Dlinkgo | RJ45 Desktop Switch 5 ports| Home and professional network
Expand your own network with this compact desktop switch. The D-LINK GO 5-port Gigabit easy desktop switch has 5 RJ45 ports that can be used to link many types of device together. Homes are equipped with more and more connected devices, this switch can bring them together with only one main cable for greater speed, performance and cable management efficiency.
Reference : 12619
27,90 €tax incl.
23,25 € tax excl.
Shipping date: 16-09-2025.
Fast-speed switch for home network
golink switch 5 ports
The D-Link Go SW 5G 5 Ports Gigagy Easy Desktop Switch is a convenient solution to create a high speed home or professionnal network.
It has 5enough RJ45 ports to link up to 5 devices at the same time, such as computer/laptop, DAC, IAP box...
With its intelligent design, the Dlink Go 5G can manage trafic distribution to provide optimal network access even when multiple devices are competiting for critical bandwidth.
The device is plug and play. No configuration is needed to make it work. Just plug your devices in and everything is already working.
Energy consumption management
As many products built by Dlinkgo, this switch was designed to offer the best performances with the most eco-friendly long-terme use. The EEE (Energy Efficient Ethernet) technology allows it to reduce the energy consumption when the network data usage is low. Because of this feature, the connected devices are also free to go to sleep mode.
The GOSW5G is protected from overheating thanks to a silent fan cooling system.
Caracteristics
  • 5 RJ45 Ports
  • Support LAN 10/100/1000
  • Conception 10 Gigabites
  • Auto MDI/MDIX
  • Support IEEE 802.3z
  • IEEE 802.3x Flow Control
  • Jumbo Frames 9.720Bytes Support
  • Dimensions : 90.2 x 72.2 x 22.5 mm
  • Alimentation : 5V/1A
Additionnal items :
  • Power cable
  • User manual
Length (m)N/A
ShieldingNC
Section (mm²)N/A
ConnectorRJ45
Conductors material (Cable)N/A
Conductors Plating (Cable)NC
D-LINK GO Network Switch RJ45 5 ports
Expand your own network with this compact desktop switch. The D-LINK GO 5-port Gigabit easy desktop switch has 5 RJ45 ports that can be used to...
