SILKLINE SPDIFMAX MKII USB XMOS XU308 to SPDIF 32bit / 192kHz Asynchronous Interface
Silkline's SPFIDMAX MKII is an asynchronous USB / SPDIF interface featuring quality components such as an XMOS XU308 chip. This digital interface supports 32bit / 192kHz PCM via its USB-B 2.0 port. It uses digital filtering technology before retransmitting the signal to its outputs (Toslink and Coaxial) to improve the input signal and limit interference.
Reference : 17853
89,90 €tax incl.
74,92 € tax excl.
USB XMOS XU308 to SPDIF 32bit / 192kHz Asynchronous interface
SILKLINE SPDIFMAX MKII USB XMOS XU208 to SPDIF 32bit / 192kHz Asynchronous interface
XMOS XU308 USB input interface
The SPDIFMAX MKII uses one of the best USB interfaces on the market, an XMOS XU308. The XMOS is an 8-core processor working with FGPA capable of processing a digital signal at a speed of 1000 MIPS in real time, and decoding up to 32bit / 192kHz PCM. This interface is compatible with the ASIO driver and therefore with a wide range of devices.
Dual high-precision clocks
These high-precision clocks considerably reduce jitter and make the digital signal more stable
American AOS power supply chip
A high-end power supply chip reduces electromagnetic interference (EMI/RFI) and incorporates a dual voltage regulation system to ensure a clean power supply system.
SILKLINE-developed X-DRIVE circuit and digital filtering technology
SilkLine has designed the SPDIFMAX MKII to increase the range of the coaxial output signal by a factor of 4. The effective transmission distance of the coaxial signal reaches over 10 meters.
Digital filter technology also enables the USB/SPDIF interface to smooth out pulse peaks, filter out first-order harmonics and guarantee a clean signal.
The Toslink output and the gold-plated coaxial output are completely independent and isolated, reducing the noise that can come from the source device.
Product typeUSB to SPDIF Digital interface
InputUSB-B 2.0
Outputs1x Optical Toslink
1x Coaxial SPDIF
USB InterfaceXOMOS XU308
USB Driver compatibilityASIO
Input supported sample ratesPCM 32bit / 192kHz (Dolby/DTS compatible)
Output sample ratesPCM 24bit / 192kHz
CompatibilityWindows XP 7/8/10 (32/64 bit)
Mac OSX 10.6.4 and above
Linux
Android
IOS 13.3.4 and above
Output signal transmission distance> 10 meters
Dimensions91 x 20 x 50 mm
ColorSilver
Net weight120g
Gross weight200g
Package1x SilkLine SPDIFMAX
OutputCoaxial SPDIF
OutputOptical Toslink
Max sampling rate192kHz
ColorSilver
Interface chipXMOS XU208
7 reviews
Excellent filtrage
Donne une belle musique en sortie de PC, naturelle
et vivante.
Attention toutefois à ne pas lésiner sur les câbles d'entrée
et de sortie pour tirer le meilleur parti du Silkline.
This review has been posted for SILKLINE SPDIFMAX MKII USB XMOS XU308 to SPDIF 32bit / 192kHz Asynchronous Interface
Excellent filtrage
Interface qui restitue une musique bien plus naturelle en sortie
de PC pour alimenter au mieux un convertisseur, à un tarif
très raisonnable.
Attention toutefois à l'accompagner d'un câblage à la hauteur,
aussi bien en entrée qu'en sortie, pour en profiter pleinement.
Je l'avais acheté pour la compatibilité ASIO (rare sur ce type d'appareil). Mais il ne fonctionne pas à 192kHz en TOSLINK: il y a des coupures fréquentes du signal, qui rendent le son inaudible. J'ai donc conservé mon ancien interface USB qui fonctionne sans problème.
Perfect working with RPI 4 & Hypex Plateamp
SeeTitle
Excellent produit qui me permet de relier un ancien DAC AUDIOMAT dépourvu d’entrée USB depuis la sortie d’un McBookPro.
Je conseille cette interface.
Silkline's SPFIDMAX MKII is an asynchronous USB / SPDIF interface featuring quality components such as...
