AUNE X7S 2021 EDITION Headphone Class A amplifier Variable Out Balanced Black
The pure class A Aune X7S headphone amplifier with balanced output is the result of a long search after the nomadic headphone amplifier Aune B1 and the Aune Panda. It is the natural companion of the DAC Aune X1S 32bit 384Khz DSD SABRE ES9018K2M. This headphone amp entirely in class A is the synthesis of all the know-how of Aune Audio.
By buying this product you get 25 loyalty points
Reference : 15097
259,00 €tax incl.
215,83 € tax excl.
Aune X7S 2021 Edition
Headphone amplifier Class A Variable output / Balanced Black
Aune X7S 2021 Edition Amplificateur Casque Class A Sortie Variable / Symétrique Noir
2021 Edition
Le X7s, pour cette édition 2021, voit son circuit audio légèrement amélioré, avec notamment l'arrivé d'un nouveau transformateur et de condensateurs plus performants. Ces modifications viennent participer à offrir une meilleure restitution sonore.
The pure class A Aune X7S headphone amplifier with balanced output is the result of a long search after the nomadic headphone amplifier Aune B1 and the Aune Panda. It is the natural companion of the DAC Aune X1S 32bit 384Khz DSD SABRE ES9018K2M. This headphone amp entirely in class A is the synthesis of all the know-how of Aune Audio. It is specially designed for high-end high impedance headphones such as: Sennheiser HD650, IE800, HD800, Beyerdynamic (Tesla) T1, DT880, AKG K701, K240.
Its gain stage, which can be configured by "switch", allows a perfect impedance matching for both low and high impedance headphones. Its structure is based on 8 Class A polarized transistors divided into 4 groups designed with a true symmetrical stage for cross talk and remote, inaudible background noise. The European sound of the Aune X7S developed by an English team has body, a deep sound image with increased natural musical tracking, a true sound signature of headphones amplifiers in class A. The separate 15 V regulated low noise power supply provides the stability necessary for the Aune X7S to operate properly in class A. By its unique design the Aune X7S will be an ideal companion for the dematerialized digital player Aune X5.
Review and measurements by Audio Science Review
The Audio Science Review forum offers a particularly complete test of the Aune X7s with in particular precise measurements of the different parameters of the device.
ClassA
Frequency response20Hz-200kHz @ -0.3dB
Noise level3µV
THD0.00013%
Inter-modulation distortion (CCIF protocol)RCA : 0.000036%
XLR 0.00057%
Output powerRCA : 250mW @ 300 Ohm / 1000mW @ 32 Ohm
XLR : 1000mW @ 300 Ohm / 1700mW @ 32 Ohm
SNRJack 6.35mm : 117dB
XLR : 125dB
Input1x Stereo RCA
Outputs1x Variable Stereo RCA
1x Jack 6.35mm
1x XLR 4 poles balanced
Dimensions145 x 171 x 45mm
Weight2kg
OutputJack 6.35mm
ClassClass A / AB
The pure class A Aune X7S headphone amplifier with balanced output is the result of a long search after the nomadic headphone amplifier Aune B1 and...
