TOPPING L30 II NFCA Headphone Amplifier Preamplifier Black
Topping unveils its L30 II, evolution of the very good L30 headphone amplifier and preamplifier. This new version is based on the architecture of the first model, while bringing many improvements to optimize the performance of the device and its sound reproduction.
Reference : 16715
149,00 €tax incl.
124,17 € tax excl.
Shipping date: 20-05-2026.
Topping L30 II
Topping L30 II Amplificateur casque NFCA Préamplificateur Noir
Differences between L30 II and L30
L30 II
L30
Amplifier
Optimized NFCA module
NFCA
THD+N
< 0.00006%
< 0.00007%
Dynamic range
144dB
141dB
Output power @ 300 Ohm
2x 560mW
2x 280mW
Gain
-14dB / 0dB / 16.5dB
-9.9dB / 0dB / 9.5dB
Output voltage
37Vpp
26Vpp
Improved NFCA
The Topping L30 II uses a revised NFCA (Nested Feedback Composite Amplifier) amplifier module. This one allows notably to double the output power available under 300Ω, compared to the L30. An output power offering the possibility to the L30 II to accompany the vast majority of headphones on the market, including the most demanding models with a high impedance. The new circuit also offers an ultra-low noise level measured at 0.3µV, a dynamic page of 144dB as well as a THD+N of 0.00006%.
Gain setting
In order to allow the L30 II to accompany both high-impedance headphones and very sensitive in-ear monitors, the amplifier offers a three-level gain control: -14dB, 0dB and 16.5dB.
1Output selector
2Gain selector
3Power indicator
4Jack 6.35mm headphone output
5Volume button
6Right channel RCA input
7Left channel RCA input
8Right channel RCA output
9Left channel RCA output
10Power connector
Product typeHeadphone amplifier and preamplifier
Amplification moduleNFCA
Input1x Stereo RCA
Outputs1x Stereo RCA
1x Jack 6.35mm headphone outout
Headphone amplifier measurements
THD+N @ 1kHz, A-Weighting< 0.00006% @ 500mW, 32Ω
< 0.00005% @ 80mW, 300Ω
THD @ 90kBw, 20Hz-20kHz< 0.00008% @ 500mW, 32Ω
< 0.00007% @ 80mW, 300Ω
SNR @ Max Out, 1kHz, A-Weighting144dB
Dynamic range @ 1kHz, A-Weighting144dB
Frequency response20Hz-40kHz (±0.05dB)
Output level14Vpp @ G=L
31Vpp @ G=M
37Vpp @ G=H
Noise level< 0.3µVrms @ G=L
< 0.3µVrms @ G=M
< 1.4µVrms @ G=H
Crosstalk @ 1kHz-92dB
Input sensitivity25Vrms @ G=L
11.2Vrms @ G=M
2.0Vrms @ G=H
Gain-14dB @ G=L
0dB @ G=M
16.5dB @ G=H
Output impedance< 0.1Ω
Output power2x3500mW @ 16Ω, THD+N < 0.1%
2x2700mW @ 32Ω, THD+N < 0.1%
2x2000mW @ 64Ω, THD+N < 0.1%
2x560mW @ 300Ω, THD+N < 0.1%
Load impedance> 8Ω
Preamplifier measurements
THD @ 90kBw, 20Hz-20kHz< 0.00007%
Dynamic range@ 1kHz, A-Weighting144dB
31Vpp @ G=M
37Vpp @ G=H
< 0.3µVrms @ G=M
< 1.4µVrms @ G=H
11.2Vrms @ G=M
2.0Vrms @ G=H
Gain-14dB @ G=L
0dB @ G=M
16.5dB @ G=H
Output impedance20Ω
Dimensions100 x 135 x 32mm
Package1x Topping L30 II
1x Power adapter
1x Male Jack 6.35mm to Female Jack 3.5mm adapter
OutputJack 6.35mm
2 reviews
Excellent rapport qualité prix
Je l'utilise en ce moment comme préamplificateur, avec un ampli Rega mira dont je me sert comme simple ampli; comment dire , je suis subjugué par sa transparence quelque soit le niveau sonore, le fruité des timbre et relief stéréo; du coup je squeeze le préamplificateur du Rega. beaucoup moins bon.. Et sans aucune manipulation autre que l'actionnement de la clé sur la face avant, je l'utilise comme amplificateur de casque ( AKG, Sennheiser, Bose ). Ecoute de musique symphonique, vocale, musique de chambre etc. Bravo.
This review has been posted for TOPPING L30 II NFCA Headphone Amplifier Preamplifier Black
Une merveille
De tous les amplis casque que j'ai possédé (de 100 à 1500 e) , c'est mon préféré sans hésitation.
Utilisé la plupart du temps avec dac Micromega Mydac et casque Shure srh 840 (44 ohms).
Transparence totale,aucune distorsion, mais sans froideur.
Il ne rajoute rien, n’enlève rien, parfaitement fidèle à la source (qui a donc toute son importance).
Aucune dureté, c'est fluide,spontané, la musique vit.
Le grave, dégraissé et restitué avec de l'impact, descend bas, de manière ultra rapide et articulée.
Il est allumé tous les jours, c'est un signe qui ne trompe pas !
Topping unveils its L30 II, evolution of the very good L30 headphone amplifier and preamplifier. This new version is based on the architecture of...
