Parfait pour alimenter un raspbery zero pendant des heures
Quel est le type de connecteur présent sur la carte (facilite son branchement)) ?
The battery manager BCPB0 provides a high performance circuit to ensure the charge and protection of your lithium batteries. Completely secure, it supports the protection against overload, overheating, short-circuit and over-discharge of the battery.
It embeds a battery cradle for 1x 26650 cell and constitutes a compact external battery Raspberry Pi / Smartphone / tablet through its female USB-A discharge port.
A LED indicator shows the state of charge and discharge of the battery.
Integration with a Raspberry Pi can be pushed even further with a cleverly designed connector to attack the GPIO in direct contact from below. This will feed a Raspberry Pi even in a very space-limited environment while leaving the 40-pin GPIO available for other applications. It is an ideal choice for your projects of DAC / streamer nomadic and semi-nomadic devices based on SBC.
| Index | Dimensions |
| A | 91.52 mm |
| A1 | 57.91 mm |
| A2 | 26.16 mm |
| B | 30.48 mm |
| B1 | 23.11 mm |
| D1 | 2.79 mm |
| D2 | 4.32 mm |
| Specifications | |
| Type | Battery Manager |
| Battery format | Lithium accumulator 26650 |
| Number of batteries | x1 |
| Batteries included? | No |
| Output voltage | 5VDC |
| Max discharge current | 2A |
| Maximum load current | 2A |
| Minimum load current | 1A |
| Overload detection voltage | 4.235V |
| Overload release voltage | 4.18V |
| Over-discharge detection voltage | 2.8V |
| Over-discharge release voltage | 3V |
| Maximum Operating Temperature | 50 ° C |
| Input | NC |
| Output | PCB Connector |
| Output | Solder pad |
| Output | USB |
| Output voltage (V) | 5.0 |
| Output current (A) | 2.0 |
| Input voltage (V) | N/A |
| Power Supply | Battery |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Stéphane M.
