TINYSINE TSA1702B TWS DSP Module Bluetooth 5.1
The TinySine TSA1702B is a complete digital audio signal processing module. The main chip used is an ADAU1702B, enabling this DSP to be used for active speakers or to create an efficient 2.1 system. Four potentiometers allow direct physical adjustment of the main parameters: gain and level of bass, midrange and treble.
Reference : 19348
32,90 €tax incl.
27,42 € tax excl.
Shipping date: 24-06-2025.
TINYSINE TSA1702B TWS DSP Module Bluetooth 5.1 ADAU1701 Sigma Studio
TINYSINE TSA1702B TWS: Front view
The TinySine TSA1702B is a complete digital audio signal processing module. The main chip used is an ADAU1701, enabling this DSP to be used for active speakers or to create an efficient 2.1 system. Four potentiometers allow direct physical adjustment of the main parameters: gain and level of bass, midrange and treble.
The module has a debug port for Sigma Studio. This means you can program the module using a programmer (sold separately, see accessories) to provide a host of additional features including EQ, filtering, bass enhancement, dynamic multiband processing, delay compensation and much more.
This module is also equipped with a Bluetooth 5.1 reception module that supports aptX, aptX HD, SBC and AAC. Finally, you can power this module via micro-USB or any 9V - 30V DC power supply.
TINYSINE TSA1702B TWS : Explanatory diagram
Download ADI Sigma Studio
Product typeDSP Module
DSPADAU1701
50MIPS
28/56bit
Output level0.9Vrms
Input signal range2Vrms
Input resistance20kΩ
Software compatibilitySigma Studio
Power supply5V via Micro USB or 9-30V DC
Hole spacing78.75 x 50mm
I2S sampling rate48KHz
Supported codecsaptX
aptX HD
SBC
AAC
Pinout
Port namePin nameDirectionDescription
External Potentiometers port3.3VPower Out3.3V Output
A_ADC1Analog InTreble control
A_ADC2Analog InMidrange control
A_ADC3Analog InBass control
A_ADC0Analog InGain control
GND--
Auxiliary inputGND--
ADC1Analog InRight channel
ADC0Analog InLeft Channel
Audio output 1GND--
DAC0Analog OutLeft Channel
DAC1Analog OutRight channel
Audio output 2GND--
DAC2Analog OutLeft Channel
DAC3Analog OutRight channel
Dimensions89 x 60mm
Package1x TinySine TSA1702B TWS
InputJack 3.5mm
OutputJack 3.5mm
The TinySine TSA1702B is a complete digital audio signal processing module. The main chip used is an ADAU1702B, enabling this DSP to be used for...
