FIIO SNOWSKY DISC Digital Audio Player DAP Black
The FiiO Snowsky Disc is a digital audio player (DAP) that combines a retro design inspired by CD walkmans with modern audio technology. Ultra-compact and lightweight, it slips easily into a pocket and features a distinctive 1.8inch (360x360px) disc-shaped IPS display. It features two CS43131 DAC chips, compatible with 32bit 384kHz PCM and DSD128, and an Ingenic X2000 processor, delivering faster processing speeds for an enhanced music listening experience.
Reference : 21610
87,90 €tax incl.
73,25 € tax excl.
FiiO Snowsky Disc Digital Audio Player DAP 2x CS43131 Bluetooth 5.4 WiFi AirPlay 32bit 384kHz DSD128 Black
FiiO Snowsky Disc
In addition, the Snowsky Disc features Wi-Fi connectivity, Bluetooth 5.4, as well as a single-ended 3.5mm output and an balanced 4.4mm jack output delivering up to 280mW, all designed to cater to a wide range of on-the-go use cases.
FiiO Snowsky Disc: A high-performance DAP
The Snowsky Disc is equipped with two CS43131 DAC chips, enabling it to support audio formats up to 32bit 384kHz PCM and DSD128 within a balanced audio circuit with an independent power supply. With a signal-to-noise ratio of 129dB and low output impedance (32Ω), it ensures precise control of the transducers, even with demanding headphones or earphones. The player can deliver up to 125mW via its 3.5mm single-ended output and 280mW via its 4.4mm balanced output, providing sufficient power for a wide range of headphones and earphones
FiiO Snowsky Disc A high-performance DAP
xxx
FiiO Snowsky Disc: Connectivity and battery life
The Snowsky Disc features Wi-Fi connectivity with Airplay support and Bluetooth 5.4 with LDAC support, enabling a fast, stable and high-fidelity wireless connection to Bluetooth headphones or speakers for on-the-go listening. It also features a microSD card slot supporting cards up to 2TB (not included), and offers approximately 12 hours of continuous playback thanks to its 1450mAh battery.
FiiO Snowsky Disc: Design and versatility
The retro design of the Snowsky Disc makes this device as stylish as it is high-performing. The Snowsky Disc can play audio files (DSD, MP3, OGG, WMA, AAC, WAV, FLAC) from a microSD card or via USB (in DAC mode), and stream to headphones or earphones via Bluetooth. With a vintage style reminiscent of CD players, its robust aluminium casing and circular IPS screen offer a variety of dynamic user interfaces that support the display of album covers and lyrics. Furthermore, it also provides access to an equaliser with 8 modes, such as "retro" and "pop", as well as numerous filters allowing for complete listening customisation. Finally, its X2000 processor and Linux-based OS are designed to ensure an optimal listening experience by focusing on the music itself.
FiiO Snowsky Disc Design and versatility
xxx
Product typeDigital music player (DAP)
InputsBluetooth 5.4
1x MicroSD card slot (up to 2TB, not included)
1x USB-C
OutputsBluetooth 5.4
1x 3.5mm single-ended headphone output / coaxial output combo
1x 4.4mm balanced headphone jack
WiFi2.4GHz
Airplay Support
DAC chips2x CS43131
ProcessorIngenic X2000
Screen1.8inch LCD (360x360 pixels)
Battery capacity1450mAh
Battery life12h
Charging time1.5h
Supported Bluetooth codecsAAC, SBC, LDAC
Supported file formatsDSD, MP3, OGG, WMA, AAC, WAV, FLAC
Supported sampling ratesDSD up to DSD128
PCM up to 32bit, 384 kHz
Supported sampling rates (Coaxial)DSD up to DSD64
PCM up to 24-bit, 192 kHz
Frequency response20Hz-80kHz < 2.4 db
20Hz-20kHz < 0.1 db
Noise floor2.9µV on a 3.5mm jack
1µV on a 4.4mm jack
Output settings (3.5mm output, High gain)
Powers2x 135mW @ 16Ω, THD+N < 1%
2x 125mW @ 32Ω, THD+N < 1%
2x 15mW @ 300Ω, THD+N < 1%
SNR≥ 117dB (A-wt)
THD+N0.0008% (1kHz/-6dB @ 32Ω)
Output impedance0.4Ω
Output settings (3.5mm output, Low gain)
Powers2x 60mW @ 16Ω, THD+N < 1%
2x 30mW @ 32Ω, THD+N < 1%
2x 5mW @ 300Ω, THD+N < 1%
SNR≥ 111dB (A-wt)
THD+N0.001% (1kHz/-2dB @ 32Ω)
Output settings (4.4mm output, High gain)
Powers2x 145mW @ 16Ω, THD+N < 1%
2x 280mW @ 32Ω, THD+N < 1%
2x 55mW @ 300Ω, THD+N < 1%
SNR≥ 129dB (A-wt)
THD+N0.0004% (1kHz/-8dB @ 32Ω)
Output impedance0.5Ω
Output settings (4.4mm output, Low gain)
SNR≥ 126dB (A-wt)
THD+N0.0005% (1kHz/-8dB @ 32Ω)
Supply voltage5V 2A
DimensionsAround 68 x 68 x 12.9mm
WeightAround 77.2g
Package1x Snowsky Disc
1x USB-C to USB cable
xxx
xxx
xxx
xxx
xxx
xxx
xxx
xxx
xxx
xxx
xxx
InputMicro SD
OutputJack 4.4mm
OutputJack 3.5mm
OutputBluetooth
DAC / ADC ChipCS43131
Max sampling rateDSD128
Max sampling rate384kHz
FIIO SNOWSKY DISC Digital Audio Player DAP 2x CS43131 Bluetooth 5.4 WiFi AirPlay 32bit 384kHz DSD128 Black
The FiiO Snowsky Disc is a digital audio player (DAP) that combines a retro design inspired by CD walkmans with modern audio technology....
