DENAFRIPS TERMINATOR 15TH PLUS DAC Black
New
The Denafrips Terminator 15Th Plus is a high-performance, symmetrical R2R NOS DAC capable of delivering incredibly pure, rich sound. It benefits from an uncompromising design, conceived to offer the best possible musical experience!
By buying this product you get 979 loyalty points
Reference : 20771
9 790,00 €tax incl.
8 158,33 € tax excl.
Denafrips Terminator 15Th Plus DAC R2R NOS Balanced 24bit 1536kHz DSD1024 Black
Denafrips Terminator 15Th Plus : Front view
Denafrips Terminator 15Th Plus: An exceptional DAC
The Denafrips Terminator 15th Plus digital/analogue conversion module and its R2R ladder networks are perfectly isolated. The two boards are physically linked by the OCXO clock module. Physical isolation reduces background noise and gives a better signal-to-noise ratio.
The Terminator 15th Plus is equipped with two OCXO clocks operating at 45.1584MHz and 49.152MHz. Encased in a metal case in the centre of the DAC, these OCXOs are specially designed for high-end audio applications with ultra-low phase noise and very high precision. Both OCXOs are powered by the completely redesigned power supply circuit, providing a constant current to the clocks. Adequate power reserves guarantee the linearity and stability of the clock signal.
Jitter is also reduced by reclocking the FIFO buffer. The adaptive FIFO buffer stores digital audio data. These are read directly using the very low phase noise OCXO located directly in the DAC.
The Terminator 15th Plus also features an OCXO clock output for perfect synchronisation of several audio devices.
Denafrips Terminator 15Th Plus : Black and Silver version
Denafrips Terminator 15Th Plus : triple transformers
Denafrips Terminator 15Th Plus: An oversized power supply stage
Denafrips Terminator 15Th Plus incorporates its own linear power supply stage, located beneath the DAC board and separated from it by a steel partition to prevent interference. The power supply uses three large O-Core toroidal transformers for the digital and analog sections, and low ESR capacitors to provide a stable electrical signal to all audio circuits.
Denafrips Terminator 15Th Plus: FPGA signal processing
To ensure the shortest possible signal path, I2S and SPDIF signals are processed on an FPGA chip, without any additional conversion chips.
Denafrips Terminator 15Th Plus : FPGA
Denafrips Terminator 15Th Plus : BNC and Coaxial inputs
Denafrips Terminator 15Th Plus: Connectors
The Denafrips Terminator 15Th Plus also boasts comprehensive connectivity, enabling easy integration into the vast majority of audio systems. Inputs include USB-B, I2S RJ45 LVCMOS, I2S RJ45 LVDS, I2S HDMI LVDS, AES/EBU, Toslink optical and coaxial. Outputs include unbalanced stereo RCA and balanced stereo XLR. Two clock outputs enable the Terminator and another audio device to be perfectly synchronized for optimum system performance.
Denafrips Terminator 15Th Plus : Connector diagram
1Balanced XLR output
2Single-ended RCA output
3/4Clock output
5Coaxial input
6Toslink optical input
7/8AES/EBU input
9I2S HDMI LVDS input
10/11I2S RJ45 LVDS / LVCMOS input
12USB-B input
13Power connector
Please note that the mains cable is not supplied.
Product typeNOS balanced R2R DAC
Inputs1x USB-B
1x I2S via HDMI LVDS
1x I2S via RJ45 LVDS
1x I2S via RJ45 LVCMOS
2x AES/EBU
1x Optical Toslink
1x Coaxial
Outputs1x XLR stéréo symétrique
1x RCA stéréo asymétrique
Supported sampling ratesUSB / I2S: PCM up to 1536kHz, DSD up to DSD1024
Optical / Coaxial / AES: PCM up to 24bit 192kHz, DSD DoP up to DSD64
Output level/impedanceRCA : 2.2Vrms @ 625Ω
XLR : 4.4Vrms @ 1250Ω
Sampling modesNon-oversampling (NOS)
Oversampling (OS)
FiltersSlow roll-of
Fast roll-of
Frequency response20‒80kHz (+1/-3dB)
Total harmonic distortion more noise (THD+N)0.0015% (A-weighted)
Signal-to-noise ratio (SNR)129dB
Dynamic range>132 dB
Crosstalk-120dB
Power supply voltage115V AC 60Hz; 230V AC 50Hz
Consumption≤20W
Dimensions430 x 385 x 108 mm
Weight18.75kg
Package1x Denafrips Terminator 15Th Plus
InputI2S via RJ45
InputI2S via HDMI
InputAES/EBU
DAC / ADC ChipR2R LADDER DAC
Max sampling rate1536kHz
Max sampling rateDSD1024
DENAFRIPS TERMINATOR PLUS 15TH DAC R2R NOS Balanced 24bit 1536kHz DSD1024 Black
The Denafrips Terminator 15Th Plus is a high-performance, symmetrical R2R NOS DAC capable of delivering incredibly pure, rich sound. It benefits...
