TEK 5 Way Remote Source Selector Stereo
With this source selector, the signal is switched directly to the circuit to avoid passing it through to the selector in order to limit interference as much as possible.
4.0 / 5
Reference : 8333
25,20 €tax incl.
21,00 € tax excl.
TEK Sélecteur de source
TEK Sélecteur de Source Déporté 3 Voies Stéréo
With this source selector, the signal is switched directly to the circuit to avoid passing it through to the selector in order to limit interference as much as possible. The signal is output to a dedicated slot for XHP sockets (sold separately). The circuit is pre-drilled for easy installation of RCA connectors (sold separately).
5 positions, 3 RCA direct soldering
Product typeInput selector
Shaft typeNotched
Ø6mm
Shaft length26mm
HolesØ8mm
Flat cable width20mm
Flat cable length300mm
Nominal capacity30VDC 0.3A
Contact resistance≤ 0.02Ω
Insulation resistance≥ 100MΩ
Dimensions72 x 38mm
InputSolder pad
OutputSolder pad
TEK Sélecteur de source déporté
Sélecteur de qualité mais impossible de choisir le nombre de palier
This review has been posted for TEK 5 Way Remote Source Selector Stereo
With this source selector, the signal is switched directly to the circuit to avoid passing it through to the selector in order to limit...
