AUDIOPHONICS DIGIRESCUE Reclocker SPDIF Optical Coaxial Galvanic Insulation 24bit 192kHz
This Audiophonics DIGIRescue reclocker interface has been designed in association with Ian Canada. Using a high-precision local clock and Ian Canada's discrete reclocking technology, it perfectly resynchronizes S/PDIF signals to achieve very low jitter. The result is a sound reproduction of an incredible clarity and precision.
Reference : 18113
149,00 €tax incl.
124,17 € tax excl.
Shipping date: 20-05-2026.
AUDIOPHONICS DIGIRESCUE Reclocker SPDIF Module Optical Coaxial Galvanic Insulation 24bit 192kHz
This Audiophonics DIGIRescue reclocker interface has been designed in association with Ian Canada. Using a high-precision local clock and Ian Canada's discrete reclocking technology, it perfectly resynchronizes S/PDIF signals to achieve very low jitter. The result is a sound reproduction of an incredible clarity and precision. It features both optical Toslink and coaxial input and output connections, supporting sampling rates up to 192kHz. It also supports Dolby Digital and DTS audio formats. An automatic signal detection function automatically locks the active input, with status LEDs indicating the latter.
Most consumer devices, such as TV sets, set-top boxes or consoles, but also many audio devices such as DACs or CD players, can feature SPDIF outputs. However, these can suffer from poor signal transmission quality due to high jitter. The Audiophonics DIGIRescue, with its high-precision clock and circuitry, resynchronizes the signals to ensure optimum, error-free transmission quality and clear sound reproduction.
This interface benefits from a meticulously optimized overall architecture, based on high-end components. With its high-performance power supply filtering networks (organic polymer/MLCC capacitors totaling 1500µF) and ultra-low-noise LDO, the Audiophonics DIGIRescue is capable of delivering a clean, stable electrical signal to all its circuits. Optical and coaxial inputs and outputs benefit from galvanic isolation to protect the signal from unwanted interference.
In addition to its reclocker and isolator functions, the DigiRescue can also be used as an optical Toslink to coaxial converter and vice versa.
In short, the Audiophonics DIGIRescue acts as reclocker, galvanic isolator and EMI/RFI filter, performing each of these tasks effectively.
Key features:
  • Reclocks S/PDIF signals using a local audio clock with very low jitter.
  • Improves S/PDIF signal quality or corrects poor-quality S/PDIF signals while isolating them.
  • Two inputs: Coaxial and Optical Toslink.
  • Two outputs: Coaxial and Optical Toslink.
  • Standard 5VDC power supply via USB-C.
  • Automatic detection and selection of input signals.
  • Supports sampling rates up to 24bit 192kHz.
  • Two bi-color LEDs indicate the selected input signal and the S/PDIF signal lock status.
Using the Audiophonics DIGIRescue
  1. Connect a 5VDC power supply to the interface via its USB-C connector (J4). Status LED D3 lights up green. The Coaxial input is selected by default.
  2. Connect a DAC to either the coaxial output (J3) or the optical output (U6).
  3. Connect an audio source to either the interface's coaxial input (J1) or optical input (U5).
When using the interface's coaxial input, when a valid digital audio signal is locked, the color of LED D3 changes to blue. The DAC connected to the DIGIRescue will then receive the audio signal received by the interface on its coaxial input.
When using the interface's optical input, if a signal is detected, the optical input is automatically selected. LED D2 then lights up. When a valid digital audio signal is latched, the color of LED D2 changes to blue. The DAC connected to the DIGIRescue will then receive the audio signal on its optical input.
U5Optical Toslink input
J1Coaxial input
U6Optical Toslink output
J4USB-C 5VDC power supply input
J3Coaxial output
D2Optical Toslink input status LED
D3Coaxial input status LED
LED indicators
  1. D3: Coaxial input status LED (J1)
    • Green: Coaxial input is selected as input.
    • Blue: Digital signal locked.
    • Off: Not selected.
  2. D2: Optical Toslink input status LED (U5)
    • Green: Optical input is selected as input.
Product typeReclocker
EMI/RFI filter
Galvanic isolator
Supported sampling ratesPCM up to 24bit 192kHz
Inputs1* Coaxial (RCA)
1* Optical Toslink
Outputs1* Coaxial (RCA)
1* Optical Toslink
Automatic input signal detection
Local clock jitter1ps RMS
SPDIF reclocking jitter20ps RMS
Supported audio formatsPCM 24bit / 192kHz
Dolby Digital
DTS
Supply voltage5VDC via USB-C
Total dimensions96.5*48*20mm
Chassis dimensions70*48*20mm
Weight80g
Package1x Reclocker SPDIF Optique Coaxial Isolation Galvanic AUDIOPHONICS DIGIRESCUE
1x USB-A to USB-C power cable with switch
OutputCoaxial SPDIF
OutputOptical Toslink
Max sampling rate192kHz
Interface chipNC
12 reviews
Erg goed
Mijn coax uitgang van de Oppo UDP 203 Vanity welke DoP 64 uitstuurt is aanzienlijk verbeterd in helderheid diepte stilte en dynamiek.
Echt een aanrader.
Gevoed met een IFi 5v voeding
This review has been posted for AUDIOPHONICS DIGIRESCUE Reclocker SPDIF Optical Coaxial Galvanic Insulation 24bit 192kHz
Very good product
I use it between a Samsung QN95D 65" TV and LD Systems Dave 15 G4X to improve the toslink signal. Clarity, contour, punch, speech and so on is greatly improved. For such a setup it is a no brainer.
Petit reclocker qui fait bien son job
Je voulais améliorer la qualité de mon transport cd Cambridge CXC. C’est chose faite.
The change in sound blew me away
The change in sound blew me away!
I connected the reclocker between my internet radio and the DAC via Toslink (optical cable). What happened next was incredible. I had a three-dimensional sound image. Only now did I realise that without the reclocker, I had only been hearing in two dimensions. I highly recommend the reclocker!
DIGIRESCUE Reclocker Isolation Galvanique de haute volée
1èrement : fait super bien ce pourquoi il est fait.
je ne rentrerai pas dans des chiffres (je n'ai pas en l'état les outils pour) mais parlerai du contexte et du ressentit (à l'écoute).
Sources reliées :
Un tuner DAB synpathique (Sangean WFT-4) cependant avec une sortie SPDIF pas au top.
Une TV avec sortie optique classique.
DAC en reception : TOPPING DX7 PRO upgradé Sparkos labs.
Alimentation du Digirescue : Ifi Ipower X
Résultats Immédiatement perceptibles : précision, profondeur, respect timing, impact, image tridimentionnelle, silence entre les notes, présence indéniable.
Bref hautrement reccommandé pour mettre à niveau des sources SPDIF moyennes avec en plus le bonus isolation galvanique entre appareils respecté (un vrai plus quand on pousse l'optimisation).
Merci Audiophonics pour ce beau et bon produit crée en partenariat avec IAN Canada
This Audiophonics DIGIRescue reclocker interface has been designed in association with Ian Canada. Using a high-precision local clock and...
