HIDIZS AP60 V2 DAP Digital HiFi Music Player 24bit/192kHz DSD128 DAC Bluetooth aptX Black
The Hidizs AP60 comes back in a revised and corrected version, while proposing a new design, compact and refined. With its many features, the AP60 V2 is a complete DAP, ensuring a high listening quality.
Reference : 12442
95,00 €tax incl.
79,17 € tax excl.
Shipping from France
Billing in France
Technical support in France
hidizs ap60
HIDIZS AP60 V2
DAP 24bit 192kHz DSD128 Bluetooth aptX AKM 4452VN DAC MAX 97220A Amplifier
Bouton potentiomètre argent
The Hidizs AP60 V2 comes back in a revised and corrected version, while offering a new compact and refined design. The AP60 V2 is a full-featured DAP with many features, ensuring high listening quality.
Hidizs AP60 v2 Features
A sumptuous new design
Designed in a CNC-machined case in a single piece of Aluminium, the DAP Hidizs AP60 V2 features an elegant and deep black dress. Its backside is covered with a glass panel, affirming a refined and thoughtful aesthetic.
Hidizs AP60 v2
Photo of Gold and Silver models, not available.
Hiby Link Smart Control Support
The AP60 V2 supports the Hiby Link functionality of the Hiby Music playback application, free downloadable here for Android or here for iOS. Hiby Link will allow you to control your DAP directly from your smartphone. This makes the use more convenient and transparent, so you don't even have to take your DAP out of your pocket.
hiby music hiby link
Bluetooth without limits
The Hidizs AP60 V2 integrates Bluetooth 4.0 Two-Way functionality. Thus, thanks to this technology, your DAP can act as a classic transmitter and thus become a high quality music source or receiver, decoding audio signals from other devices (smartphone for example). This way, you can benefit from the conversion quality of the AKM DAC integrated in the AP60 V2.
In addition, it incorporates the Lossless aptX standard. This ensures higher transmission speed, greater stability and protects the signal from possible losses. In this way, you can also enjoy your high-quality Bluetooth music.
Hidizs AP60 Bluetooth
To ensure this excellent Bluetooth quality, the Hidizs AP60 V2 features a CSR chip for lossless, CD-quality playback.
Note: To take advantage of Lossless aptX technology, your Bluetooth listening device must also be compatible with Lossless aptX technology.
A Versatile DAP
The DAC function of the Hidizs AP60 V2 is also capable of operating in "Two-Way" mode. This allows it to act both as a classical DAC, decoding an external source (computer, smartphone...), but also as a pure digital transport when it is connected to a DAC, such as the Chord Mojo or the IFI Micro iDSD.
hidizs ap60
A powerful player
The Hidizs AP60 V2 incorporates both an AKM AKM AK4452VN DAC and MAXIM MAX97220A amplifier. Thanks to these chips, the nomadic player benefits from an extended dynamic range greater than 105dB, a high Signal to Noise Ratio greater than 109dB, efficient channel separation of 106dB and very low distortion with a THD of 0.005%.
The Hidizs DAP is also capable of decoding DSD64/128 and PCM files up to 24bit 192kHz, in order to give you an accurate sound reproduction.
Hidizs AP60 V2 AKM AK4452VN et MAXIM MAX97220A
A large compatibility
It is also efficient because it is compatible with a large majority of the most commonly used audio formats, including DSD64/128.
Hidizs AP60 V2 Compatibilité
An ergonomic interface, an high quality display
The Hidizs AP60 V2 offers an extremely efficient interface that is very intuitive, whether for media playback or settings. This way, you can enjoy your music in a simple way. The AP60 V2 features a 2" 320 x 240px TFT HD TFT display and responsive mechanical physical controls.
hidizs ap60 ergonomie
Photo du modèle Silver, non disponible.
High autonomy
The DAP, to ensure a long autonomy during your travels, integrates a 1000mAh battery. This will allow you to use the device for 10 to 12 hours without recharging. Enough to enjoy your music without interruption.
hidizs ap60 batterie
ProcessorX1000
DACAKM AK4452VN
Headphone amplifierMAX97220A
DSD64, 128
USB/OTG DAC SupportYes
Bluetooth4.0
aptX Lossless
Gain settingHigh/Low Gain
Sampling rateUp to 24bit 192kHz
Supported formatsFLAC, APE, XMA, WAV, ALAC, AAC, OGG, MP3, AIFF, DSD, DIFF
OutputJack 3.5mm
Output power35mW @ 32Ω
Output impedance0.1Ω
Frequency response20Hz - 20kHz (-0.5dB)
THD+N0.005%
SNR> 109dB
Dynamic range> 105dB
Channel separation106dB
Memory extension possibleWith Micro SD Card, up to 256Go
Charge portMicro USB 2.0
Battery capacity1000mAh
Battery autonomyAbout 10-12 hours
Supported systemsMAX OSX 10.7, Windows XP/7/8/10
Screen2" TFT HD 320 x 240px
Case materialOne piece CNC Aluminium + Glass panel at the rear
Dimensions75 x 42 x 14mm
Weight70g
Package1x Hidizs AP60 V2
1x Plastic Cover
1x USB-A / Micro USB Cable
Protection screen
User manual
InputMicro SD
OutputJack 3.5mm
OutputBluetooth
DAC / ADC ChipAK4452
Max sampling rateDSD128
Max sampling rate192kHz
2 reviews
EDIT: encore mieux avec les jours qui passent
J'avais laissé un premier avis à chaud après réception, en voici un après plus de temps:
- avec un DT 770 (version 80 ohms), ça donne super bien. C'est chaud et détaillé. Parfois un poil trop rond. Mais ça reste cool.
