Refurbished product - Grade B
Functional product. Broken lower chassis (see last photo).
With the SBooster BOTW P&P ECO MKII regulated linear power supply, purification of the electrical signal begins immediately where the polluted current enters the power supply. The two-stage mains filter and ground choke eliminate high-frequency electrical pollution before the current reaches the transformer. The audio-grade transformer is custom-built and electrostatically and magnetically shielded.
The electronic design of this power supply is innovative: it uses 50% more energy from the components used, and even consumes up to 35% less energy than a conventional design. The BOTW P&P ECO MKII concept is so efficient that it consumes only slightly more energy than a standard adapter, generating more electrical pollution. So your energy bill is only slightly affected by the BOTW P&P ECO MKII.
At the end of the DC jack cable is a unique current-splitting system. The BOTW P&P ECO MKII power supply provides this system with continuous, clean power, so that the electronics can do their job efficiently: first storing the power for greater power supply responsiveness, then filtering the voltage and current one last time before they reach the audio device.
This unique power supply, with its high power reserve, delivers a pure and sufficient electrical signal to the audio device it powers at all times, ensuring stable and continuous performance.
Each model of the BOTW P&P ECO MKII, thanks to its intelligent design, features three output voltage settings. What's more, all models feature an interchangeable, self-locking DC jack connector system. This makes the BOTW P&P ECO MKII an extremely versatile power supply, capable of accompanying a wide range of HiFi equipment.
Key features:
| 1 | IEC C14 power input |
| 2 | Fuse |
| 3 | Polypropylene film capacitor |
| 4 | Common-mode choke |
| 5 | Earth line choke |
| 6 | Overvoltage protector MOV |
| 7 | Silver plated wiring with PTFE insulation |
| 8 | Mains voltage selection switch |
| 9 | Audio grade toroidal transformer |
| 10 | Non-inductive polypropylene capacitor |
| 11 | Low ESR/ESL bulk capacitor |
| 12 | Low drop linear regulator |
| 13 | DC output setting switch |
| 14 | Schottky rectifier |
| 15 | DC cable: Positive/Negative/Shielding |
| 16 | Braided cable |
| 17 | Split-current system |
| 18 | Female DC connector |
| Specifications | |
| Product type | Regulated linear power supply |
| Input voltage | 200-240VAC 50/60Hz |
| Voltage / Current output (switchable) | 18V 2.25A 18.5V 2A 19V 1.75A |
| Transformer | 50VA |
| Mains filter | High-performance two-stage filter with earth choke |
| Rectifiers | Power Schottky barrier rectifiers |
| Capacitors | Low impedance, high ripple current capacitors |
| Regulators | High-current, ultra-fast transient response LDO with high-precision external shunt reference circuit |
| Filtering capacitors | Non-inductive polypropylene film capacitors |
| Jack DC cable length | 95cm |
| Jack DC cable section | 1.309mm² (16AWG) |
| Cable shielding | |
| Current-splitting system on DC cable | |
| Interchangeable Jack DC connectors | |
| Jack DC connectors plating | Gold |
| General | |
| Dimensions | 240*130*75mm |
| Weight | 1.85kg |
| Color | Black |
| Package | 1* SBooster BOTW P&P ECO MKII 1* Power cable Jack DC connectors (various formats) |
| Input | IEC C14 |
| Output | Jack DC |
| Color | Black |
| Output voltage (V) | 18.0 |
| Output voltage (V) | 18.5 |
| Output voltage (V) | 19.0 |
| Output current (A) | 2.2 |
| Input voltage (V) | 240.0 |
| Input voltage (V) | 200.0 |
| Power Supply | Regulated Linear Power Supply |
| Refurbished Grade | Grade B |
