CANARE L-5DFB 50 Ohm Coaxial Cable
New
This professional-quality Canare L-5DFB coaxial cable has an impedance of 50Ω. It features a 2.082mm² (14AWG) copper center conductor and a double shield of aluminum foil and tin-plated copper braid. The whole assembly is covered by a black PVC sheath.
Reference : 20960
3,50 €tax incl.
2,92 € tax excl.
Câble vendu au mètre
Canare L-5DFB 50 Ohm Coaxial Cable Copper 2.082mm² Ø7.6mm
Canare L-5DFB
Product typeCoaxial cable
Outer diameterØ7.6mm
Weight8.5kg/100m
Conductor materialCopper
Conductor section2.082mm² (14AWG)
Conductor diameterØ1.8mm
Insulation diameterØ5mm
Shielding materialAluminum foil
Tinned copper braid
Conductor resistance0.7Ω/100m
Shielding resistance1.1Ω/100m
Static capacity84pF/m
Impedance50Ω
Attenuation2.5dB/100m (10MHz)
Outer sheath materialPVC
LengthSold by the metre
CANARE L-5DFB 50 Ohm Coaxial Cable Copper 2.082mm² Ø7.6mm
This professional-quality Canare L-5DFB coaxial cable has an impedance of 50Ω. It features a 2.082mm² (14AWG) copper center...
