Audio-GD SA-31SE Balanced Headphone Amp / RCA / ACSS Preamp
Reference : 8629
575,00 €tax incl.
479,17 € tax excl.
Including 1,00 € for green tax
Evolution of SA-31, the SA-31SE brings the following changes:
  • A gain difference of 10db for the SA-31 at 20db for the SA31SE
  • A new exponential control of the more precise relay volume (14 relays instead of 8)
This new helmet amplifier incorporates all the latest technical developments of the brand, capable of delivering a rare power it will be comfortable to "Driver" the most demanding helmets.
This one because of its extensive connectivity, particularly surprising for a product of this range is compatible with all the analog sources and amplifiers of power of the market.
The 100% discreet design of this amplifier is backed by a high power class A (+/- 35VDC) power supply.
RCA connectors and 6.35 headphones are manufactured by Neutrik.
Qobuz
Test in French
INGREDIENTS
aopdiscrete
STARTERS
RCAStereo x 5
EXITS
XLRBalanced
ACSSStereo
Jack6.35 mm
align = "center"> S / N
117DB (input short)
Gain + 3DB at Low gain, + 20DB at High gain
Frequency Response 20Hz - 20KHz (<0.1DB) 3Hz - 135KHz (- 3DB)
Headphone output power 10000 MW / 40 ohm
8000 MW / 50 ohm
4000 MW / 100 ohm
1400 MW / 300 ohm
700 MW / 600 ohm
Preamplifier output power 20V (High gain) 4V (Low gain)
Headphone amp Output Level (Max, RMS) 22V
Output Impedance 1 ohm
le = "font-size: small;"> Input impedance 47K ohm
Channels cross > 120DB
Channels imbalance <0.05DB
Consumption 29W
Weight 5KG
Dimensions W240 X L360 X H80 (MM, Fully aluminum)
Accessories Power cord X1
Manufacturer:
https://www.audiophonics.fr/images2/6496/6496_AUDIOGDNFB6_1.jpg
https://www.audiophonics.fr/images2/6800/6800_AUDIOGDSA31_1.jpg
https://www.audiophonics.fr/images2/6800/6800_AUDIOGDSA31_2.jpg
https://www.audiophonics.fr/images2/6800/6800_AUDIOGDSA31_3.jpg
https://www.audiophonics.fr/images2/8629/8629_audio-gd_SA-31SE_Ampli_5.jpg
https://www.audiophonics.fr/images2/6496/6496_AUDIOGDNFB6_6
