HIDIZS AP80 PRO MAX Digital Music Player DAP Gray
The Hidizs AP80 Pro Max is a compact, high-performance digital audio player designed to deliver high-resolution playback and amplification for demanding portable headphones. It features two ES9219C DAC chips, compatible with 32bit 384kHz PCM and DSD256, as well as MQA 16x, and an X1600E SoC processor for faster processing speeds, improved navigation, and greater Bluetooth stability.
Reference : 21599
189,00 €tax incl.
157,50 € tax excl.
Hidizs AP80 Pro Max Digital Music Player DAP 2xES9219C 32bit 384kHz PCM DSD256 Gray
HIDIZS AP80 PRO MAX Grey
To deliver powerful and stable audio output across a wide range of headphones and earphones, the Hidizs AP80 Pro Max features a balanced 4.4mm Jack output and a single-ended 3.5mm Jack output. For portable use, the 3.5mm Jack output, which delivers up to 2x70mW at 32Ω, is best suited for use in-ear headphones to ensure clear and natural sound. The 4.4mm Jack output, on the other hand, is much better suited for high-impedance headphones, with its capability to reach up to 2x190mW at 32Ω, delivering a spacious soundstage with precise detail.
Hidizs AP80 Pro Max Description
Hidizs AP80 Pro Max Features
Hidizs AP80 Pro Max: Versatile Features
The Hidizs AP80 Pro Max is designed to offer a versatile DAP with high-quality sound in a compact form factor. It allows you to play music from a microSD card (sold separately), via two-way Bluetooth 5.1 (supporting the high-resolution aptX and LDAC codecs) or via 2.4GHz Wi-Fi. Wi-Fi provides access to services such as Tidal, Qobuz, DLNA, and AirPlay.
A range of connection options are available with or from the AP80 Pro Max. The built-in bidirectional Bluetooth 5.1 allows you to receive or transmit music, but also enables the device to act as a wireless DAC for a computer.
Furthermore, to offer greater versatility, the AP80 Pro Max features an e-book reader function, allowing you to listen to music and read on the same device.
Hidizs AP80 Pro Max: USB DAC mode
Thanks to its bidirectional USB connectivity, the Hidizs AP80 Pro Max can be used as a DAC USB for an external device (smartphone, tablet, computer, etc.) or as a high-quality digital audio source to connect to an external DAC. In USB DAC mode, the device uses its own battery for power, which reduces interference from external sources and preserves the battery life of your source device.
Hidizs AP80 Pro Max USB DAC Mode
Hidizs AP80 Pro Max Customization
Hidizs AP80 Pro Max: Customization Options
Running on HiByOS, a system designed exclusively for high-fidelity audio, the AP80 Pro Max offers comprehensive sound customization options, including a 10-band parametric equaliser (PEQ), an equalizer (EQ), digital filters and the exclusive MSEB tuning system. It guarantees pure and detailed sound reproduction, whilst offering a responsive and stable user experience.
In addition, with the HiByLink function, your smartphone becomes a wireless remote control for the AP80 Pro Max. This allows you to control playback, adjust the volume and manage your playlists without touching the DAP.
Hidizs AP80 Pro Max: A practical and elegant design
Crafted from aluminium alloy and featuring double-layered glass, the AP80 Pro Max combines durability with elegance. Its 2.95-inch HD touchscreen (360 x 640px) offers a crystal-clear display and a truly comfortable user experience. The volume dial, featuring an ALPS potentiometer, and the physical buttons provide intuitive control.
Hidizs AP80 Pro Max Design
Hidizs AP80 Pro Max Impressive battery life
Hidizs AP80 Pro Max: Impressive battery life
The AP80 Pro Max is equipped with a built-in high-capacity 1300mAh 3.8V battery. Combined with a low-power design and a highly efficient independent battery management system, the AP80 Pro Max offers up to 12 hours of continuous playback or 60 hours on standby. The 1-hour fast-charging feature meets your daily needs, whether you’re commuting, travelling or exercising, allowing you to enjoy your music with complete peace of mind, without worrying about the battery level.
Review of the AP80 Pro Max by Audio Science Review
" It is so impressive to see so much functionality in such a tiny player yet with performance that is clearly optimized. Across almost all tests, you are getting desktop class performance and a good one at that ! I am going to recommend the Hidizs AP80 Pro Max. "
Product typeDigital audio player (DAP)
ProcessorIngenic X1600E
DAC Chip2x ES9219C
Operating systemHiBy OS
Outputs1x Jack 3.5mm single-ended
1x Jack 4.4mm balanced
1x USB-C
ConnectivityWiFi 2.4GHz
Bluetooth 5.1
Supported Bluetooth codecsSBC
AAC
aptX
LDAC
HiBy
UAT
Supported Wi-Fi protocolsAirplay, DLNA, HiByLink, Tidal, Qobuz
Touchscreen360x640 (2.95") HD
Supported sampling ratesPCM up to 32bit, 384 kHz
Native DSD up to DSD256
Technology Audio MQAMQA 16x
Single-ended output power2x70mW into 32Ω
Balanced output power2x190mW into 32Ω
Signal-to-noise ratio (SNR)Single-ended output: 119dB
Balanced output: 120dB
Total harmonic distortion with noise (THD+N)Single-ended output: 0.0007%
Balanced output: 0.0005%
Channel separationSingle-ended output: 78dB
Balanced output: 110dB
Frequency response20Hz-90kHz
StorageSlot Micro SD (jusqu'à 2TB, not included)
Battery1300mAh 3.8V
Battery lifeUp to 60 days on standby
Up to 12 hours of operation
Dimensions82.8 x 51 x 15.5mm
Weight81g
Frame materialAlliage d'aluminium
ColorGrey
Package1x AP80 Pro Max
USB-C cable (Power cable)
USB-C to USB-C OTG Cable (Data Cable)
InputWiFi
InputMicro SD
OutputJack 4.4mm
OutputJack 3.5mm
OutputBluetooth
OutputUSB
DAC / ADC ChipES9219C
Max sampling rate384kHz
Max sampling rateMQA
Max sampling rateDSD256
ColorGray
HIDIZS AP80 PRO MAX Digital Music Player DAP 2xES9219C 32bit 384kHz DSD256 Gray
The Hidizs AP80 Pro Max is a compact, high-performance digital audio player designed to deliver high-resolution playback and amplification for...
