COVID-19 Virus information. Find the latest regularly updated information about the status of our services.
MINIDSP C-DSP 8x12DL Audio Processor DSP Dirac Live SHARC ADSP21489 12 Channels
The MiniDSP C-DSP 8x12DL is a high-end audio processor that will allow you to enjoy the full potential of your audio system, including a Car Audio system since the DSP has features that allow it to be used in this context.
By buying this product you get 94 loyalty points
Reference : 13869
940,83 €tax excl.
Including 0,04 € for green tax
Shipping date: 29-05-2020.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
MiniDSP C-DSP 8x12 DL
MiniDSP C-DSP 8x12 DL Processeur Audio DSP Dirac Live SHARC ADSP21489 12 Canaux
The MiniDSP C-DSP 8x12DL is a high-end audio processor that will allow you to enjoy the full potential of your audio system, including a Car Audio system since the DSP has features that allow it to be used in this context. It includes a Dirac Live acoustic correction system and a SHARC ADSP21489 400MHz floating point processing chip. Its 32bit AKM converters provide a THD+N of -107dB for an incredibly accurate sound reproduction. Its intuitive input/output system consists of six low-level analog inputs for extremely low noise level, six high level inputs as well as an optical and a coaxial input. On the output side, the device offers 12 RCA, which, combined with eight-channel Dirac Live processing, make the C-DSP 8x12 DL particularly suitable for active crossover systems or surround/multichannel installations with subwoofer integration.
This DSP also includes a complete, efficient and intuitive audio processing system: equalizers, compression, delay adjustment, crossovers up to 48dB/octave and a mixing matrix with rear/center management are available to allow you to make precise adjustments to your audio system. Up to 4 profiles can be stored in the DSP's flash memory and can be easily selected using a wired or infrared remote control.
For Car Audio use, the C-DSP 8x12DL includes an isolated power supply, trigger input/output, wired remote control for dashboard mounting and a Micro SD card slot for offline device configuration.
Product typeDSP
DSP ChipAnalog Devices ADSP21489 400MHz floating point DSP
DAC ChipAK4456
ADC ChipAK5556
THD+N0.0007%
SNR115dB
Input / Output configuration8 inputs / 12 outputs
Inputs6x High level inputs
6x Single-ended low level RCA inputs
1x S/PDIF Coaxial
1x Optical Toslink
ASRC sampling rate44.1kHz - 192kHz
Outputs12x RCA
RCA outputs SNR115dB
RCA outputs THD+N0.0007%
Max input level8 or 12Vrms on high level inputs
4 or 2Vrms on low level inputs
Max output level6Vrms
Input impedanceHigh level : 68Ω
Low level : 10kΩ
Output impedance560Ω
Calibration softwarePlugin C-DSP 8x12
Filtering technologyIIR / FIR depending on plugin
Number of presets4
Impulse response correction
Infrared remote learning
Windows / Mac compatibility
Room EQ Wizard support
Dimensions41 x 205 x 122mm
Housing materialAluminium
Package1x MiniDSP C-DSP 8x12 DL
1x Dirac Live license
1x USB cable 1m
1x Remote control module + remote control cable 5m
1x C-DSP 8x12 DL plugin license
1x Control GUI plugin
InputUSB-B
InputUSB 2.0
DAC ChipAK4456
Channel12
Colissimo - TNT - SoColissimo
The MiniDSP C-DSP 8x12DL is a high-end audio processor that will allow you to enjoy the full potential of your audio system, including a Car Audio...
