IFI AUDIO LAN ISILENCER Isolator Filter Ethernet RJ45
The iFi Audio LAN iSilencer is an RJ45 Ethernet isolator filter to reduce interference, noise and distortion. It is basically intended to improve the transfer quality of your network data. The digital signals therefore become purer, which can be beneficial when using HiFI devices, a television or even a streamer for example.
4.4 / 5
Reference : 17692
89,00 €tax incl.
74,17 € tax excl.
Shipping date: 09-09-2025.
IFI AUDIO LAN ISILENCER Filtre isolateur Ethernet RJ45
Key points :
  1. Ethernet filter
  2. Cancellation of noise and interference
  3. Jitter reduction
  4. Gigabit Ethernet
Use exemples
Ethernet filter
This isolator filter avoids any interference, background noise or loss of data that could be problematic on your hi-fi equipment such as connected amplifiers or streamers. You will therefore gain in detail, precision and transparency of sound reproduction.
For this, the iSilencer uses a jitter-free buffer memory and a galvanically isolated input to avoid any risk of distortion. The circuits are also fully separated to avoid interactions and block ground potential differences.
Access Ethernet Gigabit
The iFi Audio LAN iSilencer can be inserted directly into any RJ45 inputs or outputs of an RJ45 switch. It can therefore provide Gigabit Ethernet network support without speed restrictions to any connected equipment. Its shielded housing with integrated earth blocks external interference (RFI), minimizes packet loss and provides a stable signal.
Product typeEthernet RJ45 isolator filter
Input1* RJ45 (1000/100/10Mbps)
Output1* RJ45 (1000/100/10Mbps)
Dimensions73*19*16mm
Weight17g
InputRJ45
OutputRJ45
Max sampling rateNC
Interface chipNC
14 reviews
Efficace
Utilisé entre une livebox Orange et mon streamer Lumin T2, il fait son petit effet. On ressent une progression de la netteté sonore et une mise en place spatiale plus précise, avec plus d'aération. L'effet est plus important s'il est placé en sortie de la box plutôt qu'à l'entrée du streamer chez moi.
This review has been posted for IFI AUDIO LAN ISILENCER Isolator Filter Ethernet RJ45
Amélioration du son
Branché en entrée de mon Eversolo, j'ai tout de suite noté un son mieux installé, plus propre.
Par contre, j'avais initialement acheté ce filtre pour éviter des coupures de son en streaming (fibre, rj-45 de la box au streamer, mais beaucoup de domotique)
Cela n'a pas été concluant et les coupures sont restées.
Depuis, le problème de coupures a disparu. Pourquoi ? je l'ignore (mise à jour logiciel, sans doute, mais lequel ? voire lesquels ???)
Très bon complément
Mis en sortie de mon routeur, c'est un très bon complément de l'IFI AUDIO iLAN purifier Pro, placé à l'entrée de mon streamer. Aucune réserve.
Surprenant
Je reviens sur l'avis que j'avais laissé en spécifiant que ce filtre n'e m'avait pas apporté de différence. Je l'ai finalement connecté directement en sortie de routeur et non directement sur le streamer et effectivement après plusieurs essais avec et sans, le avec l'emporte largement, j'ai l'impression d'un son plus analogique, ce qui est paradoxal pour un flux numérique, quoi qu'il en soit il fait le job et retire ce que j'ai écris préalablement.
Should be like must
I purcese it with DC purifier and work for me just great. I sould do this before. Recommendet.
The iFi Audio LAN iSilencer is an RJ45 Ethernet isolator filter to reduce interference, noise and distortion. It is basically intended to improve...
