A 3.5mm mono jack cable must be used for this to work (available as an accessory).
If you use a stereo jack cable, it may not work.
This accessory, made in France, in our workshops, makes it easy to add an automatic on/off function (trigger) to devices that do not have this as a native function.
The principle of operation is simple: the housing has an IEC (sector) Input and output . By default, no current flows between the two connectors.
A second input on 3.5mm jack is located on the side of the device. When this input is fed by a 12V DC, it closes the circuit between the IEC input and output, which allows current to pass.
This type of accessory can be used in a variety of fields. In the case of an audio system, it is especially convenient to turn on several devices simultaneously: A master device equipped with a trigger output connected to the 12v trigger may thus control the activation of other remote devices. The same goes for the shutdown.
If your HiFi or Home Cinema set incorporates a 12V trigger output (HC preamplifier, Blu-ray high-end player) connect product on your amplifier input and drive it from the master device to trigger on elements that are connected to it.
Product type | trigger receptor on 230V Module |
Voltage max | 12V |
Amperage max | 8A 230V |
Input | IEC C13 Female |
Output | IEC male C14 |
Rated operating curren | 33mA @ 12V |
Minimum current | 25mA (0.025A) |
Consumption (12V input) | 0.36W |
12V input | 400 Ohm / 30mA |
Dimensions | 82 x 58 x 28.5 mm It requires 25mm spacing on right side, 12mm on left side |
Weight | 66g |
Input | IEC C14 |
Output | IEC C13 |
Color | Black |
Output voltage (V) | 230.0 |
Output current (A) | 10.0 |
Input voltage (V) | 230.0 |
Power Supply | Trigger |
Average votes 4.6 / 5 59 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Maik B.
Michal L.
Bruno C.
Eemeli T.
ERIC C.
