SOMMERCABLE CONTROL FLEX I2S transfert Cable 4x0.25mm² Ø 4.7mm
Reference : 9655
1,60 €tax incl.
1,33 € tax excl.
Shipping date: 24-09-2026.
Trust is good, but "Control" is better ...
We supply a robust but very flexible cable for use as a control and signaling conductor for automation devices (eg RS232 or RS422) or computer systems in the milliampere zone. The special envelope is anti-flammable and self-extinguishing according to VDE 0472, part 804, mode B.
The CONTROL FLEX is protected by copper braid shielding (optical coverage> 90%), which makes it particularly suitable for problematic use of EMV.
Please note that we produce this cable for wholesale traders and for OEM customers, and that it is - at least in part - printed with the names prescribed by the DIN standard or other approvals, without the SOMMER CABLE logo.
ADVANTAGES :
  • Seven different sections available from our warehouses
  • Mobile, flexible up to a temperature of -10 ° C (fixed installation down to -30 ° C)
  • Practically resistant to oils
  • Self-extinguishing and anti-inflammableaccording to VDE 0472, part 804, mode B
  • Easy to work
USE :
  • Fixed installation of the building
  • Signal and automation driver
  • Retransmission of RS232 and RS422 standards
  • Loudspeaker cable in ELA technique
Specifications:
ConstitutionLIY-CY
Envelope, diameter4.70 mm
Conductor inside4 x 0.25 mm2
Copper strands per coreaccording to DIN VDE 0295 mm
Insulation of the conductorPVC / FRNC according to DIN VDE0207 part 4
Protectioncopper braid, tinned
Optical cover90%
Operating temperatureFixed installations min. -30 ° C
Operating temperaturemobile min. -20 ° C
Operating temperatureFixed installations max. 80 ° C
Operating temperatureMobile phone 70 ° C
Color of envelopegray (RAL 7001)
Packaging, packaging unitroller 100/1000 m
Electrical Specifications :
Capacity metric cond./cond.120 pF
Metric Capacity Screen / Display240 pF
Odometer Resistance, Conductor<165 Ohm
Resistance, insulation> 20 MOhm
Inductance per 1 km0.65 MHz
Operating voltage500 V
Operating voltage
Operating voltage
Test voltagefor 50 Hz (Cond./Cond.) 1200 V
Test voltagefor 50 Hz (monitor / display) 800 V
Diameter (mm)4.7
Length (m)Sold by length
Number of conductors4
Insulation materialPVC
ShieldingYes
Section (mm²)0.25
Ground / ShieldingYes
