SHANLING M7 Digital Audio Player DAP ES9038Pro Bluetooth 5.0 WiFi 32bit 768kHz DSD512 MQA
10%
With the M7, Shanling offers a very high-end digital music player with an exceptional design that combines incredible sound performance with great versatility and a luxurious look. The chassis, carved from a single block of aluminum, features an ES9038Pro DAC and a Qualcomm 665 Octa-Core processor. The device runs on a customized version of Android 10 and is controlled in a perfectly intuitive and ergonomic way thanks to the sublime 5" Full HD touchscreen that adorns the M7.
Reduced price!
Reference : 16389
Limited special offer
1 299,00 €tax incl.
-10%
1 169,10 €tax incl.
974,25 € tax excl.
Shanling M7
Shanling M7 Baladeur Numérique DAP ES9038Pro Bluetooth 5.0 WiFi 32bit 768kHz DSD512 MQA
Full HD touch screen
The M7 features a beautiful Sharp Full HD (1920*1080px) LCD touchscreen, making it easy to enjoy your music through a simple and intuitive interface.
ES9038Pro DAC
The audio circuit of the M7 is based on an ESS ES9038Pro digital to analog conversion chip. In addition to offering an incredibly accurate and rich sound reproduction, this DAC allows to enjoy high resolution audio streams, up to 32bit 768kHz in PCM and up to DSD512, but also MQA (Master Quality Authenticated).
OP+BUF Architecture & I/V Circuit
The four-channel amplifier stage of the M7 is designed in a completely symmetrical way, around an OP+BUF architecture. This design allows for superior sound quality with extremely low noise levels.
This amplifier stage is combined with an I/V conversion section using a pair of ADI ADA4896-2 amplifiers and MUSES8920 dual channel J-FETs ensuring very low noise and distortion. High precision film resistors with a tolerance of only 0.01% and Panasonic tantalum-polymer capacitors are also used.
The M7's audio circuitry also uses Shanling's CPAF (Constant Phase in All Frequencies) technology to solve the delay problems caused by low-pass filtering. In addition, two KDS oscillators and a third-generation FPGA enable a drastic reduction in jitter.
A consequent power
With three different gain settings, the M7 can deliver a significant power, up to 400mW under 32Ω unbalanced and 900mW under 32Ω balanced. It will thus be able to accompany both very sensitive IEMs and high impedance headphones.
A fast processor
Powered by an eight-core Qualcomm Snapdragon 665 processor and an Adreno 610 GPU, the M7 has more than enough processing power for all modern applications. In addition, this duo ensures low power consumption for a consistent battery life.
Two-way Bluetooth connection
Simply connect any Bluetooth headset or speaker to the L7, while enjoying excellent wireless sound quality with support for high-definition codecs such as aptX HD, LHDC or LDAC.
High speed WiFi
Equipped with a Qualcomm WCN3980 chip, the M7 supports 2.4G/5G WiFi as well as MIMO technology, ensuring a stable and fast connection. In addition, the DAP supports DLNA and AirPlay streaming protocols and can be synced to the Eddict app for remote control.
Product typeDigital audio player (DAP)
InputsBluetooth 5.0
WiFi 2.4G/5G
1x Micro SD Slot
OutputsBluetooth 5.0
1x Balanced Jack 4.4mm
1x Single-ended Jack 3.5mm
DAC ChipESS ES9038Pro
Touchscreen5"
Full HD 1920*1080px
RAM5Go LPDDR4X
ROM (Storage memory)128Go UFS 2.1
OSOpen Android 10
Battery7000mAh
QC3.0 support (quick charge)
Supported file formatsISO, DSF, DFF, DST ISO, DXD, APE, FLAC, WAV, AIFF, AIF, DTS, MP3, WMA, AAC, OGG, ALAC, MP2, M4A, AC3, M3U, M3U8
Supported sampling ratesPCM up to 32bit 768kHz, DSD up to DSD512, MQA
Gain setting3 levels
Supported Bluetooth codecsAs a transmitter: SBC, aptX, aptX HD, LHDC, LDAC
As a receiver: SBC, LDAC
Supported network protocolsSyncLink
DLNA
AirPlay
OTA Updates
Battery lifeSingle-ended : up to 10h
Balanced : up to 8.5h
Measurements
ParameterSingle-ended outputBalanced output
Output powerLow gain: 0.73V @ 32Ω (17mW)
Medium gain: 1.88V @ 32Ω (110mW)
High gain: 3.61V @ 32Ω (406mW)
Low gain: 1.46V @ 32Ω (66mW)
Medium gain: 3.35V @ 32Ω (350mW)
High gain: 5.43V @ 32Ω (920mW)
Frequency repsonse20Hz - 40kHz (0.1dB)20Hz - 40kHz (0.1dB)
THD+N0.0007%0.0007%
Channel separation75dB @ 32Ω115dB @ 32Ω
Dynamic range126dB128dB
SNR126dB128dB
Noise> 116dB (< 1.6uV) (low gain)> 113dB (< 2.2uV)
Output impedance< 1Ω< 1Ω
Dimensions128 x 78 x 20mm
Weight312g
PackageShanling M7
1x USB-A to USB-C cable
Protective screen
InputMicro SD
InputWiFi
OutputJack 3.5mm
OutputBluetooth
OutputJack 4.4mm
DAC / ADC ChipES9038PRO
Max sampling rateDSD512
Max sampling rateMQA
Max sampling rate768kHz
ColorGray
With the M7, Shanling offers a very high-end digital music player with an exceptional design that combines incredible sound performance with great...
