DENAFRIPS ARES 15TH Balanced R2R DAC Silver
To celebrate its 15 years of expertise, Denafrips presents the Ares 15TH, a high-performance, balanced NOS R2R DAC. The digital/analog conversion stage is made up of no fewer than 480 carefully selected precision resistors, and is combined with an Altera FPGA.
By buying this product you get 147 loyalty points
Reference : 19544
1 475,00 €tax incl.
1 229,17 € tax excl.
Shipping date: 02-06-2026.
Denafrips Ares 12TH-1 Balanced R2R DAC 24bit 1536kHz DSD1024 Silver
Denafrips Ares 15th: front view
To celebrate its 15 years of expertise, Denafrips presents the Ares 15TH, a high-performance, balanced NOS R2R DAC. The digital/analog conversion stage is made up of no fewer than 480 carefully selected precision resistors, and is combined with an Altera FPGA. The power supply stage of the Ares 15TH is no exception, featuring a large 60VA O-core transformer with UP-OCC copper windings, eight LDO regulators and numerous high-performance capacitors. This ensemble enables the Denafrips Ares 15TH to deliver sound reproduction of incredible precision, clarity and richness.
Key features:
  • Proprietary DSD + R2R architecture
  •  True balanced 24bit R2R + 6bit DSD circuits (32-step FIR filters)
  • Low thermal effect, hand-matched 0.01% high-precision resistors
  • Femtosecond oscillators 45.1548MHz and 49.152MHz
Denafrips Ares 12TH-1: Internal view
Denafrips Ares 15TH: A sober, elegant chassis
The Ares 15TH's circuitry is housed in a sturdy, elegant anodized aluminum chassis. Its compactness makes for easy integration.
Denafrips Ares 12TH-1: Aluminum chassis
Denafrips Hades 15TH : Connectique
Le Denafrips Ares 15TH profite d'une connectique complète. On y retrouve en entrée de l'USB-B associé à une interface STM32, de l'I2S via HDMI, de l'optique Toslink et du coaxial. Côté sortie on pourra compter sur du RCA stéréo asymétrique et du XLR stéréo symétrique.
Denarfips Ares 12TH-1: Connectors
1Balanced XLR output
2Single-ended RCA output
3Coaxial input
4Toslink optical input
5I2S input (HDMI)
6USB-B input
7Power connector
Product typeBalanced NOS R2R DAC
Inputs1x USB-B
1x I2S via HDMI
1x Coaxial
1x Optical Toslink
Outputs1x Balanced stereo XLR
1x Single-ended stereo RCA
Supported sampling ratesUSB : PCM up to 1536kHz, DSD up to DSD1024
I2S / Optical / Coaxial : PCM up to 24bit 192kHz, DSD DoP up to DSD64
Output level / impedanceRCA : 2Vrms @ 625Ω
XLR : 4Vrms @ 1250Ω
Sampling modesNon-oversampling (NOS)
Oversampling (OS)
FiltersSlow
Sharp
Frequency response20Hz - 70kHz -3dB
THD+N0.004%
SNR115dB
Dynamic range> 119dB
Crosstalk-124dB
Supply voltage100-240VAC 50/60Hz
Consumption≤ 20W
ColorSilver
Dimensions215 x 230 x 45mm
Weight3.5kg
Package1x Denafrips Ares 15TH
InputI2S via HDMI
DAC / ADC ChipR2R LADDER DAC
Max sampling rate1536kHz
Max sampling rateDSD1024
ColorSilver
Remote ControlN/A
DENAFRIPS ARES 15TH Balanced R2R DAC 24bit 1536kHz DSD1024 Silver
To celebrate its 15 years of expertise, Denafrips presents the Ares 15TH, a high-performance, balanced NOS R2R DAC. The digital/analog conversion...
