Tolerance (%)
0 % - 20 %
Capacitor capacitance (µF)
Capacitor format
Capacitor type
Inductance (mh)
Power (W)
0 - 250
Rated voltage (V)
Input voltage (V)
V
V
Output voltage (V)
Output current (A)
0 A - 5 A
Rated current (A)
Resistance (Ohm)
Section (mm²)
0 mm - 1 mm
Contacts number
4 - 9
Channel
Max panel thickness
mm
mm
Color
Electronic components
Axel J. Z.
Review Fosi S3 HiRes Streamer
Conclusion
The Fosi Audio S3 is a compact streamer/DAC with a fully balanced preamp stage, modern connectivity (Wi-Fi 6,...
Frank L.
Adaptateur de qualité
Cet adaptateur m'a permis d'utiliser un casque en 4.4 sur mon ampli sans changer le cable du casque, il n'y a...
marc g.
pas terrible!
Ridiculement petit et pas plus facile que ça à intégrer. Du coup on voit rien a plus de 3m. La nappe en dessous reste visible...
  • Capacitors
    Capacitors
  • Selfs & Coils
    Selfs & Coils
  • Resistors
    Resistors
  • Potentiometers
    Potentiometers
  • Selectors
    Selectors
  • OPA Adapters
    OPA Adapters
  • Universal circuit boards
  • Relays
    Relays
  • Fuse and Circuit breaker
  • OPA
    OPA
  • Transistors
    Transistors
  • Speaker L-control
    Speaker L-control
  • Voltage Regulator
    Voltage Regulator
  • Clocks
    Clocks
  • Light Bulbs and LED
    Light Bulbs and LED
  • Tubes and lamps
    Tubes and lamps
  • Audio Transformer
    Audio Transformer
  • Ref : 4544
    Air coils, for physical reasons, are unbeatable in terms of precision on the restitution of the impulses, and are free of any distortion (contrary to ferrite coils). For this reason, Mundorf produces coils with a large wire diameter for purists. This makes it possible to achieve better inductances while maintaining low internal impedance and zero...
    8,70 € 7,25 €Ex.
    In Stock
  • Ref : 4545
    In Stock
    9,10 € 7,58 €Ex.
    In Stock
  • Ref : 4546
    In Stock
    9,50 € 7,92 €Ex.
    In Stock
  • Ref : 4547
    In Stock
    9,90 € 8,25 €Ex.
    In Stock
  • Ref : 4548
    In Stock
    10,90 € 9,08 €Ex.
    In Stock
  • Ref : 4549
    In Stock
    11,90 € 9,92 €Ex.
    In Stock
  • Ref : 4550
    In Stock
    12,90 € 10,75 €Ex.
    In Stock
  • Ref : 4552
    In Stock
    15,90 € 13,25 €Ex.
    In Stock
  • Ref : 4553
    In Stock
    17,90 € 14,92 €Ex.
    In Stock
  • Ref : 4554
    In Stock
    19,90 € 16,58 €Ex.
    In Stock
  • Ref : 4565
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 4566
    In Stock
    49,90 € 41,58 €Ex.
    In Stock
  • Ref : 4567
    In Stock
    56,90 € 47,42 €Ex.
    In Stock
  • Ref : 4551
    In Stock
    13,90 € 11,58 €Ex.
    In Stock
  • Ref : 4556
    In Stock
    21,90 € 18,25 €Ex.
    In Stock
  • Ref : 4557
    In Stock
    23,90 € 19,92 €Ex.
    In Stock
  • Ref : 4555
    In Stock
    21,90 € 18,25 €Ex.
    In Stock
  • Ref : 4559
    In Stock
    25,90 € 21,58 €Ex.
    In Stock
  • Ref : 4560
    In Stock
    27,90 € 23,25 €Ex.
    In Stock
  • Ref : 4558
    In Stock
    16,90 € 14,08 €Ex.
    In Stock
  • Ref : 4561
    In Stock
    29,90 € 24,92 €Ex.
    In Stock
  • Ref : 4562
    In Stock
    32,90 € 27,42 €Ex.
    In Stock
  • Ref : 4563
    In Stock
    35,90 € 29,92 €Ex.
    In Stock
  • Ref : 4564
    In Stock
    39,90 € 33,25 €Ex.
    In Stock
  • Ref : 1646
    In Stock
    10,90 € 9,08 €Ex.
    In Stock
  • Ref : 1645
    In Stock
    11,90 € 9,92 €Ex.
    In Stock
  • Ref : 1648
    In Stock
    12,90 € 10,75 €Ex.
    In Stock
  • Ref : 1647
    In Stock
    9,90 € 8,25 €Ex.
    In Stock
  • Ref : 1649
    13,90 € 11,58 €Ex.
    In Stock
  • Ref : 1650
    In Stock
    14,90 € 12,42 €Ex.
    In Stock
  • Ref : 1651
    In Stock
    15,90 € 13,25 €Ex.
    In Stock
  • Ref : 1652
    In Stock
    17,90 € 14,92 €Ex.
    In Stock
  • Ref : 1653
    In Stock
    19,90 € 16,58 €Ex.
    In Stock
  • Ref : 1654
    In Stock
    21,90 € 18,25 €Ex.
    In Stock
  • Ref : 1655
    In Stock
    23,90 € 19,92 €Ex.
    In Stock
  • Ref : 1656
    In Stock
    26,90 € 22,42 €Ex.
    In Stock
  • Ref : 1658
    32,90 € 27,42 €Ex.
    In Stock
  • Ref : 1659
    In Stock
    33,90 € 28,25 €Ex.
    In Stock
  • Ref : 1660
    In Stock
    38,90 € 32,42 €Ex.
    In Stock
  • Ref : 1669
    In Stock
    129,00 € 107,50 €Ex.
    In Stock
