By buying this product you get 62 loyalty points
Compact yet extremely powerful, the DSPeaker Anti-Mode X2D presents itself as a DSP to perform acoustic correction and equalization tasks with great efficiency. It features the brand-new Anti-Mode™ 3 algorithm, capable of automatically optimizing your main speakers and optional subwoofer according to your acoustic environment. This makes it quick and easy to improve the sound quality of an existing HiFi system.
A fully customizable tone control feature is also available, in addition to a state-of-the-art digital crossover and subsonic filter. Most features can be adjusted in real time using the supplied remote control. Several sound profiles are also available, allowing quick access to previously saved settings.
DSPeaker Anti-Mode X2D offers a high-performance acoustic correction system to limit or even cancel out the impact of the many defects that a listening room can present on the quality of reproduction of an audio system. It uses a microphone-based calibration system to resolve problems such as reverberation, echo, sound reflection and speaker/subwoofer mismatch, so that your audio system can really shine. This correction is fully automatic and transparent.
In addition to its acoustic correction function, the DSPeaker Anti-Mode X2D provides tone control, allowing you to manually adjust the level of bass, midrange and treble. These parameters can be stored in three sound profiles, which can be accessed at any time.
The DSPeaker Anti-Mode X2D is placed directly between your sources and your DAC and active subwoofer. The DSPeaker Anti-Mode X2D is designed for this purpose, with a combined RCA stereo/coaxial input, a Toslink optical input and a USB-C port. Thanks to its integrated DAC, the digital section supports audio streams up to PCM 24bit 192kHz. Outputs include a Toslink optical output, a coaxial SPDIF output and a subwoofer output.
1 | 12VDC power supply connector |
2 | USB-A input (for firmware update) |
3 | USB-C audio input |
4 | Toslink optical output |
5 | SPDIF coaxial output |
6 | Subwoofer output |
7 | Stereo RCA input / Coaxial SPDIF input |
8 | Toslink optical input |
Product type | DSP Acoustic correction |
Inputs | 1x Combo RCA Stereo / SPDIF Coaxial 1x Optical Toslink 1x USB-C 1x USB Audio 1.0 Stereo PCM 1x Microphone input |
Outputs | 1x Optical Toslink 1x SPDIF Coaxial 1x Subwoofer output (RCA) |
Supported sample rates | USB: PCM up to 24bit 96kHz SPDIF: PCM up to 24bit 192kHz |
Frequency range (analog to analog) | 5Hz - 22kHz |
Analog input level | 2.3Vrms (max) |
SNR analog input | 107dB |
THD (-6dB) analog input | < 0.002% |
Optical/SPDIF output | 24/bit 96kHz |
Sbwoofer output level | 2.3Vrms (max) |
SNR subwoofer output | 100dB |
THD (-6dB) subwoofer output | < 0.03% |
Supply voltage | 12VDC 2.6A |
Dimensions | 126 x 80 x28mm |
Consumption | 1.5W |
Standby power consumption | 0.1W |
Dimensions (L*P*H) | 126*80*28mm |
Weight | 300g |
Color | Black |
Package | 1* DSPeaker Anti-Mode X2D 1* Measurement microphone 1* Remote control 1* Power supply |
Input | USB |
Input | SPDIF |
Input | RCA |
Input | Optical |
Output | Optical Toslink |
Output | Subwoofer |
Output | Coaxial SPDIF |
Max sampling rate | 192kHz |
Color | Black |
