Audio-GD Compass 2 2014 DAC / Headphone Amplifier / Preamp 32bit / 384KHz WM8741 X2
This reissue of the Compass comes back in a version featuring the new USB interface of the brand (USB32) and two converter WM8741.
This very versatile device (DAC, Headphone Amplifier and Preamplifier), has many inputs (USB, Coax, Toslink and Line in) to be comfortable in all configurations.
The brand's engineers have designed this device to ensure its scalability (it is possible to change at will the USB interface, the converter or discrete Aop).
Its ultra-modern DAC allows you to manage 32 bit 384Khz sources directly via USB and SPDIF inputs. P>
The 100% discreet design of this amplifier is backed by a high power power supply.
24k Gold Plated RCAs and Nover (UK) capacitors have been specially manufactured on Audio-Gd specifications.
Features:/ Strong>
P>
| Signal / noise ratio |
| Output Level |
| Output Power (Headphones). |
| Gain | 12DB at H gain |
| Output impedance Strong> | 2ohm / Headphone output |
| Input sensitivity |
| Frequency Response |
| USB Compatibility Strong> | Windows: 44.1kHz to 192kHz music files OSX: 44.1kHz to 384KHz music files Linux: 44.1kHz to 192kHz music files |
| Supported sampling rates | USB mode1: 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz Coaxial model: 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz Optical model: 44.1kHz, 48kHz, 88.2kHz, 96kHz (176.4KHz and 192KHz available if the source support) |
| Consumption | 220-240V AC 50/60 Hz 20W |
| Weight | 5KG |
| Accessories | AC power cord X1 USB cable X1 Optical cable X1 |
P>
P>
P>
P>
P>
P>
P>
P>
P>
P>
P>
P>
