Topping Professional unveils a portable USB audio interface offering a wide range of uses. High-performance, it offers 88dB microphone gain, 118dB DNR in ADC and 122dB in DAC, as well as up to 2x 500mW into 32 ohms of headphone output power. It also offers a range of features such as AI noise reduction, an equalizer, auto gain, ducking, and even reverb. The M62 interface has three operating modes: mobile mode, book stream mode, and pro audio mode. In terms of connectivity, it is well equipped with two USB-C ports, including one OTG, three microphone inputs, a 3.5mm AUX jack input, and a 3.5mm headphone jack output. Added to this is Bluetooth functionality with support for aptX Low Latency and aptX HD high-definition codecs. The whole thing is powered by a 5000mAh battery offering up to 8.5 hours of battery life.
The M62 audio interface is compatible with most operating systems, including Android, iOS, Windows, and macOS. The ASIO driver supports up to 24bit 96kHz PCM, enabling high-resolution recording. It also provides up to 16 recording tracks. Whether for vocal or instrumental recording, the M62 allows you to record or stream live in a professional way.
Thanks to its superior analog circuit design, the M62 allows its DAC and ADC chips to be used to their full potential. This interface therefore provides a wide dynamic range and detailed rendering.
| Input DNR (ADC) | Output DNR (DAC) |
| 118dB | 122dB |
| ADC THD+N | DAC THD+N |
| < -116db (0.00015%) | < -115db (0.00017%) |
The M62 is equipped with a proprietary preamplifier module offering excellent performance. It provides clear sound reproduction, free from background noise, allowing you to capture every detail. The 88dB gain makes it easy to drive the iconic Shure SM7B microphone, for example.
Built-in AI noise reduction ensures clear and accurate voices in complex environments.
Three reverb modes are available (Studio, Live, and Hall) to suit every stage..
This intelligently optimizes your microphone's gain so that it can be used to its full potential.
This feature removes background noise, music, or ambient sounds to make voices clearer and put dialogue front and center.
The equalizer allows you to calibrate the sound before it enters the recording device, whether it's vocals or instruments. And it does so with zero latency, in real time. This feature greatly reduces the need for post-production processing, whether for podcasts, live singing, or streaming.
It is also possible to customize the audio output before it reaches the headphone output. This EQ offers the possibility to optimize the soundstage for a balanced and immersive overall output. It is therefore possible to adapt the output to various uses: music listening, gaming, movies, etc.
The built-in 5000mAh battery provides 6.5 to 8.5 hours of battery life on a single charge, depending on the configuration.
This mode does not require any additional software. Works directly for your best live sessions.
Intelligent processing instantly optimizes live streaming rendering.
Designed specifically for creators, record in high-resolution 24-bit 96kHz PCM.
The Control M Center software provides a 5-band, 20-channel mixer that can handle up to 10 DAW inputs and 8 return signals.
It is easy to use a backing track via Bluetooth or the AUX input. Bluetooth supports SBC, AAC, aptX Low-Latency, and aptX HD codecs.
The headphone amplifier delivers up to 2x 500W into 32 ohms (THD+N<1%) via its 3.5mm jack output. Its high gain combined with its +16dBu output level and ultra-low output impedance of 1 ohm makes it easy to drive professional headphones with high impedance up to 600 ohms.
The M62 interface remote control works via Bluetooth and IR and allows you to quickly and easily adjust the volume and effects, particularly for live performances and streaming.
| 1 | Microphone inputs (2x 6.35mm jack / 1x 3.5mm jack) |
| 2 | 3.5mm AUX jack input |
| 3 | 3.5mm headphone jack output |
| 4 | USB-C OTG output volume control |
| 5 | Headphone output volume control |
| 6 | Noise reduction switch |
| 7 | Switch reverb |
| 8 | Reverb amount control |
| 9 | Input volume control |
| 10 | Input selection |
| 11 | USB-C charging port |
| 12 | USB-C OTG port |
| 13 | USB-C port |
| 14 | ON/OFF button |
"With M62, we see the company producing far better performance in a battery operated portable no less! As such, I am surprised at the positioning toward average content creator. It is far more capable than that with extensive connectivity. And you have a nice headphone jack to boot. Charge the unit and you can enjoy many hours of music listening with an appropriate source.
All of this comes at such a reasonable price.
