IBASSO DX220 HiFi DAP DAC 2x ES9028PRO 32bit/384kHz DSD512 Balanced
Keep the best of your high-definition music at hand with the iBasso DX220 through an intuitive Android interface designed specifically for audio.
4.8 / 5
By buying this product you get 89 loyalty points
Reference : 13837
899,00 €tax incl.
749,17 € tax excl.
This product has been replaced by the new version, the HiFi Player IBASSO DX240 ES9038PRO.
DAP Audio iBasso DX220
Double-9028PRO 32bit 384kHz DSD512, XMOS, headphone amplifier, apt-X / LDAC, MQA ...
Enjoy your best high-definition music anywhere with the DX220. This device uses a custom intuitive Android designed specifically for audio.
It has two integrated ES9028PRO  DAC chips, able to decode PCM up to 32bit 384kHz, native DSD512, and even MQA! The decoded signal is immediately connected to the integrated (interchangeable) headphone amplifier. DX220 thus provides a high level of audio reproduction while being light-weighted and hand-held.
Double ES9028PRO chip
The DX220 uses two  DAC SABRE ESS ES9028Pro 32-bit chips. This component is renowned in HiFi systems with its famous Hyperstream II technology using active jitter reduction and precise hardware volume control with signal auto-calibration.
A single ES90208Pro chip is capable of simultaneously decoding eight audio tracks. Integration of DX220 goes even further : each of the DAC chip is working only on a single audio channel. This plays a significant role in the development of a very wide sound stage with impressive crosstalk and dynamic range.
Femtosecond clocks
True nomadic multifunction audio processor, the DX220 has a CPU 8-core ARM, far enough computing power to ensure the reading and decoding of the most demanding audio files while providing a friendly and intuitive interface (Android 8.1).
The USB input is driven by XMOS chip. In addition to allowing native DSD and the very high resolution audio stream, this technology enables the DX220 to work as a USB sound card that has nothing to envy its desktop counterparts.
The trio DACs / XMOS / CPU works with 5 femtosecond clocks including two ultra low phase noise Accusilicon. This design makes the DX220 an absolutely unique DAP.
Interchangeable headset amplifier module
As is customary in iBasso work, the integrated AMP1 MKII headset amplifier is a removable and interchangeable module. The user can therefore let the hardware evolve based on technological developments or personal preferences.
All AMP modules compatible with the DX series are compatible with all previous and upcoming future systems. The DAP enjoys an upward and downward compatibility with any other amplifier modules available and future.
Bidirectional Bluetooth support
Bidirectional Bluetooth support allows the DX220 to operate as much as a receiver and as a transmitter for wireless audio stream.
The DAP is Bluetooth 5.0, LDAC and apt-X ready. It may join any technological basis already equipping your audio system while providing superior bluetooth quality (very to close audio CD).
The CNC casing includes an external antenna in order to eliminate any interference during transmission and reception.
Parametric Equalizer
In addition to a conventional 10 bands equalizer  found in most of the Sabre-based DAC, the DX220 offers the user a parametric equalizer with 8 filters / 6 segments.
Each of these filters can be customized according to the standard criteria of a standard PEQ : frequency, gain and Q factor
A clear display allows to quickly take control of this feature and to get the best audio reproduction based on the headset and other equipment used.
Battery 4400 mAh
The device is easy to charge thanks to a USB port C (reversible).
It has a 4400mAh battery capable of 8 and 9 hours of continuous playback.
The charging program is compatible with QC3.0 protocols PD2.0 and MTK PE Plus. Three quick charge protocols that allow a charge of 70% of the maximum battery in just one hour.
Panasonic polymer capacitor and specific drivers are used to reduce the internal resistance of the power supply.
A protective film on the screen must be removed before first use of the product.
TypeDAP
THD + N0.00018% / -114dB
@ 1kHz, 3.0VRms, No load, balanced
DACDouble ES9028PRO
USB interfaceXMOS U208, Thesycon USB + femto clock
Maximum Output Level6.2VRMS
Frequency response15Hz-45kHz (+/- 0.1dB)
headphone amplifierYes
AMP 1 MKII
Clocks5x Femtosecond (including 2 Accusilicon)
CPU8-core
RAM4GB
Max frequencyPCM 8-384kHz-32bit, DSD64-512 (native)
Supported formatsMQA, APE, FLAC, WAV; WMA; AAC, ALAC, AIFF, OGG, MP3, DFF, DSF, DXD, CUE, ISO
ChargeUSB-C
Protocols QC3.0, PD2.0, MTK more PE.
Battery4400mAh (8-9h)
Operating systemAndroid 8.1
Mango OS
InputsBluetooth 5.0
Micro SD (SDHC & SDXC up to 2TB)
USB-C
WiFi 802.11 b / g / n / ac (2-5Ghz)
Outputs2.5mm Balanced
3.5 Power Out
3.5mm Line Out
3.5mm SPDIF
USB-C
Dimensions126x70.5x18.7mm
Weight240g
Package Contents
DX220x1
Cable USB-Cx1
Coaxial cablex1
Leather casex1
Screen protector setx1
User guidex1
InputWiFi
InputMicro SD
OutputJack 3.5mm
OutputJack 2.5mm
OutputCoaxial SPDIF
OutputBluetooth
DAC / ADC ChipES9028PRO
Max sampling rateDSD512
Max sampling rate384kHz
6 reviews
DX 220: Diva caractérielle...
