AUDALYTIC HP70 Headphone Amplifier Preamplifier Black
The Audalytic HP70 is a high-end headphone amplifier and preamplifier designed to deliver exceptional sound quality thanks to its fully balanced and discrete architecture. Developed by Audalytic, a Gustard brand specializing in affordable high-end audio solutions, the HP70 is aimed at discerning audiophiles looking for powerful and precise amplification for their headphones or high-quality preamplification.
By buying this product you get 34 loyalty points
Reference : 21310
349,00 €tax incl.
290,83 € tax excl.
Shipping date: 12-11-2026.
Audalytic HP70 Headphone Amplifier Preamplifier Balanced Black
Audalytic HP70
Audalytic HP70: Key features
Audalytic HP70: Amplification and preamplification stage
Audalytic HP70: Fully balanced design and discrete components
The HP70 stands out for its fully balanced and discreet design, using high-quality components such as the LME49720 operational amplifier. This design is based on carefully selected power transistors and discrete components, ensuring linear amplification and minimal distortion. Each stage of the amplifier is optimized to deliver fast response and pure sound reproduction with remarkable dynamics and clarity. The use of discrete components also allows for better audio signal management, reducing artifacts and improving overall fidelity.
Audalytic HP70: Versatility and connectivity
In addition to its role as a headphone amplifier, the HP70 can also serve as a preamplifier, making it compatible with a wide range of audio systems. It is designed to integrate seamlessly into a HiFi system, either in combination with an external DAC or as a standalone component.
Audalytic HP70: Connectivity diagram
1ON/OFF button (standby)
2Display
3Volume knob
4Balanced Jack 4.4mm headphone output
5Single-ended Jack 6.35mm headphone output
6Single-ended RCA input #1 (left channel)
7Single-ended RCA input #2 (left channel)
8Single-ended RCA output (left channel)
9Power input
10Balanced XLR input (right channel)
11Balanced XLR input (left channel)
12Single-ended RCA input #1 (right channel)
13Single-ended RCA input #2 (right channel)
14Single-ended RCA output (right channel)
15Balanced XLR output (right channel)
16Balanced XLR output (left channel)
1715-18V DC external power supply input
18Fuse
Audalytic HP70: Optimized power supply stage
The HP70's power supply stage has been designed to provide stable and clean power, which is essential for optimal audio performance. Thanks to careful design and high-quality components, the power supply minimizes background noise and interference, ensuring uncompromised listening. This stability translates into better instrument separation, a wider soundstage, and more faithful reproduction of details, even in the most complex musical passages.
Audalytic HP70: Power supply circuit
Audalytic HP70: Quality of construction and finish
The Audalytic HP70 features a sturdy, well-crafted design with a sleek, elegant finish. Its metal chassis ensures effective heat dissipation and protection against interference, while its intuitive controls allow for precise adjustment of volume and audio settings.
Product typeHeadphone amplifier / preamplifier
Inputs1x Balanced stereo XLR
2x Single-ended stereo RCA
1x Balanced Jack 4.4mm headphone output
1x Single-ended Jack 6.35mm headphone output
Input sensitivityRCA: Typ 2Vrms / Max 3Vrms
XLR : Typ +15dBu (5V) / Max +18dBu (6V)
Input impedanceRCA: 20kΩ
XLR : 10kΩ
Frequency response20Hz - 40kHz (±0.1dB)
SNRXLR output: 122dB
Headphone output: > 120dB
CrosstalkXLR output: < -120dB @ 1kHz
Headphone output: -118dB @ 1kHz
THD+NXLR output: < 0.0004%
Headphone output: < 0.0005% (1kHz, 1000mW @ 32Ω)
IMDXLR output: < 0.0004%
Headphone output: < 0.0005% (1000mW @ 32Ω)
Headphone output impedanceJack 6.35mm: 0.1Ω
Jack 4.4mm: 0.2Ω
Headphone output power~ 2000mW @ 32Ω, Jack 4.4mm
AlimentationAC 115V / 230V, 50/60Hz
Consumption< 15W
Dimensions (excluding feet and connectors)220 x 170 x 50mm
Weight1.6kg
Package1x Audalytic HP70
1x Power cable
1x Remote
Audalytic HP70: Measurements
InputXLR
OutputJack 6.35mm
OutputJack 4.4mm
ClassClass A / AB
Remote ControlYes
3 reviews
audalytic HP70
The sound is very good, both through the preamp and the headphone output. The remote control is a bit basic, but for the price, it's perfectly acceptable.
This review has been posted for AUDALYTIC HP70 Headphone Amplifier Preamplifier Balanced Black
La bonne affaire
Un super petit préamplificateur silencieux et une bonne sortie casque. Entre mon WiiM et un 3Eaudio A5, il n’apporte que du positif ainsi qu’une sécurité due à son réglage de volume analogique. Bonne finition, manque plus que faire l’essai d’un bon convertisseur (Audalytic ?)
Rapport qualité prix imbattable et inespéré il y a quelques années.
Excellent Preampli
Colis reçu en 24h. Merci Audiophonics
Je ne m’en sers qu'en preampli XLR et RCA
Cet appareil ne semble pas du tout un début de gamme
Le son est excellent et tout fonctionne tres bien y compris la télécommande
Menu très simple aucun besoin de manuel utilisateur.
J'en suis vraiment content.
Très bel appareil a recommander
The Audalytic HP70 is a high-end headphone amplifier and preamplifier designed to deliver exceptional sound quality thanks to its fully balanced...
