IBASSO DX260MK2 Digital Audio Player DAP Silver
New
The iBasso DX260MK2, the brand's new digital audio player, is a true concentrate of technology. Featuring a perfectly optimized design and audiophile-grade components, it offers a beautifully rich listening experience. Its new interface guarantees intuitive, fluid navigation and seamless operation.
By buying this product you get 94 loyalty points
Reference : 20817
949,00 €tax incl.
790,83 € tax excl.
Shipping date: 10-06-2025.
iBasso DX260MK2 Digital Audio Player DAP 8x CS43198 Balanced Bluetooth WiFi 32bit 768kHz DSD256 Silver White
iBasso DX260 front view
iBasso DX260MK2 key features
iBasso DX260MK2: 8x CS43198 DAC
The iBasso DX260MK2 features 8 high-end Cirrus Logic CS43198 DAC chips. These offer excellent performance, with a wide dynamic range, incredible reproduction of micro-detail and extremely low noise floor.
This Octa DAC matrix and its integration guarantee both superb sound quality and exceptional measurements with a THD+N of up to -123dB.
iBasso DX260 : 8x DAC CS43198
iBasso DX260MK2: FPGA-Master 2.0 audio controller
After years of development work on a high-performance algorithm, the FPGA-Master has now reached version 2.0. As an audio controller, it retrieves audio data directly from the SoC and plays a major role in reproducing the signal and maintaining its integrity. It synchronizes and generates all audio clocks using two NDK femtosecond oscillators for total synchronization of clock sources. The FPGA-Master 2.0 also features extremely precise control and adjusts the DAC clock, data and builds the FIR filter.
iBasso DX260 : FPGA audio controller
iBasso DX260MK2: FIR filter
Thanks to the new FPGA-Master 2.0 algorithm, the potential of the 8 CS43198 DACs is maximized.
Parallel synchronous output mode :
Reduces distortion between DAC chips to improve overall performance.
FIR 2x mode, FIR 4x mode :
With FPGA-Master 2.0, picosecond control and precise adjustment of the DAC clock is implemented, allowing independent adjustment for each conversion chip. Through this architecture, the DACs form an analog FIR filter that reduces distortion while improving sonic accuracy.
iBasso DX260 : FIR filter
iBasso DX260MK2: True power
At the heart of the iBasso DX260MK2 is a Qualcomm Snapdragon 665 processor, 4GB RAM and 128GB ROM. This design ensures smooth operation.
iBasso DX260: Snpadragon 660 processor
iBasso DX260MK2: Android 11 + Mango OS + Open OS + Linux OS
The DX260MK2 benefits from an OS based on Android 11, enabling the installation of numerous streaming applications. The DX260MK2 effectively bypasses SRC at system level. Whether with its Mango player or a third-party streaming application, you can enjoy exceptional sound quality.
The iBasso DX260MK2 also uses Mango OS, a Linux audio system meticulously designed to deliver excellent playback performance. Over time, this system has benefited from numerous optimizations to its algorithms, focusing on audio playback. Resolutely audiophile, this system generates no WiFi or Bluetooth interference, has very low EMI levels and offers a pure listening experience.
iBasso DX260: Android and Mango OS operating system
iBasso DX260MK2: USB DAC mode
With its dedicated USB receiver, the DX260MK2 can also be used as a low-latency USB DAC. It also supports ASIO / WASAPI drivers, so you can easily enhance your computer's sound reproduction.
iBasso DX260 : USB DAC mode
iBasso DX260MK2: A revisited interface
The new Mango player interface offers a revamped design and an optimized user experience. Navigation is fluid and intuitive, and the DAP is a pleasure to use.
iBasso DX260: New user interface
iBasso DX260 : Detachable rear panel
iBasso DX260MK2: Detachable rear panel
Based on the design of the DX260, the DX260MK2 sports an industrial look. Its rear panel can be removed, providing access to the battery for easy replacement.
Product typeDigital audio player (DAP)
TouchscreenIPS Sharp 5", 1080x1920px
Audio formatsAPE, FLAC, WAV, WMA, ACC, ALAC, AIFF, OGG, MP3, DFF, DSF, DXD, DST
ConnectivityUSB-C 3.1
InputsWiFi
Bluetooth
Micro SD
USB DAC
OutputsJack 4.4mm balanced headphone output
Jack 3.5mm single-ended headphone output
Jack 4.4mm line output
Jack 3.5mm line outpuit
Jack 3.5mm coaxial output
USB OTG output
WiFi802.11b/g/n/ac (2.4GHz/5GHz)
Bluetooth5.0
RAM4Go LPDDR4X
ROM64Go
BatteryLiPo 3.8V 4400mAh
Charging time2.5h
Average playback lifetime14h (may vary depending on the files played, the volume used and the impedance of the headphones/earphones)
Jack 4.4mm balanced headphone output measurements
Max output level6Vrms
Output power2x1015mW @ 32Ω, THD < 0.5%
Frequency response10Hz ~ 75kHz (-1dB)
SNR133dB
Dynamic range133dB
THD+N-121dB (A-wt, 600Ω)
-114dB (A-wt, 32Ω)
Crosstalk145dB
Noise floor< 930nV (gain faible)
Jack 3.5mm single-ended headphone output measurements
Max output level3Vrms
Output power2x280mW @ 32Ω, THD < 0.5%
2x586mW @ 16Ω, THD < 0.1%
SNR128dB
Dynamic range128dB
THD+N-115dB (A-wt, 600Ω)
-110dB (A-wt, 32Ω)
Crosstalk118dB
Noise floor< 850nV (gain faible)
Jack 4.4mm balanced line output measurements
Max output level4Vrms
SNR133dB
Dynamic range134dB
THD+N-123dB
Crosstalk145dB
Jack 3.5mm single-ended line output measurements
Max output level2Vrms
SNR128dB
Dynamic range128dB
THD+N-112dB
Crosstalk115dB
Dimensions123 x 74.5 x 17.5mm
Weight229g
ColorSilver
Package1x iBasso DX260MK2
1x USB-C cable
1x Coaxial cable
1x TPU cover
1x Screen protections
InputWiFi
InputMicro SD
OutputJack 3.5mm
OutputUSB
OutputJack 4.4mm
DAC / ADC ChipCS43198
Max sampling rate768kHz
Max sampling rateDSD256
ColorSilver
IBASSO DX260MK2 Digital Audio Player DAP 8x CS43198 Balanced Bluetooth WiFi 32bit 768kHz DSD256 Silver White
The iBasso DX260MK2, the brand's new digital audio player, is a true concentrate of technology. Featuring a perfectly optimized design and...
