IFI AUDIO ZEN AIR DAC 2 USB DAC
The iFi Audio ZEN Air DAC 2 is a USB DAC with an integrated headphone amplifier designed to deliver high-quality audio reproduction in a compact and accessible format. It is based on a bit-perfect Cirrus Logic DAC compatible with DSD and DXD, combined with an optimized internal architecture and a USB interface developed in-house by iFi. Compatible with PCM streams up to 32bit / 384kHz, native DSD256, and DXD, it ensures precise and faithful digital-to-analog conversion.
Reference : 21889
139,00 €tax incl.
115,83 € tax excl.
Shipping date: 17-11-2026.
iFi Audio Zen Air DAC 2 USB DAC Cirrus Logic 32bit 768kHz DSD256
IFI AUDIO ZEN Air DAC 2
The iFi Audio Zen Air DAC 2 is a USB DAC with an integrated headphone amplifier designed to deliver high-quality audio reproduction in a compact and accessible format. It is based on a bit-perfect Cirrus Logic MasterHiFi DAC compatible with DSD and DXD, combined with an optimized internal architecture and a USB interface developed in-house by iFi. Compatible with PCM streams up to 32bit / 384kHz, native DSD256, and DXD, it ensures precise and faithful digital-to-analog conversion.
The Zen Air DAC 2 also features a headphone amplifier capable of delivering up to 286mW at 32Ω via its 6.35mm jack output and up to 484mW at 64Ω via its balanced 4.4mm jack output. It offers a stereo RCA line output with fixed or variable level (2V to 3.4V depending on preamp mode), allowing use with a power amplifier or active speakers. It includes proprietary PowerMatch (gain adjustment) and XBass+ (analog bass enhancement) technologies, as well as a front-panel analog volume control. Power is supplied via USB-C, with optimized consumption and plug & play operation. Compact and versatile, it is an ideal solution for use with a computer or in a desktop HiFi system.
iFi Audio Zen Air DAC 2: Cirrus Logic bit-perfect DAC
The Zen Air DAC 2 is based on a Cirrus Logic converter designed for faithful reproduction of the digital signal. It supports demanding high-resolution formats, including PCM up to 384kHz, native DSD256, and DXD.
This wide compatibility allows you to fully enjoy high-definition audio files, with detailed playback that respects the original recording.
iFi Audio Zen Air DAC 2: integrated headphone amplifier
The device includes a high-performance headphone amplifier capable of delivering substantial power suitable for a wide variety of headphones. It features a balanced 4.4 mm jack output delivering up to 484 mW at 64Ω, as well as an unbalanced 6.35 mm jack output delivering 286 mW at 32Ω, ensuring excellent versatility for both demanding and more sensitive headphones.
The PowerMatch function allows adjustment of the gain according to the headphones used, optimizing output level and ensuring better volume control, with increased dynamics and ideal adaptation to different impedances.
iFi Audio Zen Air DAC 2: analog bass correction
The Zen Air DAC 2 features XBass+ technology, an analog circuit designed to enhance low frequencies without affecting mids or highs.
This function is particularly useful with certain headphones or speakers lacking presence in the low-end, enabling a more balanced and immersive listening experience.
iFi Audio Zen Air DAC 2: variable or fixed output with preamp function
Thanks to its stereo RCA output, the Zen Air DAC 2 can be used as a standard DAC or as a preamplifier.
Users can choose between:
  • a fixed output level for use with an integrated amplifier
  • a variable level controlled by the front potentiometer, for direct connection to a power amplifier or active speakers
This flexibility allows easy integration into different types of audio systems.
Overview of the iFi Audio Zen Air DAC 2
Overview of the IFI AUDIO ZEN Air DAC 2
1Power
2LED indicator
3Power Match function
4Volume control
56.35mm headphone output
6Balanced 4.4mm headphone output
7XBass+ function
8RCA output
9Power supply / USB DAC input
Technical specifications
Product typeUSB DAC
DAC chipCirrus Logic
Input1x USB-C
Output1x RCA output (fixed or variable)
1x Balanced 4.4mm headphone output
1x Single-ended 6.35mm headphone output
Supported sample ratesPCM 32bit 768kHz, DSD256, DXD
RCA output measurements
Output level2 to 3.4V
SNR118dBA
DNR118dBA
Frequency response20Hz-90kHz
Output impedance≤ 50Ω
6.35mm jack output measurements
Output level286mW at 32 ohms
Output impedance< 0.7 ohm
SNR118dBA
THD+N0.0011%
4.4mm jack output measurements
Output level484mW at 64 ohms
Output impedance< 1.4 ohm
SNR118dBA
THD+N0.0015%
Power supply5V DC >1A via USB-C
Power consumptionNo signal: ~0.55W
Max.: < 3.55W max.
Dimensions158 x 35 x 100mm
Weight315g
Package contents1x iFi Audio Zen Air DAC 2
1x USB-A to USB-C 2.0 cable
OutputJack 6.35mm
OutputJack 4.4mm
DAC / ADC ChipNC
Max sampling rateDSD256
Max sampling rate768kHz
ColorBlue
IFI AUDIO ZEN AIR DAC 2 USB DAC Cirrus Logic 32bit 768kHz DSD256
The iFi Audio ZEN Air DAC 2 is a USB DAC with an integrated headphone amplifier designed to deliver high-quality audio reproduction in a compact...
