SMSL PS100 DAC ES9023 USB SPDIF HDMI ARC Bluetooth 5.0 24bit 192kHz
The SMSL PS100 is an affordable, high-performance and incredibly versatile DAC. Despite its small size, the PS100 uses quality components and a proven conversion chip (ESS SABRE ES9023) to ensure accurate and faithful sound reproduction.
4.8 / 5
Reference : 18105
32,90 €tax incl.
27,42 € tax excl.
Shipping date: 01-07-2025.
SMSL PS100
DAC ES9023 USB SPDIF HDMI ARC Bluetooth 24bit 192kHz
The SMSL PS100 is an affordable, high-performance and incredibly versatile DAC. Despite its small size, the PS100 uses quality components and a proven ESS Sabre ES9023 digital/analog conversion chip to ensure accurate and faithful sound reproduction. It also offers a full range of connectivity options to meet most connection needs, with inputs for USB-C, HDMI (ARC), SPDIF (coaxial and optical), and even Bluetooth 5.0 thanks to its ABS plastic case.
SMSL PS100 HDMI ARC
SABRE ES9023
ESS ES9023 DAC
This SMSL PS100 benefits from a ES9023 digital/analog conversion chip that is tried and trusted in the HiFi world. It boasts excellent technical characteristics and performance: 112dB SNR, 24bit / 192kHz decoding, the manufacturer's HyperStream® technology...
HDMI ARC
HDMI ARC input (Audio Return Channel)
A first in this price range, this SMSL DAC features an HDMI ARC input. This means you can connect it directly to your compatible TV to enjoy flawless, high-quality stereo sound.
Supports HDMI ARC only. Does not support eARC, so you won't be able to control volume with your TV remote.
Highly versatile
The SMSL PS100 gives you a huge number of inputs, and therefore a huge number of connection and configuration options. You can connect a computer, mobile phone, tablet, television, CD/DVD player, audio network player, active speakers, integrated amplifier, etc. to this DAC.
PS100 polyvalence
Technical specifications
Type of productDAC
DAC chipESS SABRE ES9023
Inputs1* USB-C
1* HDMI ARC
1* Coaxial
1* Optical
Bluetooth 5.0
Ouputs1* RCA Stéréo
Output level1.9Vrms
THD+N96dB
SNR98dB
USB compatibilityWindows 7 / 8 / 8.1 / 10 / 11
MAC OS X10.6 and later
Linux
Supported sampling ratesUSB: PCM up to 16bit 48kHz
Optical / Coaxial: PCM up to 24bit 192kHz
Power on / standby power consumption2W / <0.1W
Supply voltage5V 200mA via USB-C
Dimensions (W*D*H)105*80*22mm
Net weight90g
Chassis materialABS plastic
Package1* SMSL PS100
1* HDMI cable
1* USB cable
InputHDMI ARC
DAC / ADC ChipES9023
Max sampling rate192kHz
5 reviews
Robert M
I bought this product for the HDMI-ARC connection. With this SMSL box I could not control the volume level with the remote control of my LG TV. When I checked the small user manual, it is indeed stated that it is not possible to control the volume level with this box. It would be nice if Audifonics could give a more complete description of the products they sell.
This review has been posted for SMSL PS100 DAC ES9023 USB SPDIF HDMI ARC Bluetooth 5.0 24bit 192kHz
Works fine
Bought for HDMI ARC with an LG TV, it works well. Also tested for phone USB OTG, very good. Very good price for all functions included.
Parfait
Relié à la tv par hdmi arc et à l´ordi par toslink, cet appareil envoi un signal analogique tout à fait correct sur l´ampli.
Pour le jus, j´ai mis un vieux chargeur de téléphone, et hop.
Le bluetooth fonctionne aussi. Je n´ai pas testé le son par usb avec le driver dispo sur le site du constructeur.
Pour transformer le son d'une TV
J'ai acheté ce DAC pour améliorer le son de ma TV, à qui je peux ajouter désormais un ampli stéréo et des enceintes dignes de ce nom. Par Toslink ce PS100 décode le signal venu directement du Player Freebox, tout en étant sous tension grâce à une des prises USB de l'écran (pratique !).
Tout petit rikiki, donc discret, il n'en est pas moins richement doté en connexions. Surtout, question son, il fait plus que le job ! Etonnant pour le prix.
Je l'avais choisi un peu nez au vent, pour sa connectique et son prix, mais il confirme que chez Audiophonics il n'y a pas de mauvais produits. Je recommande !
Excellent mini-dac for very affordable price.
Simple, cheap but excellent and very versatile mini-DAC with HDMI-Arc input. Power over USB which every modern TV has. 24 bit resolution and 192khZ sample frequency by far enough for any home theatre. Limitation to only 2 channels.
 (4)
The SMSL PS100 is an affordable, high-performance and incredibly versatile DAC. Despite its small size, the PS100 uses quality components and a...
