SILKLINE SPDIFMAX MKII USB XMOS XU308 to SPDIF 32bit / 192kHz Asynchronous Interface
Silkline's SPFIDMAX MKII is an asynchronous USB / SPDIF interface featuring quality components such as an XMOS XU308 chip. This digital interface supports 32bit / 192kHz PCM via its USB-B 2.0 port. It uses digital filtering technology before retransmitting the signal to its outputs (Toslink and Coaxial) to improve the input signal and limit interference.
Reference : 17853
89,90 €tax incl.
74,92 € tax excl.
Shipping date: 01-05-2025.
USB XMOS XU308 to SPDIF 32bit / 192kHz Asynchronous interface
SILKLINE SPDIFMAX MKII USB XMOS XU208 to SPDIF 32bit / 192kHz Asynchronous interface
XMOS XU308 USB input interface
The SPDIFMAX MKII uses one of the best USB interfaces on the market, an XMOS XU308. The XMOS is an 8-core processor working with FGPA capable of processing a digital signal at a speed of 1000 MIPS in real time, and decoding up to 32bit / 192kHz PCM. This interface is compatible with the ASIO driver and therefore with a wide range of devices.
Dual high-precision clocks
These high-precision clocks considerably reduce jitter and make the digital signal more stable
American AOS power supply chip
A high-end power supply chip reduces electromagnetic interference (EMI/RFI) and incorporates a dual voltage regulation system to ensure a clean power supply system.
SILKLINE-developed X-DRIVE circuit and digital filtering technology
SilkLine has designed the SPDIFMAX MKII to increase the range of the coaxial output signal by a factor of 4. The effective transmission distance of the coaxial signal reaches over 10 meters.
Digital filter technology also enables the USB/SPDIF interface to smooth out pulse peaks, filter out first-order harmonics and guarantee a clean signal.
The Toslink output and the gold-plated coaxial output are completely independent and isolated, reducing the noise that can come from the source device.
Product typeUSB to SPDIF Digital interface
InputUSB-B 2.0
Outputs1x Optical Toslink
1x Coaxial SPDIF
USB InterfaceXOMOS XU308
USB Driver compatibilityASIO
Input supported sample ratesPCM 32bit / 192kHz (Dolby/DTS compatible)
Output sample ratesPCM 24bit / 192kHz
CompatibilityWindows XP 7/8/10 (32/64 bit)
Mac OSX 10.6.4 and above
Linux
Android
IOS 13.3.4 and above
Output signal transmission distance> 10 meters
Dimensions91 x 20 x 50 mm
ColorSilver
Net weight120g
Gross weight200g
Package1x SilkLine SPDIFMAX
OutputOptical Toslink
OutputCoaxial SPDIF
Max sampling rate192kHz
ColorSilver
Interface chipXMOS XU208
3 reviews
Excellent produit qui me permet de relier un ancien DAC AUDIOMAT dépourvu d’entrée USB depuis la sortie d’un McBookPro.
Je conseille cette interface.
This review has been posted for SILKLINE SPDIFMAX MKII USB XMOS XU308 to SPDIF 32bit / 192kHz Asynchronous Interface
Très bon produit
Branché en lieu et place de l’entrée usb sur un Audio GD nfb 3, le son est excellent, beaucoup de détails.
Convient très bien à des câbles résolutifs, Nordost heimdall pour ma part.
Très satisfait de cet achat.
Stéphane
Rapport musicalité/prix excellent
Je l'ai acheté pour équiper un ancien dac sans entrée USB. J'ai été tout de suite surpris par les résultats. La musique est très dynamique, la réponse en fréquence étendue et la résolution est excellente.
Les résultats ont été tellement bon que j'ai voulu l'essayer sur mon dac Audio-GD NOS. Et là les résultats ont été au-dessus de mes espérances. On retrouve les mêmes résultats que sur mon ancien dac mais tout en mieux. L'écoute est très nettement supérieure à l'entrée usb Amanero de l'Audio-gd. Au point que maintenant le Silkline est branché en permanence dessus. Vraisemblablement, le FGPA permet d'atteindre un niveau d'écoute excellent pour un prix raisonnable.
Autre chose, ce n'est pas parce que l'appareil n'est pas cher, qu'il ne faut pas soigné l'installation. Il est très sensible au câble usb. Donc ne pas hésiter à en mettre un bon. Pour ma part j'ai obtenu un très bon résultat avec le Neotech cuivre-argent. J'ai aussi mis une alimentation externe. L'apport est moins sensible que pour le câble mais il y a encore un mieux.
Autre chose. J'ai dû renvoyer le premier appareil qui a lâché au bout d'une semaine. Par contre je n'ai pas eu de problème avec le second. La prise USB semble toutefois bien fragile. Il faut bien qu'il y ait un défaut vu le prix raisonnable.
 (3)
Silkline's SPFIDMAX MKII is an asynchronous USB / SPDIF interface featuring quality components such as...
