I’m surprised by the performance of this hybrid tube amp. Simple and powerful enough to drive my HE1000SE headphones. Would certainly recommend for any newbie tube enthusiasts
Headphone Amplifier 4x 6J1 Tubes Transistors Class A Balanced
The MT-604 from xDuoo is a headphone amplifier based on the use of 4 6J1 tubes to deliver a soft and warm sound. These tubes are associated with transistors for the Class A buffer, allowing to have a comfortable output power to accompany a great majority of the headphones of the market. This design allows to take advantage of both technologies: the musicality of the tubes and the great dynamics and precision of the transistors, while developing a power of 2000mW. The power supply stage is filtered with Rubycon filtering capacitors.
The amplifier also benefits from a balanced connection. We find stereo XLR and 4.4mm jack on the input and 4 pole XLR and 4.4mm jack on the output.
The MT-604 also offers an independent volume control for each channel. This function allows a better separation of the channels.
Product type | Tube headphone amplifier |
Inputs | 1x Balanced stereo XLR 1x Balanced Jack 4.4mm |
Outputs | 1x Balanced 4 poles XLR headphone output 1x Balanced Jack 4.4mm headphone output |
Output power | 2000mW @ 1kHz, 32Ω |
Dynamic range | 85dBA @ 32Ω |
Frequency response | 10Hz~60kHz (±0.5dB) |
Recommended headphone impedance | 16Ω ~ 600Ω |
Gain | +15dB |
SNR | 115dB |
THD+N | ≤ 0.01% @ 1kHz, 32Ω |
Dimensions | 170x100x60mm |
Weight | 550g |
Input | Jack 4.4mm |
Input | XLR |
Output | Jack 4.4mm |
Output | XLR |
Color | Gray |
Class | Tube amp |
Class | Class A / AB |
Remote Control | No |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Nnanna E.
