TOPPING A50 III Headphone Amplifier Black
With its A50 III headphone amplifier, Topping unveils a compact, high-performance device. It maintains the features of its predecessor, with improvements such as a 3-level gain control and a balanced input on a 6.35mm TRS jack. Its amplifier circuit incorporates an NCFA (Nested Feedback Composite Amplifier) module for exceptional performance.
Reference : 19016
199,00 €tax incl.
165,83 € tax excl.
Last items in stock !
Shipping date: 22-07-2025.
TOPPING A50 III Headphone Amplifier NFCA Black
TOPPING A50 III picture
With its A50 III headphone amplifier, Topping unveils a compact, high-performance device. It maintains the features of its predecessor, with improvements such as a 3-level gain control and a balanced input on a 6.35mm TRS jack. Its amplifier circuit incorporates an NCFA (Nested Feedback Composite Amplifier) module for exceptional performance. Moreover, the A50 III has a maximum output power of 2x 3500mW, a comfortable reserve that enables it to drive many of the headphones available on the market, including models with up to 300 ohms impedance without difficulty.
TOPPING A50 III highlights
TOPPING A50 III: ultra-high-performance NFCA module
The A50 III incorporates a NFCA (Nested Feedback Composite Amplifier) module with hybrid current/voltage architecture combined with UHGF (Ultra High Gain Feedback) technology. This gives the A50 III excellent AC and DC performance. High output current enables the amplifier to accompany all types of headphones. An ultra-low noise level of 0.3µV, a dynamic range of 144dB and the absence of background noise also enable the A50 III to power the most sensitive IEMs with ease.
Photo of the NFCA module on the TOPPING A50 III
TOPPING A50 III: high output power
The A50 III's output power enables it to drive headphones with impedances ranging from 32 ohm to 300 ohm. In fact, it can deliver up to 2x 3500mW of power @ 32 ohm and up to 2x 760mW of power @ 300 ohm, all with a THD < 0.01%.
TOPPING A50 III output power
Photo of TOPPING A50 III with headphones
TOPPING A50 III: 2 headphone outputs and 3 gain levels
The A50 III features two headphone outputs, one on a 6.35mm jack and one balanced on a 4.4mm jack. A knob on the front panel selects the 3-level gain setting for the headphone outputs.
TOPPING A50 III: essential connectors
The rear panel of the A50 III features an RCA input and a balanced stereo input on a 6.35mm TRS connector. Added to this is a 12V trigger enabling it to be paired with other devices for simultaneous ignition. Its connectivity makes it the perfect ally for Topping's D50 III DAC.
Photo of TOPPING A50 III coupled with another device
TOPPING A50 III: a robust aluminum chassis
The A50 III features a CNC-machined aluminum chassis for aesthetic appeal and durability. This aluminum casing also helps dissipate the heat efficiently from the A50 III's amplifier stage.
