SHANLING M0 PURA Digital Audio Player DAP Black
The Shanling M0 Pura is an ultra-compact digital audio player designed for high-resolution playback on the go. It utilises a dual Cirrus Logic CS43131 chip in a symmetrical configuration and delivers up to 250 mW into 32 Ω, ensuring precise conversion combined with amplification capable of maintaining a dynamic range suitable for the vast majority of earphones and headphones.
Reference : 21908
129,00 €tax incl.
107,50 € tax excl.
Shipping date: 20-11-2026.
Shanling M0 Pura Digital Audio Player DAP 2xCS43131 Bluetooth 5.0 aptX LDAC 32bit 384kHz DSD128 Black
Shanling M0 Pura : Front view
The Shanling M0 Pura is an ultra-compact digital audio player designed for high-resolution playback on the go. It utilises a dual Cirrus Logic CS43131 chip in a symmetrical configuration and delivers up to 250mW into 32Ω, ensuring precise conversion combined with amplification capable of maintaining a dynamic range suitable for the vast majority of earphones and headphones.
Shanling M0 Pura: Dual CS43131 DAC
The Shanling M0 Pura is based on a dual Cirrus Logic CS43131 chip operating in a symmetrical configuration, which separates the channels whilst reducing crosstalk, resulting in a more stable soundstage. This architecture supports playback of PCM streams up to 32-bit/384 kHz as well as DSD128, ensuring support for high-resolution formats without intermediate conversion.
Beyond the decoding stage, this approach extends to the amplification stage, which delivers up to 250mW into a 32Ω load, providing sufficient headroom to drive both earphones and compact headphones. This consistency between conversion and amplification ensures controlled sound reproduction, even with loads of varying impedance, for mobile listening without compromising on dynamic range.
Shanling M0 Pura : CS43131 DAC chip
Shanling M0 Pura : connected to a smartphone
Shanling M0 Pura: Dual output mode
The M0 Pura features a 3.5mm jack output capable of operating in either single-ended or balanced mode, allowing the signal behaviour to be adapted to suit the application. In single-ended mode, it ensures immediate compatibility with the majority of headphones and earphones on the market, whilst using balanced mode, via a 4.4 mm jack adapter, improves channel separation whilst minimising interference caused by common-mode currents.
Shanling M0 Pura: Compact size
Weighing just 35g and featuring a 1.54-inch touchscreen, the M0 Pura prioritises a compact design that makes it easy to use whilst keeping its footprint to a minimum. This approach is further enhanced by the inclusion of a 650 mAh battery, which provides up to 9.5 hours of uninterrupted playback.
Shanling M0 Pura : Connected to headphones
Shanling M0 Pura : Two-way Bluetooth
Shanling M0 Pura: Two-way Bluetooth connectivity
The bidirectional Bluetooth module allows the M0 Pura to function as both a receiver and a transmitter, thereby adapting its role within the audio system. In receive mode, it supports LDAC, AAC and SBC codecs, allowing it to receive a high-quality audio stream from a smartphone, whilst in transmit mode it extends this compatibility to LDAC, aptX, AAC and SBC to power wireless headphones or speakers.
Technical specifications
Product typeDigital audio player (DAP)
Inputs1x USB-C
1x Micro SD slot (Max 2To)
1x Bluetooth 5.0
Outputs1x Jack 3.5mm
Bluetooth 5.0
DAC chips2x CS43131
Touch screen1.54" 240*240px
Battery650mAh
Autonomy9.5h
Supported Bluetooth codecsTransmitter : SBC, AAC, aptX, LDAC
Receiver : SBC, AAC, LDAC
Supported file formatsDSD (.iso, .dsfl, .dff) / DXD / APE / ALAC / WAV / AIFF / AIF / DTS / MP3 / WMA / AAC / OFF / MP2 / M4A / AC3 / CUE / M3U
Output powerSingle-ended output : 1.8V @32Ω (100mW @32Ω)
Balanced output : 2.8V @32Ω (250mW @32Ω)
Frequency response20Hz-40kHz (-0.5dB)
Total harmonic distortion more noise (THD+N)Single-ended output : 0.0004% @32Ω (A-Weighted @ 720mV)
Balanced output : 0.0007% @32Ω (A-Weighted @ 1V)
Dynamic rangeSingle-ended output : 121dB @32Ω (A-Weighted)
Balanced output : 128dB @32Ω (A-Weighted)
Channel separationSingle-ended output : 73dB @32Ω
Balanced output : 99dB @32Ω
Signal-to-noise ratio (SNR)Single-ended output : 121dB @32Ω
Output impedanceSingle-ended output : ≤ 0.4Ω
Balanced output : ≤ 0.8Ω
Dimensions43.8 x 45 x 13.8mm
Weight35g
Package1x Shanling M0 Pura
1x USB-C cable
InputMicro SD
OutputJack 3.5mm
OutputBluetooth
DAC / ADC ChipCS43131
Max sampling rateDSD128
Max sampling rate384kHz
SHANLING M0 PURA Digital Audio Player DAP 2xCS43131 Bluetooth 5.0 aptX LDAC 32bit 384kHz DSD128 Black
The Shanling M0 Pura is an ultra-compact digital audio player designed for high-resolution playback on the go. It utilises a dual Cirrus Logic...
