CANARE L-5CFB High performance Digital cable 75 Ohm shielded Ø7.7mm
Designed and manufactured in Japan by the famous CANARE company, this 75 Ohm L-5CFB high quality coaxial cable was originally dedicated to the professional broadcast market.
Reference : 10456
2,70 €tax incl.
2,25 € tax excl.
Shipping date: 11-09-2026.
Canare L-5CFB
75 Ohm Coaxial Cable Shielded High Performance Ø 7.7mm
Canare L-5CFB Câble Coaxial 75 Ohm Blindé Haute Performance Ø 7.7mm
Designed and manufactured in Japan by the famous CANARE company, this 75 Ohm L-5CFB high quality coaxial cable was originally dedicated to the professional broadcast market. Its notoriety is no longer to be made and the cables of the firm did not take long to penetrate the market of the Hi-Fi.
It has high quality mechanical and electrical characteristics and is one of the 75 ohm coaxial cables with an extremely low loss rate. This cable is designed to work with the CANARE RCAP-C5F 75 Ohm RCA crimp connector.
Câble Canare L-5CFB
Example of cable mounted with connector on RCA connector. The RCA connector is sold separately.
It is necessary to use a professional crimping tool to mount the cable.
Measurements and comparisons
Product type75 Ohm Coaxial cable
ConductorSolid copper
Section / Diameter18 AWG / 1.05mm
InsulationPE 4.9mm
Shielding100% Aluminium foil
Braided Copper and Aluminium
Dielectric resistance1000V AC/1min
Rating impedance75 Ohm
Rating capacity55 pF/m @ 1kHz
Propagation speed79%
Total cable diameter7.7mm
QuantitySold per meter
Diameter (mm)7.7
Length (m)Sold by length
Number of conductors2
Insulation materialPE
ShieldingYes
Section (mm²)1.05
Ground / ShieldingYes
3 reviews
Meilleur cable sub
L’un des meilleurs, Cable, subwoofer qu’il m’a été donné d’essayer, il a détrôné sans forcer des Cable de 20 fois son prix
Je mets sur mes deux caissons
This review has been posted for CANARE L-5CFB High performance Digital cable 75 Ohm shielded Ø7.7mm
Enfin un très bon Cable coaxial
Je ne comprends pas pourquoi les grandes marques continuent à faire des Cables, hors de prix pour les liaisons 75. Ohm
Aussi bon sur mes caissons en longue distance que pour faire une liaison numérique d’excellente qualité
Je ne peux que conseiller ce Cable, il n’y aura jamais mieux à ce prix
équivaut et
Même meilleurs qun cables à 400 € que j’avais avant
Top pour caisson de basse
Je l’ai acheter pour remplacer un câble atlas pour une liaison lfe entre mon subwoofer svs4000 et mon ampli hc denon
Et bien le résulta est parfait
Les impact sont percutant à souhait les basses ne bave pas
Il est top et pour un prix raisonnable il remplacera largement des modèle de 10fois ce prix voir plus
Designed and manufactured in Japan by the famous CANARE company, this 75 Ohm L-5CFB high quality coaxial cable was originally dedicated to the...
