DOUK AUDIO U2PRO Digital Reclocker Interface
The Douk Audio U2 PRO is a USB digital interface with reclocker function designed to convert and regenerate a USB audio signal in order to feed a DAC, amplifier, or AV receiver with a clean, stable, and low-jitter digital stream. Based on an asynchronous USB interface using the XMOS XU316 chip, the U2 PRO supports high-resolution audio streams up to PCM 32bit / 768kHz as well as native DSD512 via its HDMI I2S output. It also allows conversion of a USB signal from a PC, Mac, smartphone, or Raspberry Pi to coaxial S/PDIF and optical Toslink digital outputs supporting up to PCM 24bit / 192kHz as well as DoP DSD64.
Reference : 21953
64,90 €tax incl.
54,08 € tax excl.
Shipping date: 01-12-2026.
Douk Audio U2PRO XMOS XU316 USB-C to HDMI I2S/Toslink/Coaxial Digital Reclocker Interface PCM 32bit 768kHz DSD512
Photo of the DOUK AUDIO U2PRO
Compatible with Windows 10 / 11, macOS, Android, iOS, PS5, and Nintendo Switch systems, it features a UAC 1.0 / UAC 2.0 switch allowing operation to be adapted depending on usage. UAC 1.0 mode ensures driverless plug & play compatibility with consoles and compatible devices (PS5, Nintendo Switch), while UAC 2.0 mode provides access to advanced high-resolution audio streams.
The U2 PRO also benefits from an audiophile-oriented design with an extremely low typical jitter of only 75ps as well as a THD+N of 0.000008%, ensuring particularly clean and accurate digital transmission. It integrates PCM / DSD indicator lights allowing real-time identification of the audio format currently being played. Powered directly by 5V DC via USB-C, the U2 PRO adopts a compact format of 85 x 79 x 26 mm for a weight of 220g, and comes supplied with a USB-C to USB-A/C cable ensuring immediate compatibility with a wide variety of digital audio sources.
Overview of the Douk Audio U2PRO
Overview of the DOUK AUDIO U2PRO
1Sampling rate indicator
2USB-C input
3HDMI I2S output
4Optical Toslink output
5Coaxial SPDIF output
6HDMI pin definition
7UAC 1.0/2.0 switch
Technical specifications
Product typeDigital Interface
Reclocker
USB interfaceXMOS XU316
Input1x USB-C
Outputs1x HDMI I2S
1x Optical Toslink
1x Coaxial
Supported sampling ratesOptical Toslink/Coaxial SPDIF: 24bit 192kHz, DSD DoP64
I2S via HDMI: 32bit 768kHz, DSD DoP256, DSD512
UAC compatibilityUAC 1.0/UAC 2.0
Compatible OSW10/W11/Mac OS/Android/iOS/PS5/Switch
Jitter75ps
THD+N0.000008%
Power supply5V DC
Dimensions85x79x26mm
Weight220g
Package1x U2 PRO digital interface
1x Optical Toslink cable
1x USB-C to USB-A/USB-C cable
OutputOptical Toslink
OutputCoaxial SPDIF
OutputI2S LVDS via HDMI
Max sampling rate768kHz
Max sampling rateDSD512
Interface chipXMOS XU316
2 reviews
Correction sur mon avis à propos du Douk Audio
Je viens de donner un avis sur le douk audio et comme de bien entendu, j'y ai glissé une coquille.
Dans la phrase du premier commentaire " J’ai alors branché le Douk Audio dont le physique me paraît plus attrayant sur la prise USB de mon premier PC Daphile. Puis j’ai décidé de faire sortir le flux par la prise i2S du smsl qui se trouve compatible (format PS Audio des deux produits et de l’audio GD). Depuis lors, plus aucune coupure pénible du flux audio."
Il ne s'agit évidemment pas de la prise i2s du smsl, cela ne présenterait vraiment aucun intérêt, mais il s'agit de la sortie i2s hdmi du Douk Audio qui est donc ensuite branchée sur l'entrée i2s hdmi de mon dac audioGD D77 dont la puce usb amanero faisait parfois du mauvais travail avec daphile.
Voilà.
Et c'est un excellent produit dans l'absolu et mirobolant pour le prix.
This review has been posted for DOUK AUDIO U2PRO Digital Reclocker Interface XMOS XU316 USB-C to HDMI I2S/Toslink/Coaxial 32bit 768kHz DSD512
Pareil que le smsl PO100 pro mais j'adore les 2
Un petit commentaire commun à deux produits achetés en même temps en pensant renvoyer celui qui ne me conviendrait pas.
Un smsl PO100 pro et un Douk Audio U2 pro.
En résumé, même puce usb Xmos XU316, même jitter, même taux d’échantillonnage, même prix (à peu près). Enfin bref, ce sont les mêmes produits sous des packaging différents.
Et concernant la sonorité (enfin les apports sonores), honnêtement, je n’ai pas perçu de différences entre les produits. Par contre, j’ai quand même l’impression que le son qui sort des mes enceintes est un peu plus ample (en vrai, on s’en fiche, objectivisme contre subjectivisme – pas de débats)
Mon idée était d’améliorer l’entrée USB d’un dac audio GD D77 (première version) qui utilise une interface usb amanéro. Et cette dernière ne fait pas toujours bon ménage avec mes PC utilisés comme serveur réseau pour Qobuz par le biais de l’excellentissime DAPHILE (linux, gratuit et paramétrable de ouf).
En effet, l’audio GD perdait très régulièrement le son et je devais alors, soit éteindre et rallumer le Dac ou bien le déconnecter puis le reconnecter de la prise usb du PC.
Ça a fini par m’agacer.
Sur les conseils avisés de Mr AUBERT, j’ai acheté le smsl PO100 pro et sur mes propres conseils un peu moins avisés, j’ai acheté le Douk Audio. Mais ce n’est pas très grave comme les lecteurs curieux pourront le constater à la fin.
J’ai alors branché le Douk Audio dont le physique me paraît plus attrayant sur la prise USB de mon premier PC Daphile. Puis j’ai décidé de faire sortir le flux par la prise i2S du smsl qui se trouve compatible (format PS Audio des deux produits et de l’audio GD). Depuis lors, plus aucune coupure pénible du flux audio. Donc, voilà une bonne chose.
Je m’apprêtais alors à renvoyer le smsl mais du coup, je me suis dit, branche le donc sur ton second pc daphile branché lui aussi en usb mais sur un fda Fx Audio D2160 II. Celui ci perdait aussi parfois le son mais différemment (en fait, il perdait la connexion réseau) alors je ne peux pas affirmer que l’ajout du smsl PO100 pro est la cause de l’amélioration de la stabilité de la lecture sur le FDA. Dans le cas du FDA, j’ai branché la sortie coax du smsl. Et franchement, depuis lors et malgré de nombreuses écoutes, plus de coupures réseau ni de son.
Donc, en conclusion, je garde les deux interfaces USB, et je suis fort satisfait des deux. Ensuite, en résumé, ce sont deux produits qui apportent un réel plus pour des systèmes dont les sorties USB peuvent être capricieuses, ce qui est souvent le cas des PC anciens utilisés comme lecteur réseau.
J’adore.
The Douk Audio U2 PRO is a USB digital interface with reclocker function designed to convert and regenerate a USB audio signal in order to feed a...
