perfect little device for active speakers without volume control, sounds better for the cost, works flawlessly with the TV (LG HDMI ARC), no problems at
DAC ES9023 USB SPDIF HDMI ARC Bluetooth 24bit 192kHz
The SMSL PS100 is an affordable, high-performance and incredibly versatile DAC. Despite its small size, the PS100 uses quality components and a proven ESS Sabre ES9023 digital/analog conversion chip to ensure accurate and faithful sound reproduction. It also offers a full range of connectivity options to meet most connection needs, with inputs for USB-C, HDMI (ARC), SPDIF (coaxial and optical), and even Bluetooth 5.0 thanks to its ABS plastic case.
This SMSL PS100 benefits from a ES9023 digital/analog conversion chip that is tried and trusted in the HiFi world. It boasts excellent technical characteristics and performance: 112dB SNR, 24bit / 192kHz decoding, the manufacturer's HyperStream® technology...
A first in this price range, this SMSL DAC features an HDMI ARC input. This means you can connect it directly to your compatible TV to enjoy flawless, high-quality stereo sound.
Supports HDMI ARC only. Does not support eARC, so you won't be able to control volume with your TV remote.
The SMSL PS100 gives you a huge number of inputs, and therefore a huge number of connection and configuration options. You can connect a computer, mobile phone, tablet, television, CD/DVD player, audio network player, active speakers, integrated amplifier, etc. to this DAC.
| Specifications | |
| Type of product | DAC |
| DAC chip | ESS SABRE ES9023 |
| Inputs | 1* USB-C 1* HDMI ARC 1* Coaxial 1* Optical Bluetooth 5.0 |
| Ouputs | 1* RCA Stéréo |
| Output level | 1.9Vrms |
| THD+N | 96dB |
| SNR | 98dB |
| USB compatibility | Windows 7 / 8 / 8.1 / 10 / 11 MAC OS X10.6 and later Linux |
| Supported sampling rates | USB: PCM up to 16bit 48kHz Optical / Coaxial: PCM up to 24bit 192kHz |
| Power on / standby power consumption | 2W / <0.1W |
| General | |
| Supply voltage | 5V 200mA via USB-C |
| Dimensions (W*D*H) | 105*80*22mm |
| Net weight | 90g |
| Chassis material | ABS plastic |
| Color | Black |
| Package | 1* SMSL PS100 1* HDMI cable 1* USB cable |
| Input | USB |
| Input | Optical |
| Input | HDMI ARC |
| Input | SPDIF |
| Input | Bluetooth |
| Output | RCA |
| DAC / ADC Chip | ES9023 |
| Max sampling rate | 192kHz |
| Color | Black |
| Networking | No |
| Remote Control | No |
Average votes 4.9 / 5 10 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Georgios D.
Paul M.
Marc E.
Julien V.
David R.
