R-CORE Transformer 30VA 2x115V to 2x15V 1A
This R-Core transformer is ideal for powering a DAC or preamplifier. It has one primary 2x115V and two secondary 15V 1A
4.3 / 5
Reference : 8540
19,90 €tax incl.
16,58 € tax excl.
Shipping date: 17-09-2026.
Photos are not contractual.
The values of the secondary voltages of the transformers are the nominal load voltages. No-load voltages will be slightly higher than those stated.
Transformateur R-Core 30VA 2x115V vers 2x15V 1A
This R-Core transformer is ideal for powering a DAC or preamplifier. It has a 2x115V primary. Provided that the appropriate cabling is carried out, it will therefore be able to operate both on the European and American electricity grids.
With its two secondary windings, it can supply several devices requiring the indicated voltages and currents. There are therefore two 15V windings with a maximum current of 1A each. Moreover, it is equipped with a magnetic screen and an electrostatic screen.
Each cable is identified by a colour code. This colour code is detailed on a label glued directly to the transformer body.
Transformer dimensions
Product typeTransformer
FormatR-Core
Power30VA
Primary winding (input voltage)(230V)
0-115V
0-115V
Secondary winding (output voltage)0-15V 1A
0-15V 1A
Dimensions79 x 68 x 39mm
CablesFlexible
200mm
Weight680g
Mounting plateIncluded
Already mounted
Primary voltage (V)2x 115.0
Secondary voltage (V)15.0
Power (VA)30.0
3 reviews
Bien mais phases des secondaires non repérées
Plutôt bien, mais les phases des 2 secondaires de 15V ne sont pas repérées.
Si on les utilise en //, par exemple pour alimenter une alimentation stabilisée, l'absence de repérage des phases peut entraîner une surchauffe du transformateur même à vide (et l'alim peut ne pas fonctionner) comme dans mon cas.
Pour retrouver un fonctionnement normal, il suffit d'inverser un des 2 secondaires, mais il est regrettable que les phases ne soient pas repérées !
Un point qu'Audiophonics devrait faire corriger au fabricant..
A part ça RAS: Audiophonics au top côté livraison comme d'habitude.
This review has been posted for R-CORE Transformer 30VA 2x115V to 2x15V 1A
Great look&feel with the copper sheet wrapping at the outside.
Works flawless and buzz-free, which is important to me.
transformateur R-Core
Bon petit transfo. Compact. Absence de bruit/vibration, enroulements secondaires bien équilibrés.
NB 15v est la tension à pleine charge
Avec un montage consommant environ 100 ma. Les tensions sont à 18.1 v
(cela est sans conséquence pour mon application)