I am happy to recommend Topping M62 Professional Interface."
| Specifications | |
| Product type | Portable USB audio interface |
| Inputs | 2x 6.35mm TRS jack inputs (with 48V phantom power) 3.5mm TS/TRRS microphone input (with 2.5V bias voltage) 3.5mm AUX jack input Bluetooth |
| Outputs | 1x 3.5mm jack headphone output |
| Other connectors | 1x USB-C OTG port 1x USB-C port |
| Supported sample rates | USB-C OTG: 16bit 48kHz / 24bit 48kHz USB-C: 24bit 44.1kHz / 24bit 96kHz |
| DAW channels | 10 |
| Recording channels | 16 |
| Loopback channels | 8 |
| Operating modes | Mobile mode Live streaming mode Pro audio mode |
| Compatible operating systems | Windows / OSX / iOS / Android |
| Mixers | 5 |
| EQ | 4 bands per microphone input EQ type: parametric 10-band EQ on headphone output (only in Pro Audio mode) |
| Ducking | Ducking for all channels Adjustable parameters: threshold, attack, reduction, release |
| Noise reduction | AI noise reduction, noise gate 70 levels available for each mode |
| Reverb | 3 types of reverb Adjustable parameters: Dry/Wet mix, Room size, Decay |
| Input level indicator | IN1, IN2, AUX, BT avec LED RGB |
| Output level indicators | HP and OT with 2x9 double multicolor LED bars |
| IN1 input selection indicators | MIC 1, Mic-3.5, Mic-HP with 3 white LEDs |
| Noise reduction indicator | NC1, NC2 with two white LEDs |
| Ducking indicator | With 1 white LEDs |
| Reverb selection indicator | Studio, Live, Hall with 3 white LEDs |
| 48V phantom power indicator for Mic1 and Mic2 | 2 red LEDs |
| Power and battery indicators | LED circle |
| Microphone input | |
| Equivalent input noise | -129.5dBu |
| THD+N @ A-WT | -116dB (0.00015%) |
| Dynamic range @ A-WT | 118dB |
| SNR @ A-WT | 118dB |
| Crosstalk @ 1kHz | -140dB |
| Frequency response | 20Hz-20kHz (+/-0.2dB) |
| Max. input level | 8.6dBu |
| Input impedance | 2.0kOhms |
| Available gain | 0-88dB |
| Phantom power supply | 48V |
| Connector type | Jack 6.35mm TRS |
| AUX input | |
| THD+N @ A-WT | -110dB (0.0003%) |
| Dynamic range @ A-WT | 117dB |
| SNR @ A-WT | 117dB |
| Crosstalk @ 1kHz | -118dB |
| Max. input level | 2.6dBu |
| Input impedance | 10kOhms |
| Available gain | -99dB +9.5dB |
| Connector type | Jack 3.5mm TRS |
| 3.5mm MIC jack input | |
| THD+N @ A-WT | -100dB (0.001%) |
| Dynamic range @ A-WT | 113dB |
| SNR @ A-WT | 113dB |
| Max. input level | 4dBu |
| Input impedance | 1.2kOhms |
| Bias voltage | 2.5V |
| Connector type | Jack 3.5mm TS |
| 3.5mm MIC-HP jack input | |
| Connector type | Jack 3.5mm TRRS |
| 3.5mm headphone jack output | |
| THD+N @ A-WT | -115dB (0.00017%) |
| Dynamic range @ A-WT | 122dB |
| SNR @ A-WT | 122dB |
| Crosstalk @ 1kHz | -130dB |
| Max. output level | 16dBu |
| Bruit @ A-WT | 3.8uVrms |
| Output impedance | 1 Ohms |
| Output power | 2x 500mW @ 32 ohms (THD+N<1%) 2x 330mW @ 64 ohms (THD+N<1%) 2x 150mW @ 150 ohms (THD+N<1%) 2x 80mW @ 300 ohms (THD+N<1%) 2x 39mW @ 600 ohms (THD+N<1%) |
| USB OTG output (@OTG 24-bit 48 kHz & USB-C 24-bit 44.1/96 kHz) | |
| THD+N @ A-WT | -130dB (0.00003%) |
| Dynamic range @ A-WT | 138dB |
| SNR @ A-WT | 138dB |
| Crosstalk @ 1kHz | -154dB |
| Frequency response | 20Hz-20kHz (+/-0.1dB) |
| Max. output level | -0.5dBFS |
| Connector type | USB-C OTG |
| General | |
| Power supply | 5V 1-2.5A via USB-C |
| Battery | 5000mAh |
| Charging time | < 2.5 hours (with AC adapter > 10W, device turned off) |
| Autonomy | > 8.5 hours (without condenser microphone connected) > 7.5 hours (with one condenser microphone connected) > 6.5 hours (with two condenser microphones connected) |
| Dimensions | 7.2 x 15 x 2cm |
| Weight | 300g |
| Color | White |
| Package | 1x Topping Professional M62 1x Remote Control 1x USB-A to USB-C Cable 1x USB-C Cable |
| Input | Jack 3.5mm |
| Input | USB |
| Input | Jack 6.35mm |
| Output | Jack 3.5mm |
| Output | USB |
| Max sampling rate | 96kHz |
| Color | White |
| Interface chip | NC |