- avec un Sony MDR-1A, c'est super cool. Les basses sont un peu trop présentes à mon goût sans jouer avec l'equalizer, mais le niveau de restitution et de spatialisation est super intéressant ! Vraiment chouette comme combo.
- en mode DAC: il écrase sans problème la sortie du MacBook Air. J'entends de suite la différence. C'est fou ce que ce petit truc arrive à sortir. Il ne chauffe pas beaucoup.
La dernière mise à jour corrige des points d'ergonomie, et c'est bienvenu !
Seul petite ombre au tableau: le choix d'équalizer choisit ne survit pas à un reboot, il faut le re-sélectionner...souci de jeunesse encore.
D'ailleurs, avec l'equalizer, meme en high gain, la perte de volume est importante. En filaire, aucun souci. En bluetooth, c'est plus pénible.
- le mode changement de pistes via les boutons de volume est fort appréciable pendant une session running.
- la batterie est satisfaisante mais pas des foudres de guerre non plus.
Je recommande vivement.
This review has been posted for HIDIZS AP60 V2 DAP Digital HiFi Music Player 24bit/192kHz DSD128 DAC Bluetooth aptX Black
Premier avis
Je cherchais un lecteur pour remplacer mon Fiio M3, afin d'enfin y voir quelque chose lorsque je run et trail en extérieur, car l'écran du Fiio M3 est ce qu'on pourrait tout bonnement qualifier de "moisi".
J'ai donc reçu aujourd'hui ce petit Hidizs AP60 Mark 2.
Le packaging est soigné. La boite est arrivée un peu abîmée mais comme d'hab avec LaPoste faut s'estimer heureux d'avoir reçu le colis déjà...
Déballage: le baladeur pèse beaucoup plus lourd qu'il n'y parait, la "faute" à son chassis tout en aluminium et en verre. Il respire la solidité.
Les boutons sont bien PHYSIQUES, et non tactiles, ni même capacitifs. De bons vieux boutons mécaniques intégrés dans la façade avant. Le bonheur du runner. Le pavé de navigation est assez grossièrement découpé sur les bordures. Mais rien de bien méchant. Par contre si vous avez de gros doigts, ce petit DAP sera l'enfer à manipuler. Oubliez le.
La sortie casque donne une impression de solidité absolue. Un "clic" se passe lorsque vous insérez votre jack. C'est vraiment du travail sérieux. Je ne m'y attendais pas.
La lecture de la carte SD s'est faite sans broncher, malgré que je dispose de fichiers encodés avec les pieds ou directement pris de sites de streaming. Là où le Fiio buggait sans cesse, m'obligeant à insérer et sortir la carte SD une dizaine de fois avant de parvenir à faire fonctionner l'appareil, là c'est instantané, pas de plantage.
L'écran est très lisible, même en extérieur, en plein soleil. Alors certes, sur un écran de 2", ce n'est pas la panacée, mais au moins on peut le lire et l'utiliser sans problème. Pas comme ce foutu Fiio M3.
Le menu de navigation est simple, très simple: navigation dans les fichiers, par ordre alphabétique, catégories de musiques (pas testé parce que je m'en fous), réglages musique (mode de lecture, etc.), réglages système.
C'est fluide, ça défile bien. Pas de problème.
La connectivité bluetooth est top mais manque de patate: obligé de mettre à fond pour avoir un son décent sur enceinte nomade (pas encore testé avec intra ou casque).
Niveau son, la signature de base de cet Hidizs est sympa, mais assez colorée sur le bas du spectre. Les basses ressortent pas mal, beaucoup plus que sur le Fiio M3 qui pour le coup sonnait légèrement mieux à mon goût.
En revanche, l'équalizer est super, et propose beaucoup de préréglages, ainsi qu'une possibilité de customiser le son aux petits oignons.
Si je devais comparer avec le M3, je dirais que le M3 me parait plus musical, sans pour autant que le Hidizs soit désagréable, loin de là, mais pour tout le reste, le Hidizs est loin devant. Peut-être aurait-il pu être plus fin, car la finesse du M3 est un avantage, il se glisse partout. Le AP60 est plus épais (le double d'épaisseur du M3). Leur gabarit hormis cela est identique. Le poids, comme dit précédemment, est supérieur au M3 et de loin.
Cet AP60 ne peut pas être utilisé en lecture lorsqu'il est branché en USB.
Je recommande non de diou ! :)
The Hidizs AP60 comes back in a revised and corrected version, while proposing a new design, compact and refined. With its many features, the AP60...
