SMSL PO100 PRO USB Interface XMOS XU316 I2S SPDIF 32bit 768kHz DSD512 MQA
The SMSL PO100 PRO presents itself as an extremely powerful and incredibly compact USB interface. Despite its small size, the PO100 PRO is based on an architecture using high quality components to ensure a faithful and precise sound reproduction. It also offers a complete connectivity to answer most of the connection needs, with USB-C as input and coaxial, optical and I2S via HDMI as output.
4.9 / 5
Reference : 17036
68,91 €tax incl.
57,42 € tax excl.
Shipping date: 19-11-2026.
SMSL PO100 PRO
SMSL PO100 PRO Interface USB XMOS XU316 I2S SPDIF 32bit 768kHz DSD512 MQA
SMSL PO100AK Interface USB XMOS XU316 I2S SPDIF 32bit 768kHz DSD512 MQA
XMOS XU316 USB Interface
The USB-C input of the PO100 PRO is associated with a third generation XMOS XU316 high-end USB interface. This one, in addition to allowing a transparent sound reproduction, ensures the support of high resolution audio streams up to PCM 32bit 768kHz and DSD512.
MQA Decoder
The SMSL PO100 PRO is able to decode MQA (Master Quality Authenticated) audio files. These files allow to enjoy a sound as close as possible to the original studio recording.
I2S & UAC Modes
The SMSL PO100 PRO provides two UAC modes and two I2S modes. These modes allow to maximize the compatibility of the interface with other devices. The UAC modes can be useful when used with a console such as PS5 or Nintendo Switch, while the I2S modes can correct compatibility issues in a HiFI installation.
Technical characteristics
Product typeUSB Interface
USB Interface chipXMOS XU316
Input1* USB-C
Outputs1* I2S via HDMI
1* Coaxial
1* Optical Toslink
USB Transmission modeAsynchronous
USB CompatibilityWindows 7/8/8.1/10/11
Mac OSX 10.6 or later
Linux
Android
iOS
THD+N (No-Weighting)0.000008% (141.7dB)
Supported sampling ratesI2S : PCM up to 32bit 768kHz, Native DSD up to DSD512
Optical / Coaxial : PCM up to 24bit 192kHz, DSD DoP up to DSD64
Jitter75ps
Supply voltage5V 200mA via USB-C
Dimensions (L*P*H)80*60*13mm
Weight75g
Shell materialAluminum
Package1x SMSL PO100 PRO
1x USB-A to USB-C cable
OutputOptical Toslink
OutputCoaxial SPDIF
OutputI2S LVDS via HDMI
Max sampling rateDSD512
Max sampling rateMQA
Max sampling rate768kHz
15 reviews
Perfect
This little box solved the problem of Wiim Ultra not having a usb-input (except for external storage). Usb from PC into the P0100 Pro and optical from there to Wiim Ultra. Bit perfect conversion, small, started to work instantly.
This review has been posted for SMSL PO100 PRO USB Interface XMOS XU316 I2S SPDIF 32bit 768kHz DSD512 MQA
SMSL PO100 pro et DOUK AUDIO U2 pro, même combat. J'adore les 2
Un petit commentaire commun à deux produits achetés en même temps en pensant renvoyer celui qui ne me conviendrait pas.
Un smsl PO100 pro et un Douk Audio U2 pro.
En résumé, même puce usb Xmos XU316, même jitter, même taux d’échantillonnage, même prix (à peu près). Enfin bref, ce sont les mêmes produits sous des packaging différents.
Et concernant la sonorité (enfin les apports sonores), honnêtement, je n’ai pas perçu de différences entre les produits. Par contre, j’ai quand même l’impression que le son qui sort des mes enceintes est un peu plus ample (en vrai, on s’en fiche, objectivisme contre subjectivisme – pas de débats)
Mon idée était d’améliorer l’entrée USB d’un dac audio GD D77 (première version) qui utilise une interface usb amanéro. Et cette dernière ne fait pas toujours bon ménage avec mes PC utilisés comme serveur réseau pour Qobuz par le biais de l’excellentissime DAPHILE (linux, gratuit et paramétrable de ouf).
En effet, l’audio GD perdait très régulièrement le son et je devais alors, soit éteindre et rallumer le Dac ou bien le déconnecter puis le reconnecter de la prise usb du PC.
Ça a fini par m’agacer.
Sur les conseils avisés de Mr AUBERT, j’ai acheté le smsl PO100 pro et sur mes propres conseils un peu moins avisés, j’ai acheté le Douk Audio. Mais ce n’est pas très grave comme les lecteurs curieux pourront le constater à la fin.
J’ai alors branché le Douk Audio dont le physique me paraît plus attrayant sur la prise USB de mon premier PC Daphile. Puis j’ai décidé de faire sortir le flux par la prise i2S du smsl qui se trouve compatible (format PS Audio des deux produits et de l’audio GD). Depuis lors, plus aucune coupure pénible du flux audio. Donc, voilà une bonne chose.
Je m’apprêtais alors à renvoyer le smsl mais du coup, je me suis dit, branche le donc sur ton second pc daphile branché lui aussi en usb mais sur un fda Fx Audio D2160 II. Celui ci perdait aussi parfois le son mais différemment (en fait, il perdait la connexion réseau) alors je ne peux pas affirmer que l’ajout du smsl PO100 pro est la cause de l’amélioration de la stabilité de la lecture sur le FDA. Dans le cas du FDA, j’ai branché la sortie coax du smsl. Et franchement, depuis lors et malgré de nombreuses écoutes, plus de coupures réseau ni de son.
Donc, en conclusion, je garde les deux interfaces USB, et je suis fort satisfait des deux. Ensuite, en résumé, ce sont deux produits qui apportent un réel plus pour des systèmes dont les sorties USB peuvent être capricieuses, ce qui est souvent le cas des PC anciens utilisés comme lecteur réseau.
J’adore.
Connect it with ifi zen streamer
It improved the sound of ifi zen streamer
A positive addition to my system
I am listening music by connecting a laptop to a USB Dac through a good but lengthy (5m) USB interconnect cable. The connection is asychronous, so in theory, adding a recloaker shouldn't make any difference.
The problem I was facing, was the appearance of a very noisy ground loop; I could only listen to music when the laptop was disconnected from its power supply and was relying only on its internal battery.
I solved that problem with the help of the SMSL gadget and a toshlink interconnect. As for the sound, I can discern a subtle but noticable improvement. Not a night and day difference, but the sound appears "fresher" and with a somehow larger soundstage. If the SMSL could be combined with an external power supply, the sound could be even better - but it only gets powered by the USB interconnect. In that price point, I believe that the company should provide the first option.
That said, the SMSL has been a positive addition to my system. Reclockers do work, even in a subtle way. Does it worth the cost? This is subjective. Not every system needs one, but when it's needed, I believe that the SMSL PO100 PRO won't dissapoint.
Improving sound quality
Huge improvement in sound quality: detail, separation, spacing. The price/performance ratio is amazing.
The SMSL PO100 PRO presents itself as an extremely powerful and incredibly compact USB interface. Despite its small size, the PO100 PRO is based on...
