High-quality 5-pin female DIN socket with contacts gold plated 24k andisolated PTFE .
Connects directly to the reading arm. Fastening and clamping system of the cable by two side screws. Accepts cables of diameter 8.5 mm maximum . CylinderAluminum plated Carbon
Specifications:
Also available in "Black" color
| Max cable diameter (mm) | 8.5 |
| Mounting type | To weld |
| Connectic | Female |
| Contacts number | 5 |
| Max panel thickness (mm) | N/A |
| Connector | DIN |
| Contacts Material (Connector) | N/A |
| Contacts Plating (Connector) | Gold |
