ADC CS5343 / DAC CS4344 I2S 24bit / 192kHz
Reference : 14326
46,90 €tax incl.
39,08 € tax excl.
Shipping date: 13-06-2025.
Module ADC / DAC
ADC CS5343 / CS4344 DAC of I2S
Here is a very compact module with ADC & DAC I2S function .
The ADC stage operates using a CS5343 chip multi-bit A-Z modulator and an LME49721 operational amplifier (digital filter and high pass filter embedded).
It is suitable for all compact applications involving quality sound aquisition with its dynamic range of 98dB and its Signal / Noise ratio of -92dB.
ADC can be reached simply thanks tp a 3.5mm stereo jack connector which is already installed & soldered on the PCB. The only thing to do is it to connect a microphone and connect the I2S port on a standard I2S format read device to operate.
The DAC stage uses a 24-bit CS4344 chip with a maximum sampling rate of 192 kHz and high performanceoperational amplifier LA4811.
This stage managed to offer a dynamic range  of105dB with a signal / noise ratio of -90dB. DAC can be reached via the I2S connector and meets standard I2S format.
Note that it also hase a pin dedicated to volume (+ 12dB / -33dB & mute) if the connected device has a driver that supports this type of application.
The decoded audio stream is available for immediate use on a 3.5mm stereo jack connector which is already installed on the PCB.
A third 3.5mm stereo connector labeled "LINEIN" can bypass both ADC & DAC stages and facilitate connections.
Diagram & Pinout
Pinout
# PinName Description
1VCCPMOD 3.3V
2GNDPMOD GND
3SDOUTI2S ADC Data output
4SCLKI2S DAC ADC Clock
5LRCK1I2S ADC clock left and right channel
6MCLKI2S DAC ADC modulation clock
7SDINI2S DAC data input
8LRCK2I2S DAC clock left and right channel
9UDVolume control
10CLKHorloge contrôle de volume
TypeModule ADC / DAC
DACCS4344 24-bit 192kHz
ADCCS5343 24-bit 4-108kHz
DynamicADC: 98dB
DAC: 105dB
SNRADC: -92dB
DAC: -90dB
InputsAnalog 3.5mm jack - Line
Analog 3.5mm jack - Mic
Digital on pin 2.54mm - I2S input
OutputAnalog 3.5mm jack - Headphone output
Digital on pin 2.54mm - I2S output
Dimension42.93 x 24.13 x 1.6mm
Weight8g
InputI2S
InputJack 3.5mm
OutputJack 3.5mm
DAC / ADC ChipCS4344
Max sampling rate192kHz
ColorN/A
