TOPPING D10S DAC USB 32bit/384kHz DSD 256 XMOS U208 ES9038Q2M Black
12%
Revisited version of the D10 from Topping, the D10s is an office DAC with impressive capabilities in its price range. This second version includes an ESS ES9038Q2M 32bit high-fidelity decoding chip as well as an XMOS U208 USB interface with a customized Thesycon driver to cover most of the high resolution audio formats (up to PCM 384kHz / DSD 256).
4.7 / 5
Reduced price!
Reference : 14686
Limited time offer:
109,00 €tax incl.
-12%
95,92 €tax incl.
79,93 € tax excl.
Shipping date: 09-07-2025.
Topping D10s
DAC / interface USB 32bit ES9038QM PCM 384kHz DSD256 XMOS U208
With analog and digital outputs, it is the solution of choice for any compact and scalable High-Fidelity installation with many options for integration.
A welcome evolution of the Topping D10
Topping D10S
Topping D10
DAC
ES9038Q2M
Es9018K2M
THD+N @1kHz A-weighted
<0.0002%
<0.0008%
SNR @1kHz A-weighted
120dB
115dB
Noise A-weighted
<2.5uVrms
<4uVrms
Crosstalk @1kHz
-135dB
-115dB
Channel balance
<0.02dB
0.1dB
Output impedance
20Ω
100Ω
The Topping D10s audio circuit
DAC ES9038Q2M
At the cutting edge of technology, Topping's DAC D10s uses an ES9038Q2M chip from ESS Technology. This component is among the best current hardware solutions for high-fidelity audio decoding, especially with the famous HYPERSTREAM 32 BIT architecture. This chip model is also equipped with advanced reconstruction filters and has excellent finesse in dithering.
The Q2M version is particularly appreciated in desktop and mobile devices since it consumes little energy and offers excellent performance while allowing extremely space-saving design and form-factor.
Asynchronous XMOS U208 USB interface
The USB-B input (USB-2 standard) operates through an XMOS U208 USB interface. This is a benchmark component that no longer has to prove itself in the world of high-fidelity music, supporting very high resolution / high sampling frequency digital streams for precise, rich and detailed listening experience.
This USB interface has an asynchronous architecture capable of overcoming digital noise as well as jitter from the source if the latter does not have reference clocks suitable for Hi-Fi audio use. This significantly increases audio accuracy compared to DACs and sound cards traditionally found in the general consumer market.
Modular analog output stage
The output stage of the D10s works with an operational amplifier LME49720NA mounted on a DIP8 support. The OPA is removable and can easily be replaced by the user for testing purpose and to find the best sound signature according to one's personnal preferences.
Please note this operation is not recommended for users with no experience in operational amplifiers. Any unsuited model or improper installation could cause damage to the device.
Connection panel
The analog output is available on a stereo RCA connector. Just connect it to a preamplifier itself connected to a power amplifier, to an integrated amplifier or to passive speakers and the audio system is already operational. It is also possible to connect the analog output to a headphone amplifier and take advantage of all the qualities of the D10s when listening with headphones.
The D10s has a digital output available on a Coaxial SPDIF connector as well as an optical SPDIF connector. This output supports audio streams up to 24bit - 192kHz and can re-encode 1-bit streams (DSD) up to DOP64.
This feature - usually absent from this price range - allows you to bypass the conversion stage and use the D10s as a USB to S / PDIF interface. The D10s can then interface your computer on the fly with any S / PDIF device, a particularly useful function for audiophiles that already own a powerful DAC which lacks an USB input.
The USB-B input on the far right provides connection to your computer / OTG  smartphone as well as powering the device. The latter therefore does not require an additional cable for its power supply which allows space-saving and clean installations even for the most limited desktop in terms of space.
A sober, compact and elegant device
With its dimensions of 103mm (width) x 146mm (depth) x 37mm (height), the D10s is one of the most compact desktop HIFI DACs available on the market.
The device is housed in an elegant 100% brushed aluminum case. A robust, durable material capable of effectively blocking any noise related to the proximity of other electronic devices, thus preventing unwanted interferences in the audio signal.
The D10s has a very elegant display on the front. Its respects the color chart of Toppping devices and allows complex installations with multiples Topping products with homogeneous general style.
The screen displays in real time the type of encoding of the audio files being played (PCM / DSD) as well as the sampling frequency of the digital stream. It allows you to check at a glance that the conversion is going as planned and that the DAC is working in the best conditions.
Audio Precision Measurements
Click on an image to enlarge the analysis result.