Black and silver versions of TOPPING A50 III
Topping A50 III overview
TOPPING A50 III connector diagram
1Switch-on / gain selection
2Gain LED indicator
36.35mm jack headphone output
44.4mm jack headphone output
5Volume control knob
6Balanced 6.35mm stereo jack input
7Stereo RCA input
8Source selection switch
9Software update port
1012V Trigger
1115V DC power supply
Inputs1x Stereo RCA input
1x Balanced input on 6.35mm TRS jack connector
Outputs1x 6.35mm headphone output
1x 4.4mm headphone jack output
A50 III HEADPHONE AMPLIFIER MEASUREMENTS
RCA / Jack 6.35mmBAL TRS 6.35mm / jack 6.35mmRCA / Jack 4.4mmBAL TRS 6.35mm / Jack 4.4mm
THD+N @ 1kHz A-wt<0.00006% @ 500mw 32 ohm
<0.00006% @ 80mw 300 ohm
<0.00007% @ 500mw 32 ohm
<0.00007% @ 2000mw 32 ohm
<0.00006% @ 320mw 300 ohm
<0.00012% @ 2000mw 32 ohm
<0.00008% @ 320mw 300 ohm
THD+N @ 20Hz-20kHz 90kBW<0.0002% @ 500mw 32 ohm
<0.0001% @ 80mw 300 ohm
<0.0005% @ 500mw 32 ohm
<0.0003% @ 80mw 300 ohm
<0.0002% @ 2000mw 32 ohm
<0.0001% @ 320mw 300 ohm
<0.0001% @ 2000mw 32 ohm
<0.0002% @ 320mw 300 ohm
SNR @ Max out 1kHz A-wt141dB136dB144dB137dB
Dynamic range @ 1kHz A-wt141dB136dB144dB137dB
Frequency response20Hz-40kHz (±0.05dB)
10Hz-100kHz (±0.1dB)
20Hz-40kHz (±0.1dB)
10Hz-100kHz (±0.05dB)
20Hz-40kHz (±0.1dB)
Output level21Vpp @G=L
21Vpp @G=M
21Vpp @G=H
21Vpp @G=L
21Vpp @G=M
21Vpp @G=H
18Vpp @G=L
42Vpp @G=M
42Vpp @G=H
18Vpp @G=L
42Vpp @G=M
42Vpp @G=H
Output noise A-wt(Mesures AP)< 0.7uVrms @G=L
< 0.7uVrms @G=M
< 1.2uVrms @G=H
< 0.7uVrms @G=L
< 0.7uVrms @G=M
< 1.1uVrms @G=H
< 0.9uVrms @G=L
< 0.9uVrms @G=M
< 2.1uVrms @G=H
< 0.9uVrms @G=L
< 0.9uVrms @G=M
< 2.1uVrms @G=H
Output noise A-wt< 0.3uVrms @G=L
< 0.3uVrms @G=M
< 1.0uVrms @G=H
< 0.3uVrms @G=L
< 0.3uVrms @G=M
< 1.0uVrms @G=H
< 0.7uVrms @G=L
< 0.7uVrms @G=M
< 2.0uVrms @G=H
< 0.7uVrms @G=L
< 0.7uVrms @G=M
< 2.0uVrms @G=H
Input sensitivity13Vrms @G=L
8.0Vrms @G=M
1.9Vrms @G=H
9.2Vrms @G=L
8.0Vrms @G=M
1.9Vrms @G=H
13Vrms @G=L
7.8Vrms @G=M
1.9Vrms @G=H
9.2Vrms @G=L
7.8Vrms @G=M
1.9Vrms @G=H
Gain-12.0dB @G=L
0dB @G=M
11.9dB @G=H
-12.0dB @G=L
0dB @G=M
11.7dB @G=H
-6.0dB @G=L
6.0dB @G=M
17.9dB @G=H
-6.0dB @G=L
6.0dB @G=M
17.9dB @G=H
Output impedance< 0.1Ω< 0.1Ω< 0.2Ω< 0.2Ω
Input impedance10.0kΩ @G=L
2.5kΩ @G=M
2.5kΩ @G=H
2.0kΩ @G=L
2.0kΩ @G=M
2.0kΩ @G=H
10.0kΩ @G=L
2.5kΩ @G=M
2.5kΩ @G=H
2.0kΩ @G=L
2.0kΩ @G=M
2.0kΩ @G=H
Output power2150mW x2 @ 16Ω THD+N<0.1%
1400mW x2 @ 32Ω THD+N<0.1%
190mW x2 @ 300Ω THD+N<0.1%
100mW x2 @ 600Ω THD+N<0.1%
3500mW x2 @ 16Ω THD+N<0.1%
2700mW x2 @ 32Ω THD+N<0.1%
760mW x2 @ 300Ω THD+N<0.1%
395mW x2 @ 600Ω THD+N<0.1%
Load impedance> 8Ω
Power supply15V DC
Dimensions125 x 140 x 260mm
Package1x Topping A50 III
1x Power supply adapter
1x 3.5mm jack to 6.35mm jack adapter
InputJack 6.35mm
OutputJack 4.4mm
OutputJack 6.35mm
ClassN/A
With its A50 III headphone amplifier, Topping unveils a compact, high-performance device. It maintains the features of its predecessor, with...
