The Fosi Audio DAP Neo is a portable digital audio player designed to listen to your music library without relying on a streaming service. It features a Cirrus Logic CS43198 DAC and supports MP3, FLAC, WAV, APE, M4A and DSD files. This version comes with a 16GB microSD card, and the player accepts cards with capacities of up to 256GB. For listening, it features an unbalanced 3.5mm headphone jack output and Bluetooth connectivity using the SBC codec.
Its 2.4-inch TFT LCD color screen, with a resolution of 320 × 240 pixels, displays music information, while its touch control wheel, side buttons and minimalist interface make navigation easy. Its all-metal enclosure, CNC-machined on a 5-axis machine, measures 97 × 47 × 10.6mm and has a maximum stated weight of 75g.
Compact and lightweight, the DAP Neo is designed for portable listening with wired or Bluetooth headphones, with a stated battery life of up to 12 hours. Its output power is specified at 129mW and its signal-to-noise ratio at 127dB.
The Fosi Audio DAP Neo uses a Cirrus Logic CS43198 digital-to-analog converter to play MP3, FLAC, WAV, APE, M4A and DSD files. For wired listening, its 3.5mm headphone jack provides an unbalanced output. It also offers Bluetooth connectivity limited to the SBC codec. Storage relies exclusively on the included microSD card, which has a capacity of 64GB in this version; it can be expanded up to 256GB using a compatible card. The DAP Neo therefore lets you carry your personal music library with you, without requiring internal memory or streaming applications.
The DAP Neo offers up to 12 hours of playback on a single charge, depending on usage conditions. Its 2.4-inch TFT LCD color screen, with a resolution of 320 × 240 pixels, lets you browse tracks and display album information. Navigation is handled by a touch control wheel, accompanied by side buttons for accessing essential functions, including volume control, all within a deliberately minimalist interface. Its compact, all-metal chassis is CNC-machined, making it easy to carry around every day. The player comes with two screen protectors, a USB cable for charging and data transfer, and a user manual.
Technical Specifications
| Specifications | |
| Product type | DAP Digital Audio Player |
| Outputs | 3.5mm Unbalanced Jack Bluetooth |
| DAC chips | CS43198 |
| Battery life | 12h |
| Supported sampling rates | PCM up to 32bit 384kHz DSD up to DSD256 |
| Inputs | SD Card |
| Supported Bluetooth codecs | SBC |
| Touchscreen | |
| Screen | TFT LCD 2.4" (320×240px) |
| Supported audio formats | MP3, FLAC, WAV, APE, M4A, DSD |
| WiFi | |
| SNR | 127dB |
| Connectivity | Bluetooth |
| Storage | 16GB |
| General | |
| Color | Black |
| Dimensions | 97 × 47 × 10.6mm |
| Package contents | 1x Fosi Audio DAP Neo 2x Screen Protectors 1x USB-C Charging Cable |
| Input | SD Card |
| Output | Bluetooth |
| Output | Jack 3.5mm |
| DAC / ADC Chip | CS43198 |
| Max sampling rate | NC |
| Color | Black |
