Tolerance (%)
0 % - 20 %
Capacitor capacitance (µF)
Capacitor format
Capacitor type
Inductance (mh)
Power (W)
0 - 250
Rated voltage (V)
Input voltage (V)
V
V
Output voltage (V)
Output current (A)
0 A - 5 A
Rated current (A)
Resistance (Ohm)
Section (mm²)
0 mm - 1 mm
Contacts number
4 - 9
Channel
Max panel thickness
mm
mm
Color
Electronic components
freddy w.
bluffé et dubitatif
Bj, j'ai suivi un avis au final d'un ami qui m'a assuré que j'allais tomber parterre en écoutant ce cable...
Françoise B.
Dans un système de qualité, ceux qui sont encore septique sur le traitement du signal numérique ethernet il faut essayer cet...
Patrick P.
Musique !
Trois LP12 et maintenant trois Fosi phono x5.
Ravi, tellement ce petit boîtier fait entendre la musique et les musiciens en...
  • Capacitors
    Capacitors
  • Selfs & Coils
    Selfs & Coils
  • Resistors
    Resistors
  • Potentiometers
    Potentiometers
  • Selectors
    Selectors
  • OPA Adapters
    OPA Adapters
  • Universal circuit boards
  • Relays
    Relays
  • Fuse and Circuit breaker
  • OPA
    OPA
  • Transistors
    Transistors
  • Speaker L-control
    Speaker L-control
  • Voltage Regulator
    Voltage Regulator
  • Clocks
    Clocks
  • Light Bulbs and LED
    Light Bulbs and LED
  • Tubes and lamps
    Tubes and lamps
  • Audio Transformer
    Audio Transformer
  • Ref : 1093
    In Stock
    Unlike conventional resistors, & film metal winding resistors have no residual inductance. Thus, in cases where impulse response is essential, in midrange frequencies for example, & film metal winding resistors are an excellent choice.
    3,40 € 2,83 €Ex.
    In Stock
  • 1,70 € 1,42 €Ex.
    In Stock
  • 1,70 € 1,42 €Ex.
    In Stock
  • Ref : 20417
    Mundorf MResist Classic resistors offer very good performance. They are similar but slightly simpler in construction than the MResist Supreme resistors. The MResist Classic series is designed to bridge the gap between ordinary MOX resistors and the top-of-the-line MResist Supreme. The Mundorf MResist Classic shares the essential features of the advanced...
    9,90 € 8,25 €Ex.
    In Stock
  • Ref : 16087
    9,90 € 8,25 €Ex.
    In Stock
  • Ref : 16088
    In Stock
    9,90 € 8,25 €Ex.
    In Stock
  • Ref : 16089
    In Stock
    9,90 € 8,25 €Ex.
    In Stock
  • Ref : 16090
    In Stock
    9,90 € 8,25 €Ex.
    In Stock
  • Ref : 16091
    In Stock
    9,90 € 8,25 €Ex.
    In Stock
  • Ref : 16092
    In Stock
    9,90 € 8,25 €Ex.
    In Stock
  • Ref : 16093
    In Stock
    9,90 € 8,25 €Ex.
    In Stock
  • Ref : 16094
    In Stock
    9,90 € 8,25 €Ex.
    In Stock
  • Ref : 16095
    In Stock
    9,90 € 8,25 €Ex.
    In Stock
  • Ref : 16104
    In Stock
    9,90 € 8,25 €Ex.
    In Stock
  • Ref : 16105
    In Stock
    9,90 € 8,25 €Ex.
    In Stock
  • Ref : 16106
    In Stock
    9,90 € 8,25 €Ex.
    In Stock
  • Ref : 16107
    9,90 € 8,25 €Ex.
    In Stock
  • Ref : 16096
    In Stock
    9,90 € 8,25 €Ex.
    In Stock
  • Ref : 16097
    In Stock
    9,90 € 8,25 €Ex.
    In Stock
  • Ref : 16108
    In Stock
    9,90 € 8,25 €Ex.
    In Stock
  • Ref : 16098
    In Stock
    9,90 € 8,25 €Ex.
    In Stock
  • Ref : 16099
    In Stock
    9,90 € 8,25 €Ex.
    In Stock
  • Ref : 16100
    In Stock
    9,90 € 8,25 €Ex.
    In Stock
  • Ref : 16101
    In Stock
    9,90 € 8,25 €Ex.
    In Stock
  • Ref : 16102
    In Stock
    9,90 € 8,25 €Ex.
    In Stock
  • Ref : 16103
    In Stock
    9,90 € 8,25 €Ex.
    In Stock
  • Ref : 12980
    In Stock
    The Mundorf MResist SUPREME resistance range offers products of exceptional quality. Having a real impact on the sound restitution, these resistances allow to obtain finer details and a much better spatialization.
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 14450
    In Stock
    The Mundorf MResist SUPREME range of resistors offers products of exceptional quality. With a real impact on sound reproduction, these resistors allow finer details and much better spatialization.
    13,90 € 11,58 €Ex.
    In Stock
  • Ref : 15558
    In Stock
    19,90 € 16,58 €Ex.
    In Stock
  • Ref : 4063
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4064
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4065
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4066
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4075
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4076
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4077
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4078
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4067
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4068
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4079
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
