SMSL DAC MINI DAC Headphone Amplifier
New
The SMSL DAC Mini, as its name suggests, is a compact desktop DAC that also features a built-in headphone amplifier. It is based on an ES9039Q2M DAC chip combined with an XMOS XU-316 USB interface, allowing it to support high-resolution sampling rates up to PCM 32bit 768kHz and DSD256. It is also capable of driving a wide range of headphones via its 3.5mm single-ended jack and 4.4mm balanced jack headphone outputs, delivering up to 2x 317mW under a 32ohm load.
Reference : 21530
139,00 €tax incl.
115,83 € tax excl.
SMSL DAC Mini DAC Headphone Amplifier ES9039Q2M XMOS XU316 32bit 768kHz DSD256
Photo of the SMSL DAC Mini
The SMSL DAC Mini, as its name suggests, is a compact desktop DAC that also features a built-in headphone amplifier. It is based on an ES9039Q2M DAC chip combined with an XMOS XU-316 USB interface, allowing it to support high-resolution sampling rates up to PCM 32bit 768kHz and DSD256. It is also capable of driving a wide range of headphones via its 3.5mm single-ended jack and 4.4mm balanced jack headphone outputs, delivering up to 2x 317mW under a 32ohm load. In addition to its headphone outputs, it includes essential connectivity with a USB-C input, a USB-A Host input, an RCA line output, and a mini optical Toslink output. The device stands out with its distinctive design, pairing perfectly with a Mac Mini both ergonomically and aesthetically, thanks to details such as its small orange side button.
SMSL DAC Mini: ES9039Q2M DAC
Featuring an ES9039Q2M DAC and an XMOS XU-316 USB interface, the SMSL DAC Mini supports high-resolution sampling rates up to PCM 32bit 768kHz and DSD256 while delivering excellent technical performance, including a THD+N of 0.000125% (-118dB) on its line output and 0.000178% (-115dB) on its headphone outputs.
SMSL DAC Mini THD+N performance
SMSL DAC Mini ES9039Q2M DAC
SMSL DAC Mini high headphone output power
SMSL DAC Mini: High Headphone Output Power
In addition to its dual headphone outputs ensuring wide compatibility, the DAC Mini provides output levels capable of driving a large variety of headphones available on the market.
Headphone Output Levels
Load ImpedanceOutput Power
16Ω265mW x2
32Ω317mW x2
64Ω280mW x2
150Ω120mW x2
300Ω60mW x2
600Ω30mW x2
SMSL DAC Mini: The Perfect Match for Mac Mini
Its design allows it to sit neatly beneath a Mac Mini for seamless desktop integration. Details such as the orange side button and the illuminated top base further enhance its visual appeal.
SMSL DAC Mini perfect Mac Mini integration
SMSL DAC Mini Overview
SMSL DAC Mini overview
1Auxiliary power button (Mac Mini power)
2Touch button
33.5mm single-ended  headphone output
44.4mm balanced headphone output
5RCA line output
6Optical mini Toslink output (SPDIF)
7USB-A input (Host)
8USB-C input
9Decorative light indicator
10Auxiliary power button (Mac Mini power)
Technical Specifications
Product TypeDAC
DAC ChipES9039Q2M
Inputs1x USB-C
1x USB-A (Host)
Outputs1x RCA line output
1x Optical Mini Toslink (SPDIF)
1x 3.5mm single-ended headphone output
1x 4.4mm balanced headphone output
Supported sampling ratesPCM 32bit 768kHz
DSD DoP256
DSD256
Headphone Output Power265mW x2 @ 16Ω
317mW x2 @ 32Ω
280mW x2 @ 64Ω
120mW x2 @ 150Ω
60mW x2 @ 300Ω
30mW x2 @ 600Ω
THD+NRCA line output: 0.000125% (-118dB)
Headphone outputs: 0.000178% (-115dB)
Dynamic RangeRCA line output: 122dB
Headphone outputs: 120dB
SNRRCA line output: 121dB
USB CompatibilityWindows 7/8/9/10/11 (driver required)
Mac OSX10.6+, Linux, Android
Power SupplyVia USB-C
Power ConsumptionOperating: < 4W
Standby: < 0.3W
Dimensions127 x 28.2 x 133.6mm
Weight0.244kg
ColorSilver
Package Contents1x SMSL DAC Mini
1x USB-C cable
OutputJack 3.5mm
OutputOptical Mini-Toslink
OutputJack 4.4mm
DAC / ADC ChipES9039Q2M
Max sampling rate768kHz
Max sampling rateDSD256
ColorSilver
SMSL DAC MINI DAC Headphone Amplifier ES9039Q2M XMOS XU316 32bit 768kHz DSD256
The SMSL DAC Mini, as its name suggests, is a compact desktop DAC that also features a built-in headphone amplifier. It is based on an ES9039Q2M...
