Currently running a wiim pro plus into Klipsch 'The sevens'. The digirescue made an amazing difference to the clarity. My wife even asked what I had done to the stereo! Highly recommended
This Audiophonics DIGIRescue reclocker interface has been designed in association with Ian Canada. Using a high-precision local clock and Ian Canada's discrete reclocking technology, it perfectly resynchronizes S/PDIF signals to achieve very low jitter. The result is a sound reproduction of an incredible clarity and precision. It features both optical Toslink and coaxial input and output connections, supporting sampling rates up to 192kHz. It also supports Dolby Digital and DTS audio formats. An automatic signal detection function automatically locks the active input, with status LEDs indicating the latter.
Most consumer devices, such as TV sets, set-top boxes or consoles, but also many audio devices such as DACs or CD players, can feature SPDIF outputs. However, these can suffer from poor signal transmission quality due to high jitter. The Audiophonics DIGIRescue, with its high-precision clock and circuitry, resynchronizes the signals to ensure optimum, error-free transmission quality and clear sound reproduction.
This interface benefits from a meticulously optimized overall architecture, based on high-end components. With its high-performance power supply filtering networks (organic polymer/MLCC capacitors totaling 1500µF) and ultra-low-noise LDO, the Audiophonics DIGIRescue is capable of delivering a clean, stable electrical signal to all its circuits. Optical and coaxial inputs and outputs benefit from galvanic isolation to protect the signal from unwanted interference.
In addition to its reclocker and isolator functions, the DigiRescue can also be used as an optical Toslink to coaxial converter and vice versa.
In short, the Audiophonics DIGIRescue acts as reclocker, galvanic isolator and EMI/RFI filter, performing each of these tasks effectively.
Key features:
When using the interface's coaxial input, when a valid digital audio signal is locked, the color of LED D3 changes to blue. The DAC connected to the DIGIRescue will then receive the audio signal received by the interface on its coaxial input.
When using the interface's optical input, if a signal is detected, the optical input is automatically selected. LED D2 then lights up. When a valid digital audio signal is latched, the color of LED D2 changes to blue. The DAC connected to the DIGIRescue will then receive the audio signal on its optical input.
U5 | Optical Toslink input |
J1 | Coaxial input |
U6 | Optical Toslink output |
J4 | USB-C 5VDC power supply input |
J3 | Coaxial output |
D2 | Optical Toslink input status LED |
D3 | Coaxial input status LED |
Product type | Reclocker EMI/RFI filter Galvanic isolator |
Supported sampling rates | PCM up to 24bit 192kHz |
Inputs | 1* Coaxial (RCA) 1* Optical Toslink |
Outputs | 1* Coaxial (RCA) 1* Optical Toslink |
Automatic input signal detection | |
Local clock jitter | 1ps RMS |
SPDIF reclocking jitter | 20ps RMS |
Supported audio formats | PCM 24bit / 192kHz Dolby Digital DTS |
Supply voltage | 5VDC via USB-C |
Total dimensions | 96.5*48*20mm |
Chassis dimensions | 70*48*20mm |
Weight | 80g |
Package | 1x Reclocker SPDIF Optique Coaxial Isolation Galvanic AUDIOPHONICS DIGIRESCUE 1x USB-A to USB-C power cable with switch |
Input | Optical |
Input | SPDIF |
Output | Coaxial SPDIF |
Output | Optical Toslink |
Max sampling rate | 192kHz |
Color | Black |
Interface chip | NC |
Average votes 5.0 / 5 5 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Paul J.
David S.
Robert v.
Alain S.
Francis K.
