DAYTON AUDIO DSP-RC Wired Remote Control DSP-408
The Dayton Audio DSP-RC is a compact wired remote control for controlling the DSP-408 Digital Signal Processor (DSP). It will allow you to directly adjust the volume as well as select a profile pre-registered by you.
2.0 / 5
Reference : 13044
22,90 €tax incl.
19,08 € tax excl.
Shipping from France
Billing in France
Technical support in France
This model has been replaced by the Dayton Audio DSP-NRC version.
DAYTON AUDIO DSP-RC
Wired remote control for Dayton Audio DSP-408
Télécommande pour Dayton Audio DSP-408
Take control of your DSP-408
The Dayton Audio DSP-RC is a compact wired remote control for controlling the DSP-408 Digital Signal Processor (DSP). It will allow you to directly adjust the volume as well as select a profile pre-registered by you. On this remote control there is a rotary knob illuminated with blue LEDs, a digital display and two LEDs indicating the parameters on which you act, namely the sound or the profiles. To switch from volume control to profile control, simply press and hold the rotary knob until the LED indicates the desired mode.
CompatibilityDSP-408
ConnectionRJ45
Cable length40cm
Control remote dimensions6 x 3.8 x 1.9cm
LEDs colorBlue
InputBNC
OutputNC
Max sampling rateNC
ChannelN/A
Déçu
Dommage, bien que de belle qualité, ce petit appareil lorsqu'il est raccordé au DSP-408 émet un petit buzzz dans les hauts parleurs, perceptible à bas niveau, quoi que sur des enceintes à très haut rendement. A mon humble avis, l'alimentation de l'éclairage (trop vif) passant contre le signal de modulation (sur 5 mètres) doit générer ces interférences. En Hi-Fi embarquée, ça doit passer inaperçu, pas sur une chaîne de salon à très haut rendement.
This review has been posted for DAYTON AUDIO DSP-RC Wired Remote Control DSP-408
The Dayton Audio DSP-RC is a compact wired remote control for controlling the DSP-408 Digital Signal Processor (DSP). It will allow you to directly...