THD+N
Niveau RMS
Spectre FFT
Topping D10s review by Audio Science Review
" Measured performance is stellar for the category. If you want a very performant DAC, that is nice to look at but doesn't cost you much, D10s is for you ! "
Test du Topping D10S par Audio Science Review
TypeDAC
InputUSB-B
OutputsDigital: SPDIF Optical & SPDIF Coaxial
Analog: RCA stéréo
Input sampling ratePCM : 44.1kHz - 384kHz / 16-32bit
DSD : DSD64 - DSD256 (Natif)
DOP : DOP128
Digital output sampling ratePCM : 44.1kHz - 192kHz / 16-24bit
DOP : DOP64
THD+N @ 1kHz A-wtless than 0.0002%
SNR @ 1kHz A-wt120dB
Dynamic range @ 1kHz A-wt120dB
Frequency response20Hz-20kHz(+/-0.1dB)
20Hz-40kHz(+/-0.4dB)
Output level2Vrms @0dBFS
Noise @A-wtless than 2.5 uVrms
Crosstalk @ 1kHz A-wt-135dB
Channel balanceless than 0.02dB
Output impedance20Ω
Power SupplyUSB-B 5VDC 0.5A
Package contents
DAC Topping D10Sx1
Male USB-A to male USB-Bx1
User manualx1
OutputOptical Toslink
OutputCoaxial SPDIF
DAC / ADC ChipES9038Q2M
Max sampling rateDSD256
Max sampling rate384kHz
Interface chipXMOS XCore U208
9 reviews
très bon petit Dac
Bonjour . J'ai acheté ce petit dac pour m'en servir comme interface Usb . J'utilise un Dac Hélixir avec son interface Usb d'origine mais j'ai besoin d'une deuxième interface pour brancher un deuxième ordinateur sans avoir à toucher les branchements à chaque fois .J'ai fait des essais comparatifs entre l'interface d'origine Hélixir , une M2Tech Hiface 1 et ce Dac utilisé en interface .
Celui ci arrive dernier . Je ne vais pas le garder .
J’en ai profité pour comparer le Hélixir et le Topping . Là encore le Topping est battu .
À l’écoute du Topping , dans les deux essais , il y a un voile sur la micro dynamique ( mais la sonorité est belle ) .
Les chiffres donnés par Audio Science Rewiew classent le Topping très près du Mola Mola Tanbaqui valant 11000 € . Je constate que les chiffres ne suffisent donc pas .
Conclusion : mon Hélix et son interface valent 90 fois le prix du Topping .
Je suis rassuré de voir qu’il y a une différence . Mon souvenir ramène le Topping aux environ de mon ancien Dac qui valait 28 fois plus cher .
Le Topping est donc un produit , ayant un excellent rapport qualité prix , qui ne s’adresse pas aux personnes cherchant l’ultime perfection .Si ce n’est pas votre cas , vous pouvez l’acheter et en tirerez beaucoup de plaisir .
PS J'ai du chercher le bon driver sur le site Topping alors qu'il est noté qu'il est plug and play .
PS Comme toujours , excellent service de Audiophonics .
This review has been posted for TOPPING D10S DAC USB 32bit/384kHz DSD 256 XMOS U208 ES9038Q2M Black
Easy to use. Excellent specifications.
Pourquoi payer plus un convertisseur USB vers RCA ?
J'avais besoin de rajouter une entrée sur mon ampli intégré pour écouter internet (youtube and Co) depuis mon PC.
Pas besoin d'un truc audiophile (j'ai un HifiRose 250 pour ça).
Je voulais simple, efficace et direct : PC+ D10s sur une entrée de mon intégré. Système autonome. Parfait.
Je me suis amusé à comparer un concert youtube entre mon entrée line-1 (PC+D10s) et line-2 (Rose).
Oui le Rose est meilleur mais pas 20 fois mieux (prix du rose = 20 fois celui du D10s).
Humour :
Ce Topping D10s n'est pas assez cher pour être pris au sérieux !
Idéal pour ajouter une entrée USB à un DAC qui est dépourvu
La sortie optique de mon iMac comporte un léger rumble. Ce DAC m'a permis d'utiliser l'USB pour alimenter mon DAC Linn via l'entrée SPDIF coaxiale, car il n'a pas d'entrée USB. Pas de driver nécessaire sur Mac. Pas de rumble! Fonctionne avec J River et encore mieux avec Roon (meilleure gestion du volume). Toutes fréquences audio HD FLAC reconnues. Son correct, un peu doux, légèrement moins de punch qu'en utilisant l'UPnP ou Roon via le réseau sur le Linn. Produit très bien fini.
qualité de son parfaite mais bug de connexion avec apple et sony
Je suis super satisfait quand cela fonctionne ...Sur source pc bureau w10 vers dac c'est vraiment excellent, idem source Motorola g7 vers dac et Samsung s8 vers dac . C'est du plug and play avec w10 + samsung, Mais pour Motorola c'est galère , pas instantané, cela fonctionne après avoir "bidouillé" qques installations de driver un peu "au pif" mais vraiment galère à faire fonctionner avec un Motorola g7 qui est quasi neuf ( 6 mois . Pour apple S6, il faut oublier, pas moyen de faire fonctionner l'association entre les deux produit : topping et s6. Idem avec tablette Sony qui ne trouve pas le dac ...Donc je mets 3 Etoiles car c'est dommage que le constructeur ne fasse pas des efforts pour rendre compatibles son DAC avec plus de versions android et apple.
J'ai acheté ce produit pour le mettre sur une installation " light " en terme de place et de mode de fonctionnement, avec comme source un ampli Cyrius + une source telephone portable ou tablette + enceinte Davis eva mais là je suis contraint à devoir mettre mon téléphone portable que j'utilise comme outil de communication et donc pas adapté pour lecture sur Quobuz... J vais devoir récupérer un pc portable pour le mettre en lecteur source mais ergonomie et place pas aussi bien que celle du telephone portable .
Le dac est source d'amélioration qualitative réelle, avec quobuz, c'est étonnant comme changement : on perçoit les details, la scène sonore, les instruments et voix sont plus clairs.
Revisited version of the D10 from Topping, the D10s is an office DAC with impressive capabilities in its price range. This second version includes...
