LITTLE DOT MK9 Tube Headphone Preamplifier / Amplifier
By buying this product you get 72 loyalty points
Reference : 9240
729,00 €tax incl.
607,50 € tax excl.
The Little Dot MK9 is the latest headphone amplifier of the brand.
It uses a Single Ended Push-Pull amplifier in class A based on 6N9P / FSE 6080 tubes.
These tubes are surrounded by quality components to deliver their full tonal richness.
This amplifier can drive headphones from 32 to 600ohm.
RCA outputs can be used as a preamp.
In addition to this, this amp includes an externally accessible gain adjustment to best match the impedance of your headphones.
The MK9 version includes a Neutrik Jack socket, high quality RCA sockets and first choice components at key circuit locations./ P>
Features:/ Strong>
  • SEPP (Single Ended Push Pull) OTL in Class-A
  • Frequency response: 12Hz - 100kHz (-1dB)
  • THD + N: 0.05% (80mW @ 300 ohm)
  • Output Power
    • 300mW @ 300/600 ohm
    • 350mW @ 120 ohm
    • 250mW @ 32 ohm
  • Power Consumption: 80VA
  • Adjustable gain: 3, 4, 5 or 10x
  • Recommended load: 32 to 600ohm
  • Input impedance: 50k ohm
  • Preamp section:
    • Output impedance: 600 ohm
    • Gain: 3 to 10x (linked to amp gain)
    • Voltage: 10V RMS
    • Tubes input and output on preamp output
  • Front tube: 6N9P
  • Rear Tubes: Thompson France FSE 6080 (22V, 65mA)
  • Chassis Aluminum
  • Dimensions: 300x220x150mm
  • Weight: 4kg
  • Warranty 1 year
  • Comes with a 6.3mm to 3.5mm jack adapter, an RCA modulation cable
[Img-8343-left-thickbox_default]
[Img-8345-left-thickbox_default]
