By buying this product you get 139 loyalty points
The Tonewinner AT-300 is a 16 channel audio/video processor and preamplifier, ideal for home theater integration in 9.3.4 or 7.3.6 configurations. It supports all current audio formats such as Dolby Atmos, Dolby True HD, DTS:X and DTS Master. Similarly, the AT-300 accepts video streams up to 4K UHD 60Hz and is compatible with HDR, HDR10 and Dolby Vision technologies. It allows you to enjoy the latest and greatest formats available for the most immersive audio and visual experience possible.
The video processing section for the AT-300's HDMI inputs and outputs uses a Panasonic MN864788 controller. It supports 32bit streams, resolutions up to 4K (3840*2460px) 60Hz and is compatible with RGB/YUV 4:4:4 color spaces.
The audio part of the AT-300 relies largely on two Cirrus Logic CS42528 chips, ensuring at the same time the functions of DAC, ADC and SPDIF receiver. These ensure a quality sound reproduction thanks to a wide dynamic range and a very low level of distortion and noise.
Combined with these chips, an Analog Devices ADSP-21573 SHARC floating point DSP takes care of decoding Dolby Atmos and DTS:X audio formats to create a truly immersive and consistent sound experience with excellent channel separation.
Quite rare on this type of device, the volume control is here with resistance switching. Such integration allows a precise and non-destructive adjustment of the sound level.
The Tonewinner AT-300 supports all current video technologies and formats. With 18Gbps of bandwidth and HDCP 2.2 compliant HDMI 2.1 connectivity, it easily decodes 4K UHD 60Hz video streams. It also supports HLG, HDR10 and Dolby Vision technologies, bringing an incredible level of brightness and contrast for an exceptional image quality.
With the ETM-2 measurement microphone (sold separately), the AT-300 is able to automatically calibrate and correct your audio system. The microphone captures the sound information emitted by your speakers and applies automatic equalization to each channel, depending on your listening position.
In addition to the automatic calibration, it is possible to adjust the equalization manually. Indeed, the Tonewinner AT-300 provides an 11-band parametric equalizer for the left, right and center channels and a 5-band equalizer for the surround, top and bass channels. This equalization can be done directly from the graphical interface of the device.
Each group of inputs has an equalizer and independent effects. These different parameters are stored by the device and automatically selected according to the selected input.
The Tonewinner AT-300, in order to adapt to different environments, can be used in several configurations: 2.0, 2.1, 5.1, 5.1.2, 5.1.4, 7.1, 7.1.2, 7.1.4, 7.3.6, 9.3.4... So no matter what room you use it in, the AT-300 will fit right in and let you enjoy your audio and video content.
For each channel, the AT-300 allows you to apply a volume level setting and limitations that can be saved and applied as soon as the unit is turned on.
In addition to a particularly extensive connectivity, the AT-300 integrates a Bluetooth receiver. This one allows a wireless audio broadcast, from a smartphone or a tablet for example. The control of the playback is then done directly from your mobile device for a simple, fast and convenient use.
1 | RCA outputs |
2 | RCA inputs |
3 | Optical Toslink inputs |
4 | Coaxial inputs |
5 | HDMI output |
6 | Bluetooth antenna |
7 | HDMI eARC output |
8 | Calibration microphone connector |
9 | Micro SD slot |
10 | IR input |
11 | 5V trigger output |
12 | Mini USB input (USB Audio) |
13 | RS232 interface |
14 | HDMI inputs |
15 | XLR outputs |
16 | Power input |
Product type | Audio / Video processor Home Cinema preamplifier |
Channels | Total : 16 channels |
Inputs | Bluetooth 6* HDMI 2.0 4* Stereo RCA 2* Coaxial 2* Optical Toslink 1* Micro SD slot 1* Mini USB (USB Audio) 1* USB-A (USB Host) |
Outputs | Bluetooth 2* HDMI 2.0 (including 1 eARC) RCA 9.3.4 channels XLR 9.1.4 channels |
Other connectors | 1* RS232 1* 5V trigger output |
Supported audio formats | Dolby Atmos DTS/X Dolby True HD Dolby Digital Plus DTS Master DTS Hi-Res DTS Upmix DTS Neural X |
Supported video formats / resolutions | 4K UHD 3D Dolby Vision HDR10 / HDR10+ HLG |
HDCP version | 2.2 |
eARC support | On one output |
CEC support | On 5 inputs |
Automatic EQ calibration | |
Lip Synchronization | Up to 1000ms |
DRC function | |
Input impedance | 20kΩ |
Output impedance | 1kΩ |
Input level | ≥ 2Vrms |
Gain | ≥ 14dB |
THD | ≤ 0.02% (1kHz) |
SNR | ≥ 98dB (A-Weighted) |
Frequency response | 10Hz-50kHz (+1/-3dB) |
Channel separation | > 80dB |
Crosstalk | ≥ 80dB |
Supply voltage | 100-240VAC 50/60Hz |
Dimensions (L*P*H) | 431*326*100mm |
Weight | 4.4kg |
Color | Black |
Package | 1* Tonewinner AT-300 1* Remote control 1* Power cable 1* HDMI cable 1.5m 1* RCA cable |
Input | HDMI |
Input | RCA |
Input | Optical |
Input | Micro SD |
Input | USB |
Input | SPDIF |
Input | Bluetooth |
Output | XLR |
Output | Bluetooth |
Output | RCA |
Output | HDMI |
Max sampling rate | NC |
Color | Black |