Ce DAP est un somptueux Bijou musical...
Il a un grave abyssal, une scène spacieuse et crédible. Sa musicalité est à l'avenant...
On pourrai disserter des heures sur les beautés sonores que distille cette merveille... En bref; pour un mélomane: c'est un "Must have", une source de bonheur.
Dans cette gamme de prix, Il a peu de concurrents et encore une fois; c'est une question de saveurs et de goût personnel...
J'apprécie beaucoup la fenêtre musicale qu'il me fait découvrir et Il mérite d'être associé à un très bon casque qu'il pourra transcender.
... il est aussi très versatile et rétif.
Sa manipulation est délicate et je n'aime pas son système d'exploitation qui est beaucoup trop instable. Sa bibliothèque Mango est juste passable. On est encore très loin de MacOS, et sa batterie est vraiment sous dimensionnée.
Alors évidemment..., on ne peut pas reprocher à une fusée d'être inconfortable, improbable et énergivore. Par fonction, elle nous permet d'explorer des mondes musicaux encore inconnus...
C'est une Diva! On l'aime pour son talent de Maestro très rare... mais pas pour son caractère capricieux...
This review has been posted for IBASSO DX220 HiFi DAP DAC 2x ES9028PRO 32bit/384kHz DSD512 Balanced
Oui, réellement meilleur que son prédécesseur, le DX200...
En réponse à Christian D :
vu mon exigence en matière de qualité sonore globale, je peux affirmer que le DX220 + Amp 1 [MKII] est meilleur que son prédécesseur direct, le iBasso DX200 + Amp 1 [1ère version].
Ayant la chance de posséder ces 2 DAP, j'ai pu les comparer correctement et ainsi être sûr de mon ressenti...
Attention cependant car la différence réelle et audible ne peut être qualifiée "de jour et la nuit" pour autant non plus tant le DX200 est déjà tout simplement exceptionnel !
En gros, pour moi, le DX220 est à peu près supérieur sur l'ensemble des registres et critères musicaux de 20 à 25% que le DX200, ce qui est déjà plus qu'appréciable.
Et si vous complétez ce DX220 avec le dernier module d'amplification en date, le iBasso Amp9 (avec les Nutubes Korg de 6ème génération!), le tout associé avec soit des IEM audiophiles de très grande qualité comme mes superbes Oriolus Reborn, ou soit avec un casque incroyable comme mon fabuleux Focal Stellia,
vous atteindrez rapidement le summum de ce que la musique en mobilité, actuellement, peut procurer comme émotions renversantes de beauté, et ce, en tous lieux !
Seule la batterie d'une autonomie de 6 à 7h (au grand maximum), avec des fichiers audio Flac, limitera votre durée d'immense plaisir sur les longs trajets sans recharge possible...
Hélas oui, la perfection totale n'est pas encore atteinte même si la batterie compatible avec les derniers standards de charge rapide (QC 3.0 / PD 2.0 / MTK PE Plus Quick Charge) vous permettra, avec le bon chargeur à acquérir en plus, de recharger presque 70% en 1h de temps et 100% en 2h30, contre 3h pour 70% et un peu plus de 4h pour 100% de batterie pleine avec le DX200 (temps de charge approximatif depuis une batterie totalement vide dans les deux cas de figure, DX220 vs DX200).
Pour tous ceux et celles qui sont amoureux de la musique en mode nomade et particulièrement exigeants question son, et qui avez les moyens de bien l'associer (IEM et/ou casque de très grande qualité audio) :
ce DAP est tout simplement ensorcelant et totalement addictif !!!
200vs220
moi j'aimerais bien qu'on me dise s'il est meilleur que le 200 ou pas...je parle de la restitution sonore bien sûr.
Merci d'avance.
Du son et du vrai
J'ai redécouvert des musiques grâce à ce lecteur.Des basses enveloppantes et des aigus pas trop pointus . Une très belle définition. Utilisé en carte son de PC, il vous change tout. Un vrai plaisir. Il chauffe pas mal mais il envoie tellement du lourd que çà va. Heureusement que la batterie est grosse car il dépense de l'énergie, le petit coco. Je suis vraiment content de mon achat .
Quel DAP !
Sortit d'un IPod touch, il y a de cela des années, J'ai une installation home cinéma qui me permet de visionner des films avec une bonne qualité d'écoute (RZ900 en Pure Audio en mode musique), je suis totalement satisfait de ce DAP! Je l' ai associé a des Ibasso IT04 neufs, un son cristallin , détaillé. Il me reste à profiter encore des écouteurs qui ne sont pas totalement ouverts! Un petit bémol : la chaleur qu'il dégage mais avec l 'étui on ne sent plus rien. Un peu cher mais cela mérite l achat surtout avec les amplis modulables. bravo ibasso.
