XDUOO TA-22 Tube Headphone Amplifier 2x 12AU7 DAC 2x ES9038Q2M Bluetooth 5.0 aptX HD LDAC 32bit 384kHz DSD256 MQA
xDuoo unveils with its TA-22 a beautiful headphone amplifier and DAC combo with a neat design. This one embeds quality components in order to provide a sound restitution both musical and detailed. It also offers a complete connectivity to meet the vast majority of needs, as well as a convenient Bluetooth connectivity.
By buying this product you get 56 loyalty points
Reference : 17032
569,00 €tax incl.
474,17 € tax excl.
Shipping date: 09-09-2025.
xDuoo TA-22
xDuoo TA-22 Amplificateur Casque à Tubes 2x 12AU7 DAC 2x ES9038Q2M Bluetooth 5.0 aptX HD LDAC 32bit 384kHz DSD256 MQA
A powerful hybrid amplifier
Using a pair of 12AU7 tubes and a Class A transistor buffer, the TA-22 is capable of developing a power of 3000mW in balanced output and 1500mW in single-ended output, offering a soft and warm sound reproduction, characteristic of this type of amplification. It is thus able to drive both high sensitivity headphones and high impedance headphones while ensuring a beautiful musicality.
A high performance DAC
The TA-22's converter stage features a balanced architecture with two ES9038Q2M chips, ensuring high precision and clarity, perfectly complementing the tube amplifier system. These chips also allow the TA-22 to support high-resolution audio streams, up to 32bit 384kHz PCM and DSD256, as well as to render MQA files. The conversion circuitry is also equipped with a pair of low phase noise oscillators to provide a clean clock signal to minimize jitter.
Bluetooth 5.0
In addition to a complete connectivity, the TA-22 offers a Bluetooth 5.0 reception thanks to its Qualcomm 5125 chip, so it is possible to broadcast and control your music remotely, from a smartphone or a tablet for example. This receiver supports aptX HD and LDAC codecs for high quality wireless playback.
Pre-Out output
The TA-22 also provides a stereo RCA pre-out. It is thus possible to connect an amplifier or active speakers in order to take advantage of the sound signature of the TA-22 tubes.
Product typeTube headphone amplifier and DAC
Tubes2* 12AU7
DAC chip2* ES9038Q2M
S/PDIF interfaceAK4118
InputsBluetooth 5.0
1* USB-B
1* Coaxial
1* Optical Toslink
1* Balanced stereo XLR
1* Balanced Jack 4.4mm
1* Stereo RCA
Outputs2* Stereo RCA
1* Balanced Jack 4.4mm headphone output
1* Balanced XLR 4 pins headphone output
1* Single-ended Jack 3.5mm headphone output
ScreenOLED 3.12"
USB compatibilityWindows
Mac OS
Linux
Android
iOS
Supported sampling ratesUSB : PCM up to 32bit 384kHz, Native DSD up to DSD256, MQA up to 384kHz
Optical / Coaxial : PCM up to 24bit 384kHz, DSD DoP up to DSD128
Supported Bluetooth codecsSBC, AAC, aptX, aptX LL, aptX HD, LDAC
Single-ended headphone output parameters
Output power1500mW @ 32Ω
Frequency response20Hz~60kHz (±0.5dB)
THD+N≤ 0.02%
SNR113dB
Crosstalk≥ 70dB
Balanced headphone output parameters
Output power3000mW @ 32Ω
THD+N≤ 1%
SNR118dB
Crosstalk≥ 96dB
AUX output parameters
Output level2Vrms
Frequency response20Hz~20kHz (±0.5dB)
THD+N0.001%
SNR113dB
Crosstalk≥ 113dB
Dimensions (W*D*H)260*190*70mm
Weight3kg
ColorGray
Power cableIncluded
InputJack 4.4mm
InputXLR
OutputJack 3.5mm
OutputJack 4.4mm
DAC / ADC ChipES9038Q2M
Max sampling rate384kHz
Max sampling rateMQA
Max sampling rateDSD256
ColorGray
ClassTube amp
ClassClass A / AB
4 reviews
perfect xduoo ta-22
neutral sound with very good stock tubes, rolled nos RFT 12au7 from 1960 east germany made. more relaxed sound with more extended highs.
This review has been posted for XDUOO TA-22 Tube Headphone Amplifier 2x 12AU7 DAC 2x ES9038Q2M Bluetooth 5.0 aptX HD LDAC 32bit 384kHz DSD256 MQA
très bon son
j'avais oubliés les 5 etoiles .
 (3)
très bon son
je l'ai acheter pour sa sortie tubes , car mon ampli rotel manquait de matière dans les medium sur les voix , problème résolu avec ce préampli très bien fini . Et comme toujours depuis plusieurs années un très bon service de la part de toute l'équipe audiophonics. Compter toujours un rodage plus ou moins 100heures , attention quand un appareil ne fonctionne pas pendant quelques jours il faut refaire un petit rodage de quelques heures surtout en hiver.
 (4)
Perfect
Beautiful, well-finished device, numerous connection possibilities and top-notch features.
Getting started is very easy. I had a little problem with mine unit because voltage switch at the back was placed at 110V instead of 220V when arrived. I didn't pay attention and burned the fuse.
After week of listening impressions are great. Mine Audeze LCD-2 sounded like never before. I can only compare this amp with Unison Research SH sound wise, but Unison lacks power to drive LCD-2 properly.
With this device max volume I needed (on most quiet recordings) was 45 out of 100.
I am pretty sure reviews that will come out will point that this device does not have perfect measurements and I can tell you, I don't care. I didn't by this amp to read charts and numbers but to listen to music.
It sounds great with stock tubes. In a couple of months I will probably replace them with other tubes (something like PSVANE 12AU7-S which you can buy at Audiophonics) , which will probably sound even better.
I am more than satisfied with this purchase, which I can recommend.
 (3)
xDuoo unveils with its TA-22 a beautiful headphone amplifier and DAC combo with a neat design. This one embeds quality components in order to...
